    MMM-BackgroundSlideshow
    30 Posts 4 Posters 13.8k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      Ok, thanks for the explanation :) I can understand that reasonably. You are a genius
        sdetweil @CyruS1337
        @CyruS1337 no… it happened to me!
          Now I thought it was solved, but after about 1 hour the screen was black again. I had to stop the MagicMirror with pm2 stop 0 and then restart it with pm2 start 0.
          I also changed the size from 100 to 1024.
          What else can it be?
          sudo dphys-swapfile swapoff
          sudo nano /etc/dphys-swapfile / (changed size 1024)
          sudo dphys-swapfile swapon
            sdetweil @CyruS1337
            @CyruS1337 and rebooted after changing swap file
            CyruS1337C 1 Reply Last reply Reply Quote 0
              CyruS1337 Project Sponsor @sdetweil
              @sdetweil said in MMM-BackgroundSlideshow:
              I have now reboot the mirror …
                free -m
                Command will show memory usage
                  free -m
                  pi@raspberrypi_1:~ $ free -m
                                total        used        free      shared  buff/cache   available
                  Mem:            925         218         404           1         302         657
                  Swap:          1023         111         912
                    This morning, the mirror was dark again.
                    This is the memory output
                    Mem:            925         220         391           1         313         653
                    Swap:          1023         118         905
                    Edit: The mirror was stopped and started and after 15min he was dark again …
                      I seem to have found the mistake. I have selected one to quality of photos for playing the photos (4mb per photo). The fact that I have chosen a lower quality of the photos, the problem is gone.
                        sdetweil @CyruS1337
                        @CyruS1337 interesting, i use MMM-ImagesPhotos, and have lots of images over 4meg, most in the 11-13 meg range
                          Yes, that’s really interesting. But since I let the pictures play with max 1-2 MB, the mirror was never black anymore. Although I did the elevation of SWAP.
                          • H Offline
                            hootzter
                            I’m new to magic mirror. Since two weeks I try to get MMM-ImagesPhotos or MMM-BackgroundSlideshow to work with the photos of my camera (all pictures are JPEG with 5 to 10 meg).
                            Like @CyruS1337 the whole mirror goes black, if I use my photos but works if I use the example-pictures.
                            @sdetweil :
                            How did you get this to work with your pictures?
                            Could you post your config (including tweeks you did) and tell us which pi you are using?
                            I was so desperate that I looked for alternatives. I found pi3d but couldn’t integrate it into magic mirror.
                            I would really appreciate your help.
                            Best regards
                            hootzter
                              sdetweil @hootzter
                              @hootzter said in MMM-BackgroundSlideshow:
                              MMM-ImagesPhotos
                              usually black screen means some missing library…
                              if u npm start from the terminal window you will see runtime messages
                              also from the developers window , ctrl-shift-i on the mirror keyboard, select the console tab, and scroll up.
                              you can try my MMM-ImagesPhotos
                              https://github.com/sdetweil/MMM-ImagesPhotos
                              my config
                              			module: "MMM-ImagesPhotos",
                              			disabled: false,
                              			position: "fullscreen",  // < --- this is the div location NOT screen covered with image
                              				opacity: 0.9,
                              				animationSpeed: 0,
                              				updateInterval: 30000,  // how often to change pic
                              				backgroundColor: "#808080", // color around pic (if u want something other than black)
                              I have run this on pi0 thru pi4, mac, and two non-pi SBCs, odroid Xu4, and nano jetson.
                              where did u put your pictures? the module is looking in the folder
                              ~/MagicMirror/modules/MMm_ImagesPhotos/uploads
                              I linked that to a mounted server volume
                              now, my tweaks were to display the images without distortion… same aspect ratio as taken.
                              I did NOT want the screen completely filled… (image stretched or clipped)
                              to use mine, just rename the old MMM-ImagesPhotos folder out of the way, and then git clone my version of the module.
                              • StoffbeuteluweS Offline
                                Stoffbeuteluwe Project Sponsor @sdetweil
                                @sdetweil Hi, is it possible to cover the whole screen with mmm images photos?
                                  sdetweil @Stoffbeuteluwe
                                  @Stoffbeuteluwe not with my code, no
                                  the original code does fill the screen if u set the max height and width to the screen size
                                  img.style.maxWidth = this.config.maxWidth;
                                  img.style.maxHeight = this.config.maxHeight;
                                  StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                    @sdetweil Thank you Sam 😀🙏
                                      @sdetweil hi Sam can you help me again I have tried a lot but no luck…my screensize is
                                      width: 1080
                                      high: 1920
                                      I don’t know how to set it the right way
                                      Thanks 🙏
                                        @Stoffbeuteluwe are u portrait, not landscape? original or mine?
                                        it should work, but ugly
                                          @sdetweil Portrait
                                            @Stoffbeuteluwe oops. the width/height is from the imagesSlideshow
                                            this module only supports
                                            backgroundSize	The sizing of the background image. Values can be:
                                            cover: Resize the background image to cover the entire container, even if it has to stretch the image or cut a little bit off one of the edges.
                                            contain: Resize the background image to make sure the image is fully visible
                                            Example: 'contain'
                                            Default value: 'cover'
                                            This value is OPTIONAL
