    Almost done need to active my mirror by Phrase
    phrase
    24 Posts 4 Posters 12.6k Views 4 Watching
      sdetweil @otto
      @otto I think MMM-Hotword has enough capability to wake up from sleeping hotword detection
      • O Offline
        otto @sdetweil
        @sdetweil said in Almost done need to active my mirror by Phrase:
        The question is how… I have found one that are using Alexa, but not google.
        And to be honest I don’t rely know where to start.
          sdetweil @otto
          @otto MMM-Hotword listens for the starter word (alexa, mirror, smart-mirrot…) and then signals assistant started, so the assistant can take over. MMM-AssistantMk2 is for google assistant…
          but the latest hotword can do wakeup i think… @Sean has done a good job…
          i use this combo on one of my mirror setups… (mostly to tell it to go to sleep!, vs wait til the no motion timeout)…
          but i can ask anything i can ask GA. my home automation goes thru insteon smarthome devices which I have connected thru Alexa. i haven’t tried GA for that
          • O Offline
            otto
            @sdetweil i have been doing som googleing… and found some intresseting post in the forum:
            https://forum.magicmirror.builders/topic/5003/mmm-glance-glance-focus-specific-module-s
            https://forum.magicmirror.builders/topic/8444/wake-mirror-with-voice/14?
            page=2
            https://forum.magicmirror.builders/topic/653/voice-controlled-wake-sleep-function
            • O Offline
              otto
              i think i will needing this:
              MMM-Glance will be use as hiding the modules
              MMM-Hotword for for the comand mirror mirror on the wall to active it
              MMM-NotificationTrigger that will do the hard work and start/stop it all
              if i can combien them some way it can work, dont know if there is a more faster way
              and not sure how
                sdetweil @otto
                @otto hotword hears the phrase, and sends the notification you configure.
                Some other module listens for that notification and does what you configure. No reason to send ANOTHER notification (notification trigger)… send what glance needs
                • O Offline
                  otto @sdetweil
                  @sdetweil okej so u think i just need hotword and glance?
                  i did install MMM-glance i have no ide what i am doing right now. SO i guess this is as wrong at it can be:/
                    module: 'MMM-Glance',
                      defaultGlancingTime: 10000,
                      alias: {
                        "news" : "newsfeed",
                  			module: "alert", "MMM-NowPlayingOnSpotify", "updatenotification", "calendar","compliments","currentweather","weatherforecast","newsfeed","MMM-Hotword","MMM-AssistantMk2",
                        "party mode"  : ["clock", "helloworld", "MMM-Something"],
                    hotword config doc
                    https://github.com/eouia/MMM-Hotword/blob/master/documents/usage.md
                    glance only displays the info for some period of time… (default 10 seconds)… how long do you want the info to stay on screen?
                    the README.md file for each module tells how to use it
                    • O Offline
                      otto @sdetweil
                      hotword config doc
                      thanks for link i have been redning and reding it a coupel of time, and i notis the "This is a real example of recipe file"
                      is what i am looking for, that is a code for show all/hide all, the “only” thing i need figuer out, is how to get it to work, i need to record some new audio files, and change the “show all” to my phrase that i whant.
                      and creat trainer for it:D
                      looks like i maybe can solve this.
                      The qustine is if i need to anything more?
                      will that code hide all of my modules?
                      or do i need to typ all the namn of them,
                      dont rely know how to explain, i hoop u understand, if not let me know
                      var recipe = {
                        models: [
                            hotwords    : "hideall",
                            file        : "hideall.pmdl",
                            sensitivity : "0.5",
                            hotwords    : "showall",
                            file        : "showall.pmdl",
                        commands: {
                          "hideall": {
                            moduleExec: {
                              module: [],
                              exec: (module) => { module.hide()}
                          "showall": {
                            moduleExec: {
                              module: [],
                              exec: (module) => { module.show()}
                      exports.recipe = recipe // Don't remove this line.````
                        [[global:former-user]] @otto
                        @otto I think your code is enough.(at least logically). evenif there be a problem, it would not be serious to solve.
                        • O Offline
                          otto @Guest
                          @Sean thanks for reply
                            commands: {
                              "hideall": {
                                moduleExec: {
                                  **module: [],**
                                  exec: (module) => { module.hide()}````
                          Do i need write all of the module namn? or is that module [], inculude all of my module?
