    MMM-BackgroundSlideshow
    30 Posts 4 Posters 13.8k Views 4 Watching
      sdetweil @CyruS1337
      @CyruS1337 and rebooted after changing swap file
      CyruS1337C 1 Reply Last reply Reply Quote 0
      • CyruS1337C Offline
        CyruS1337 Project Sponsor @sdetweil
        @sdetweil said in MMM-BackgroundSlideshow:
        I have now reboot the mirror …
          free -m
          Command will show memory usage
            free -m
            pi@raspberrypi_1:~ $ free -m
                          total        used        free      shared  buff/cache   available
            Mem:            925         218         404           1         302         657
            Swap:          1023         111         912
              This morning, the mirror was dark again.
              This is the memory output
              Mem:            925         220         391           1         313         653
              Swap:          1023         118         905
              Edit: The mirror was stopped and started and after 15min he was dark again …
                I seem to have found the mistake. I have selected one to quality of photos for playing the photos (4mb per photo). The fact that I have chosen a lower quality of the photos, the problem is gone.
                  sdetweil @CyruS1337
                  @CyruS1337 interesting, i use MMM-ImagesPhotos, and have lots of images over 4meg, most in the 11-13 meg range
                    Yes, that’s really interesting. But since I let the pictures play with max 1-2 MB, the mirror was never black anymore. Although I did the elevation of SWAP.
                    • H Offline
                      hootzter
                      I’m new to magic mirror. Since two weeks I try to get MMM-ImagesPhotos or MMM-BackgroundSlideshow to work with the photos of my camera (all pictures are JPEG with 5 to 10 meg).
                      Like @CyruS1337 the whole mirror goes black, if I use my photos but works if I use the example-pictures.
                      @sdetweil :
                      How did you get this to work with your pictures?
                      Could you post your config (including tweeks you did) and tell us which pi you are using?
                      I was so desperate that I looked for alternatives. I found pi3d but couldn’t integrate it into magic mirror.
                      I would really appreciate your help.
                      Best regards
                      hootzter
                        sdetweil @hootzter
                        @hootzter said in MMM-BackgroundSlideshow:
                        MMM-ImagesPhotos
                        usually black screen means some missing library…
                        if u npm start from the terminal window you will see runtime messages
                        also from the developers window , ctrl-shift-i on the mirror keyboard, select the console tab, and scroll up.
                        you can try my MMM-ImagesPhotos
                        https://github.com/sdetweil/MMM-ImagesPhotos
                        my config
                        			module: "MMM-ImagesPhotos",
                        			disabled: false,
                        			position: "fullscreen",  // < --- this is the div location NOT screen covered with image
                        				opacity: 0.9,
                        				animationSpeed: 0,
                        				updateInterval: 30000,  // how often to change pic
                        				backgroundColor: "#808080", // color around pic (if u want something other than black)
                        I have run this on pi0 thru pi4, mac, and two non-pi SBCs, odroid Xu4, and nano jetson.
                        where did u put your pictures? the module is looking in the folder
                        ~/MagicMirror/modules/MMm_ImagesPhotos/uploads
                        I linked that to a mounted server volume
                        now, my tweaks were to display the images without distortion… same aspect ratio as taken.
                        I did NOT want the screen completely filled… (image stretched or clipped)
                        to use mine, just rename the old MMM-ImagesPhotos folder out of the way, and then git clone my version of the module.
                        • StoffbeuteluweS Offline
                          Stoffbeuteluwe Project Sponsor @sdetweil
                          @sdetweil Hi, is it possible to cover the whole screen with mmm images photos?
                            sdetweil @Stoffbeuteluwe
                            @Stoffbeuteluwe not with my code, no
                            the original code does fill the screen if u set the max height and width to the screen size
                            img.style.maxWidth = this.config.maxWidth;
                            img.style.maxHeight = this.config.maxHeight;
                            StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                              @sdetweil Thank you Sam 😀🙏
                                @sdetweil hi Sam can you help me again I have tried a lot but no luck…my screensize is
                                width: 1080
                                high: 1920
                                I don’t know how to set it the right way
                                Thanks 🙏
                                  @Stoffbeuteluwe are u portrait, not landscape? original or mine?
                                  it should work, but ugly
                                    @sdetweil Portrait
                                      @Stoffbeuteluwe oops. the width/height is from the imagesSlideshow
                                      this module only supports
                                      backgroundSize	The sizing of the background image. Values can be:
                                      cover: Resize the background image to cover the entire container, even if it has to stretch the image or cut a little bit off one of the edges.
                                      contain: Resize the background image to make sure the image is fully visible
                                      Example: 'contain'
                                      Default value: 'cover'
                                      This value is OPTIONAL
                                        also, how are you rotated? physical or CSS?
                                        module does
                                        			div1.style.transform="rotate(0deg)";
                                        then adjusts if different
                                        var Orientation = EXIF.getTag(this, "Orientation");
                                        				if (Orientation != null) {
                                          @sdetweil I rotate with settings on my Mac
                                          Settings , Monitor , Rotation 90
                                            @Stoffbeuteluwe hm… on my virtual mac, landscape it looks ok… (backgroundsize: ‘contain’)
                                            i don’t see that monitor settings option on my catalina mac vm…
