    MMM-BackgroundSlideshow
    30 Posts 4 Posters 11.2k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      Sorry, it’s me again.
      One of my PI’s actually ran for months without any problems. I updated the module MMM-BackgroundSlideshow 3 days ago. Since this update, my mirror is about 10min always dunek. When I enter pm2 start mm in the console, the picture comes back. I have also run the dependency in module folder npm install, without success.
      What could be the reason for this?
        sdetweil @CyruS1337
        @CyruS1337 show us pm2 logs
        CyruS1337C 1 Reply Last reply Reply Quote 0
          CyruS1337 Project Sponsor @sdetweil
          that would be the log files
          pi@raspberrypi_1:~/MagicMirror $ pm2 logs
          /home/pi/.pm2/pm2.log last 15 lines:
          PM2        | 2019-09-07T10:11:41: PM2 log: pid=840 msg=failed to kill - retrying in 100ms
          PM2        | 2019-09-07T10:11:42: PM2 log: pid=840 msg=failed to kill - retrying in 100ms
          PM2        | 2019-09-07T10:11:42: PM2 log: Process with pid 840 still alive after 1600ms, sending it SIGKILL now...
          PM2        | 2019-09-07T10:11:42: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
          PM2        | 2019-09-07T10:11:42: PM2 log: pid=840 msg=process killed
          PM2        | 2019-09-07T10:11:42: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2019-09-07T10:11:43: PM2 log: App [mm:0] online
          0|mm       | All module helpers loaded.
          0|mm       | Starting server on port 8080 ...
          0|mm       | Server started ...
          0|mm       | Connecting socket for: updatenotification
          0|mm       | Connecting socket for: MMM-Remote-Control
          0|mm       | Starting node helper for: MMM-Remote-Control
          0|mm       | Connecting socket for: MMM-NowPlayingOnSpotify
          0|mm       | Connecting socket for: MMM-MyCommute
          0|mm       | ====================== Starting node_helper for module [MMM-MyCommute]
          0|mm       | Connecting socket for: MMM-SystemStats
          0|mm       | Connecting socket for: MMM-BackgroundSlideshow
          0|mm       | Sockets connected & modules started ...
          0|mm       | Launching application.
          0|mm       | Refreshed access token because it has expired. Expired at: 10:12:00 now is: 10:12:01
          0|mm       | Refreshed access token because it has expired. Expired at: 11:12:01 now is: 10:12:01
          0|mm       | libGL error: MESA-LOADER: failed to retrieve device information
          0|mm       | MESA-LOADER: failed to retrieve device information
          0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
          0|mm       | (node:871) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [960:0907/095911.730586:FATAL:memory.cc(22)] Out of memory. size=96002048
          0|mm       | (node:3175) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [3214:0907/102404.493830:FATAL:memory.cc(22)] Out of memory. size=96002048
            @CyruS1337 said in MMM-BackgroundSlideshow:
            make the swap space bigger
            https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
              @sdetweil Ok, I did. I’ll watch that. Can you explain in one sentence what I just did here or where the mistake was?
                sdetweil @CyruS1337
                @CyruS1337 by default, the raspberry pi OS uses physical memory… if it runs out, it will try to swap out things not being used to make room for current work. but… the swap space is very small, only 100 meg…
                so the swap out fails, and the current process is killed
                  Ok, thanks for the explanation :) I can understand that reasonably. You are a genius
                    sdetweil @CyruS1337
                    @CyruS1337 no… it happened to me!
                      Now I thought it was solved, but after about 1 hour the screen was black again. I had to stop the MagicMirror with pm2 stop 0 and then restart it with pm2 start 0.
                      I also changed the size from 100 to 1024.
                      What else can it be?
                      sudo dphys-swapfile swapoff
                      sudo nano /etc/dphys-swapfile / (changed size 1024)
                      sudo dphys-swapfile swapon
                        sdetweil @CyruS1337
                        @CyruS1337 and rebooted after changing swap file
