    Almost done need to active my mirror by Phrase
    phrase
    24 Posts 4 Posters 12.6k Views 4 Watching
      sdetweil @otto
      @otto hotword hears the phrase, and sends the notification you configure.
      Some other module listens for that notification and does what you configure. No reason to send ANOTHER notification (notification trigger)… send what glance needs
      • O Offline
        otto @sdetweil
        @sdetweil okej so u think i just need hotword and glance?
        i did install MMM-glance i have no ide what i am doing right now. SO i guess this is as wrong at it can be:/
          module: 'MMM-Glance',
            defaultGlancingTime: 10000,
            alias: {
              "news" : "newsfeed",
        			module: "alert", "MMM-NowPlayingOnSpotify", "updatenotification", "calendar","compliments","currentweather","weatherforecast","newsfeed","MMM-Hotword","MMM-AssistantMk2",
              "party mode"  : ["clock", "helloworld", "MMM-Something"],
          hotword config doc
          https://github.com/eouia/MMM-Hotword/blob/master/documents/usage.md
          glance only displays the info for some period of time… (default 10 seconds)… how long do you want the info to stay on screen?
          the README.md file for each module tells how to use it
          • O Offline
            otto @sdetweil
            @sdetweil said in Almost done need to active my mirror by Phrase:
            hotword config doc
            thanks for link i have been redning and reding it a coupel of time, and i notis the "This is a real example of recipe file"
            is what i am looking for, that is a code for show all/hide all, the “only” thing i need figuer out, is how to get it to work, i need to record some new audio files, and change the “show all” to my phrase that i whant.
            and creat trainer for it:D
            looks like i maybe can solve this.
            The qustine is if i need to anything more?
            will that code hide all of my modules?
            or do i need to typ all the namn of them,
            dont rely know how to explain, i hoop u understand, if not let me know
            var recipe = {
              models: [
                  hotwords    : "hideall",
                  file        : "hideall.pmdl",
                  sensitivity : "0.5",
                  hotwords    : "showall",
                  file        : "showall.pmdl",
              commands: {
                "hideall": {
                  moduleExec: {
                    module: [],
                    exec: (module) => { module.hide()}
                "showall": {
                  moduleExec: {
                    module: [],
                    exec: (module) => { module.show()}
            exports.recipe = recipe // Don't remove this line.````
              [[global:former-user]] @otto
              @otto I think your code is enough.(at least logically). evenif there be a problem, it would not be serious to solve.
              • O Offline
                otto @Guest
                @Sean thanks for reply
                  commands: {
                    "hideall": {
                      moduleExec: {
                        **module: [],**
                        exec: (module) => { module.hide()}````
                Do i need write all of the module namn? or is that module [], inculude all of my module?
                if so i "just need to"
                1. record audio file using tranier
                2  add the file to models directory
                2. add the recipe file to  recipes directory
                3. add config js : recipes: ["hide_show_all"]
                any it that right?
                  @otto
                  module: [] will point all modules.
                  if you want, you can add specific module names in it. like module:["clock", "calendar"]
                  Your attempt is right. Wish you good luck.
                  If you have trouble, contact me via these;
                  • mail : eouia0819@gmail.com
                  • Telegram : @eouia
                    Or github issue board.
                    smassy
                    @otto
                    The way I did it is by using MMM-Assistantmk2, hotword and google voice reco. There is an already build ‘recipe’ in Assistantmk2 that do what you want.
                    The module is hide_and_show_all_modules.js
                    var recipe = {
                      transcriptionHook: {
                        "HIDE_ALL_MODULES": {
                          pattern: "Go to sleep",
                          command: "HIDEMODULES"
                        "SHOW_ALL_MODULES": {
                          pattern: "Wake up",
                          command: "SHOWMODULES"
                      command: {
                        "HIDEMODULES": {
                          moduleExec: {
                            module:()=>{
                              return []
                            exec: (module, params, key) => {
                              module.hide(1000, null, {lockString:"AMK2"})
                        "SHOWMODULES": {
                          moduleExec: {
                            module:()=>{
                              return []
                              module.show(1000, null, {lockString:"AMK2"})
                    In your config.js file , within the MMM-AssistantMk2 section, there is a line where you have to put all your ‘recipes’
                    recipes: ["hide_and_show_all_modules.js","playlist.js","volume.js"],
                    When I say ‘Jarvis Go to sleep’ my screen goes black and then when I say ‘Jarvis Wake up’ all my modules appear.
                    For the record I’m french :smiling_face: so the phrases there are not the one I’m using, it may need some test so you don’t use google reserved words.
