Solved MMM-BackgroundSlideshow
Ok, thanks for the explanation :) I can understand that reasonably. You are a genius
@CyruS1337 no… it happened to me!
Now I thought it was solved, but after about 1 hour the screen was black again. I had to stop the MagicMirror with
pm2 stop 0
and then restart it withpm2 start 0
.I also changed the size from 100 to 1024.
What else can it be?
sudo dphys-swapfile swapoff sudo nano /etc/dphys-swapfile / (changed size 1024) sudo dphys-swapfile swapon
@CyruS1337 and rebooted after changing swap file
@sdetweil said in MMM-BackgroundSlideshow:
I have now reboot the mirror …
free -m
Command will show memory usage -
free -m
Command will show memory usagepi@raspberrypi_1:~ $ free -m total used free shared buff/cache available Mem: 925 218 404 1 302 657 Swap: 1023 111 912
This morning, the mirror was dark again.
This is the memory output
pi@raspberrypi_1:~ $ free -m total used free shared buff/cache available Mem: 925 220 391 1 313 653 Swap: 1023 118 905
Edit: The mirror was stopped and started and after 15min he was dark again …
I seem to have found the mistake. I have selected one to quality of photos for playing the photos (4mb per photo). The fact that I have chosen a lower quality of the photos, the problem is gone.
@CyruS1337 interesting, i use MMM-ImagesPhotos, and have lots of images over 4meg, most in the 11-13 meg range
