    Failed at the magicmirror@2.8.0 start script
    3 Posts 2 Posters 1.3k Views 2 Watching
    • I
      Ivanov_d
      When I restart the Raspberry (PRI3B+) I get this error in the pm2 log:
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.8.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2019-07-12T19_29_14_310Z-debug.log
      ATTENTION: default value of option force_s3tc_enable overridden by environment.
      npm ERR! errno 1
      npm ERR!
      npm ERR!     /home/pi/.npm/_logs/2019-07-12T19_59_43_770Z-debug.log
      And this is the output of the npm log:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.9.0
      3 info using node@v10.16.0
      5 info lifecycle magicmirror@2.8.0~prestart: magicmirror@2.8.0
      6 info lifecycle magicmirror@2.8.0~start: magicmirror@2.8.0
      7 verbose lifecycle magicmirror@2.8.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.8.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.8.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.8.0~start: Args: [ '-c', 'sh run-start.sh' ]
      11 silly lifecycle magicmirror@2.8.0~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.8.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.8.0 start: `sh run-start.sh`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
      13 verbose stack     at EventEmitter.emit (events.js:198:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:198:13)
      13 verbose stack     at maybeClose (internal/child_process.js:982:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.8.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.19.42-v7+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v10.16.0
      19 verbose npm  v6.9.0
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.8.0 start: `sh run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.8.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      The MagicMirror script starts though … and the modules are loaded …
      How can I fix this?
      • F
        flopp
        I got this after I set the Pi to not auto-start Desktop, reboot my Pi to implement my change. After reboot it starts in CLI, then I got the above message.
        I changed back so Desktop will auto-start, reboot but still same message as above.
        Was working perfect before.
        RPi 3B
        Raspbian Buster
        • F
          flopp
          My mistake was that I had chossen to auto-start Desktop but not Autologin, after I changed to Autologin with Desktop everything was fine again.