                    O 2 Replies Last reply Reply Quote 0
                    • O Offline
                      otto @smassy
                      yes i am doing almost the same, i found the hide_and show all… i did make new hotword, and have edit the recipes… so all i have left now, was to start it and see it work but, cant some error in the config…
                      • O Offline
                        otto
                        i cant post my code, the forum is saying its spam:/
                                               recipes: ["hiden_show_all.js",]
                        		       chimeOnFinish: null,
                        		       mic: {
                        			recordProgram: "arecord",
                        			device: "plughw:1"
                        		models: [
                        				hotwords    : "smart_mirror",
                        				file        : "smart_mirror.umdl",
                        		commands: {
                        			"smart_mirror": {
                        				notificationExec: {
                        					notification: "ASSISTANT_ACTIVATE",
                        					payload: (detected, afterRecord) => {
                        						return {profile:"default"}
                        				restart:false,
                        				afterRecordLimit:0 ```
                        i am geting error on **chimeOnFinish: null,**
                          @otto
                          First, you should confirm how it works; With MMM-Hotword itself? or With MMM-AssistantMk2? both are slightly different. I think you have some confusing at this moment.
                          • O Offline
                            otto @Guest
                            @Sean dont relly understand you post. and dont rely know what i sholde do next, this is the first boot up afteri have create hotword, recipes, dont know if its wrong in my config or in my files,
                            this is my config:
                            https://pastebin.com/bw4QpXnL
                            it feels like my config is a bit messy?
                            • O Offline
                              otto @smassy
                              @smassy can u post your config, whant to see whear u add the recipes line,
                              • O Offline
                                otto
                                so i got some time over today, to test it all,
                                if i say: hide all module it dosent work
                                but it if i say :Smart mirror hide all modules it works
                                but mirror mirror on the wall i just get some saying from it, not show the modules.
                                i need to say :smart mirror show all module it works
                                can i some way change so i dont need to say smart mirror, just hide all module?
                                i now need to trying found out what is wrong…dont know wher to start, i guees the .pdl i a good one
                                ? S 2 Replies Last reply Reply Quote 0
                                  @otto
                                  You can use MMM-Hotword standalone without MMM-AsistantMk2 just to call simple Hotword as a command.
                                  Make your own .pmdl(“hide modules”). Then make a command of MMM-Hotword to be executed when “hide modules” be called.
                                    smassy
                                    @otto
                                    In config.js
                                                            module: "MMM-AssistantMk2",
        // --- ESSENTIALS / modifying for your environment might be needed.
        deviceLocation: {
        coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
        latitude: 45.6307, // -90.0 - +90.0
        longitude: -72.9563, // -180.0 - +180.0
        defaultProfile: "default", // If you have several profiles and want to set one of them as default profile, describe here.
        profiles: {
        "default" : { // profile name.
        profileFile: "default.json", // profile file name.
        lang: "fr-CA"
        //currently available (estimation, not all tested):
        //  de-DE, en-AU, en-CA, en-GB, en-US, en-IN
        // fr-CA, fr-FR, it-IT, ja-JP, es-ES, es-MX, ko-KR, pt-BR
        // https://developers.google.com/assistant/sdk/reference/rpc/languages
        /* Add your other profiles here, if exists.
        "other_profile" : {
        profileFile: "other.json",
        lang: "de-DE"
        record: { // Full values are in `FOR EXPERTS` section.
        recordProgram: "arecord",  // Defaults to "arecord" - also supports "rec" and "sox"
        device: "plughw:1"       // recording device (e.g.: "plughw:1")
        notifications: {
        ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
        ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
        play: { // Full values are in `FOR EXPERTS` section.
        playProgram: "mpg321", // recommended.
        // --- OPTIONAL / not important but customizable for your usage
        responseVoice: true, // If available, Assistant will response with her voice.
        responseScreen: true, // If available, Assistant will response with some rendered HTML
        responseAlert: true, // If available, Assistant will response with Alert module of MM
        // Sometimes, any response might not be returned. responseAlert is useful for displaying error.
        screenZoom: "80%", // Adjust responseScreen to your mirror size.
        screenDuration: 0, // milliseconds. How long responseScreen will be shown after speech.
        //If you set 0, Screen Output will be closed after Response speech finishes ASAP.
        youtubeAutoplay: true, //If set as true, found Youtube video will be played automatically.
        pauseOnYoutube:true, //If set as true, You cannot activate Assistant during youtube playing.
        //Recommended for the performance (Because permanent hotword detecting might make performance lower)
        youtubePlayerVars: { // You can set youtube playerVars for your purpose, but should be careful.
        "controls": 0,
        "loop": 1,
        "rel": 0,
                                    youtubePlayQuality: "default", //small, medium, large, hd720, hd1080, highres or default
        useWelcomeMessage: "", //Try "brief today" as this value. You can use this value to check module working when MM is starting.
        onIdle: {
        //timer: 1000*60*30, // if you don't want to use this feature, just set timer as `0` or command as ""
        //command: "HIDEMODULES",
        timer: 0,
        command: null,
        onActivate: {
        timer: 0,
        //command: "SHOWMODULES"
        command: null,
                                      smassy @otto
                                      @otto
                                      I think you can do that but it’s going to be painful since the mirror will listen and react to everything people say near him. The magic word (jarvis, mirrror mirror,etc…) is a safeguard to that behavior.
