    MMM-BackgroundSlideshow
    30 Posts 4 Posters 12.4k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      Sorry, it’s me again.
      One of my PI’s actually ran for months without any problems. I updated the module MMM-BackgroundSlideshow 3 days ago. Since this update, my mirror is about 10min always dunek. When I enter pm2 start mm in the console, the picture comes back. I have also run the dependency in module folder npm install, without success.
      What could be the reason for this?
        sdetweil @CyruS1337
        @CyruS1337 show us pm2 logs
        CyruS1337C 1 Reply Last reply Reply Quote 0
          CyruS1337 Project Sponsor @sdetweil
          that would be the log files
          pi@raspberrypi_1:~/MagicMirror $ pm2 logs
          /home/pi/.pm2/pm2.log last 15 lines:
          PM2        | 2019-09-07T10:11:41: PM2 log: pid=840 msg=failed to kill - retrying in 100ms
          PM2        | 2019-09-07T10:11:42: PM2 log: pid=840 msg=failed to kill - retrying in 100ms
          PM2        | 2019-09-07T10:11:42: PM2 log: Process with pid 840 still alive after 1600ms, sending it SIGKILL now...
          PM2        | 2019-09-07T10:11:42: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
          PM2        | 2019-09-07T10:11:42: PM2 log: pid=840 msg=process killed
          PM2        | 2019-09-07T10:11:42: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2019-09-07T10:11:43: PM2 log: App [mm:0] online
          0|mm       | All module helpers loaded.
          0|mm       | Starting server on port 8080 ...
          0|mm       | Server started ...
          0|mm       | Connecting socket for: updatenotification
          0|mm       | Connecting socket for: MMM-Remote-Control
          0|mm       | Starting node helper for: MMM-Remote-Control
          0|mm       | Connecting socket for: MMM-NowPlayingOnSpotify
          0|mm       | Connecting socket for: MMM-MyCommute
          0|mm       | ====================== Starting node_helper for module [MMM-MyCommute]
          0|mm       | Connecting socket for: MMM-SystemStats
          0|mm       | Connecting socket for: MMM-BackgroundSlideshow
          0|mm       | Sockets connected & modules started ...
          0|mm       | Launching application.
          0|mm       | Refreshed access token because it has expired. Expired at: 10:12:00 now is: 10:12:01
          0|mm       | Refreshed access token because it has expired. Expired at: 11:12:01 now is: 10:12:01
          0|mm       | libGL error: MESA-LOADER: failed to retrieve device information
          0|mm       | MESA-LOADER: failed to retrieve device information
          0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
          0|mm       | (node:871) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [960:0907/095911.730586:FATAL:memory.cc(22)] Out of memory. size=96002048
          0|mm       | (node:3175) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [3214:0907/102404.493830:FATAL:memory.cc(22)] Out of memory. size=96002048
            @CyruS1337 said in MMM-BackgroundSlideshow:
            make the swap space bigger
            https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
              @sdetweil Ok, I did. I’ll watch that. Can you explain in one sentence what I just did here or where the mistake was?
                sdetweil @CyruS1337
                @CyruS1337 by default, the raspberry pi OS uses physical memory… if it runs out, it will try to swap out things not being used to make room for current work. but… the swap space is very small, only 100 meg…
                so the swap out fails, and the current process is killed
                  Ok, thanks for the explanation :) I can understand that reasonably. You are a genius
                    sdetweil @CyruS1337
                    @CyruS1337 no… it happened to me!
                      Now I thought it was solved, but after about 1 hour the screen was black again. I had to stop the MagicMirror with pm2 stop 0 and then restart it with pm2 start 0.
                      I also changed the size from 100 to 1024.
                      What else can it be?
                      sudo dphys-swapfile swapoff
                      sudo nano /etc/dphys-swapfile / (changed size 1024)
                      sudo dphys-swapfile swapon
                        sdetweil @CyruS1337
                        @CyruS1337 and rebooted after changing swap file
                          @sdetweil said in MMM-BackgroundSlideshow:
                          I have now reboot the mirror …
                            free -m
                            Command will show memory usage
                              free -m
                              pi@raspberrypi_1:~ $ free -m
                                            total        used        free      shared  buff/cache   available
                              Mem:            925         218         404           1         302         657
                              Swap:          1023         111         912
                                This morning, the mirror was dark again.
                                This is the memory output
                                Mem:            925         220         391           1         313         653
                                Swap:          1023         118         905
                                Edit: The mirror was stopped and started and after 15min he was dark again …
                                  I seem to have found the mistake. I have selected one to quality of photos for playing the photos (4mb per photo). The fact that I have chosen a lower quality of the photos, the problem is gone.
                                    sdetweil @CyruS1337
                                    @CyruS1337 interesting, i use MMM-ImagesPhotos, and have lots of images over 4meg, most in the 11-13 meg range
                                      Yes, that’s really interesting. But since I let the pictures play with max 1-2 MB, the mirror was never black anymore. Although I did the elevation of SWAP.
                                      • H Offline
                                        hootzter
                                        I’m new to magic mirror. Since two weeks I try to get MMM-ImagesPhotos or MMM-BackgroundSlideshow to work with the photos of my camera (all pictures are JPEG with 5 to 10 meg).
                                        Like @CyruS1337 the whole mirror goes black, if I use my photos but works if I use the example-pictures.
                                        @sdetweil :
                                        How did you get this to work with your pictures?
                                        Could you post your config (including tweeks you did) and tell us which pi you are using?
                                        I was so desperate that I looked for alternatives. I found pi3d but couldn’t integrate it into magic mirror.
                                        I would really appreciate your help.
                                        Best regards
                                        hootzter
                                          sdetweil @hootzter
                                          @hootzter said in MMM-BackgroundSlideshow:
                                          MMM-ImagesPhotos
                                          usually black screen means some missing library…
                                          if u npm start from the terminal window you will see runtime messages
                                          also from the developers window , ctrl-shift-i on the mirror keyboard, select the console tab, and scroll up.
                                          you can try my MMM-ImagesPhotos
                                          https://github.com/sdetweil/MMM-ImagesPhotos
                                          my config
                                          			module: "MMM-ImagesPhotos",
                                          			disabled: false,
                                          			position: "fullscreen",  // < --- this is the div location NOT screen covered with image
                                          				opacity: 0.9,
                                          				animationSpeed: 0,
                                          				updateInterval: 30000,  // how often to change pic
                                          				backgroundColor: "#808080", // color around pic (if u want something other than black)
                                          I have run this on pi0 thru pi4, mac, and two non-pi SBCs, odroid Xu4, and nano jetson.
                                          where did u put your pictures? the module is looking in the folder
                                          ~/MagicMirror/modules/MMm_ImagesPhotos/uploads
                                          I linked that to a mounted server volume
                                          now, my tweaks were to display the images without distortion… same aspect ratio as taken.
                                          I did NOT want the screen completely filled… (image stretched or clipped)
                                          to use mine, just rename the old MMM-ImagesPhotos folder out of the way, and then git clone my version of the module.
                                          • StoffbeuteluweS Offline
                                            Stoffbeuteluwe Project Sponsor @sdetweil
                                            @sdetweil Hi, is it possible to cover the whole screen with mmm images photos?