                          if so i "just need to"
                          1. record audio file using tranier
                          2  add the file to models directory
                          2. add the recipe file to  recipes directory
                          3. add config js : recipes: ["hide_show_all"]
                          any it that right?
                            @otto
                            module: [] will point all modules.
                            if you want, you can add specific module names in it. like module:["clock", "calendar"]
                            Your attempt is right. Wish you good luck.
                            If you have trouble, contact me via these;
                            • mail : eouia0819@gmail.com
                            • Telegram : @eouia
                              Or github issue board.
                              smassy
                              @otto
                              The way I did it is by using MMM-Assistantmk2, hotword and google voice reco. There is an already build ‘recipe’ in Assistantmk2 that do what you want.
                              The module is hide_and_show_all_modules.js
                              var recipe = {
                                transcriptionHook: {
                                  "HIDE_ALL_MODULES": {
                                    pattern: "Go to sleep",
                                    command: "HIDEMODULES"
                                  "SHOW_ALL_MODULES": {
                                    pattern: "Wake up",
                                    command: "SHOWMODULES"
                                command: {
                                  "HIDEMODULES": {
                                    moduleExec: {
                                      module:()=>{
                                        return []
                                      exec: (module, params, key) => {
                                        module.hide(1000, null, {lockString:"AMK2"})
                                  "SHOWMODULES": {
                                    moduleExec: {
                                      module:()=>{
                                        return []
                                        module.show(1000, null, {lockString:"AMK2"})
                              In your config.js file , within the MMM-AssistantMk2 section, there is a line where you have to put all your ‘recipes’
                              recipes: ["hide_and_show_all_modules.js","playlist.js","volume.js"],
                              When I say ‘Jarvis Go to sleep’ my screen goes black and then when I say ‘Jarvis Wake up’ all my modules appear.
                              For the record I’m french :smiling_face: so the phrases there are not the one I’m using, it may need some test so you don’t use google reserved words.
                              O 2 Replies Last reply Reply Quote 0
                              • O Offline
                                otto @smassy
                                yes i am doing almost the same, i found the hide_and show all… i did make new hotword, and have edit the recipes… so all i have left now, was to start it and see it work but, cant some error in the config…
                                • O Offline
                                  otto
                                  i cant post my code, the forum is saying its spam:/
                                                         recipes: ["hiden_show_all.js",]
                                  		       chimeOnFinish: null,
                                  		       mic: {
                                  			recordProgram: "arecord",
                                  			device: "plughw:1"
                                  		models: [
                                  				hotwords    : "smart_mirror",
                                  				file        : "smart_mirror.umdl",
                                  		commands: {
                                  			"smart_mirror": {
                                  				notificationExec: {
                                  					notification: "ASSISTANT_ACTIVATE",
                                  					payload: (detected, afterRecord) => {
                                  						return {profile:"default"}
                                  				restart:false,
                                  				afterRecordLimit:0 ```
                                  i am geting error on **chimeOnFinish: null,**
                                    @otto
                                    First, you should confirm how it works; With MMM-Hotword itself? or With MMM-AssistantMk2? both are slightly different. I think you have some confusing at this moment.
                                    • O Offline
                                      otto @Guest
                                      @Sean dont relly understand you post. and dont rely know what i sholde do next, this is the first boot up afteri have create hotword, recipes, dont know if its wrong in my config or in my files,
                                      this is my config:
                                      https://pastebin.com/bw4QpXnL
                                      it feels like my config is a bit messy?
                                      • O Offline
                                        otto @smassy
                                        @smassy can u post your config, whant to see whear u add the recipes line,
                                        • O Offline
                                          otto
                                          so i got some time over today, to test it all,
                                          if i say: hide all module it dosent work
                                          but it if i say :Smart mirror hide all modules it works
                                          but mirror mirror on the wall i just get some saying from it, not show the modules.
                                          i need to say :smart mirror show all module it works
                                          can i some way change so i dont need to say smart mirror, just hide all module?
                                          i now need to trying found out what is wrong…dont know wher to start, i guees the .pdl i a good one
                                          ? S 2 Replies Last reply Reply Quote 0
                                            @otto
                                            You can use MMM-Hotword standalone without MMM-AsistantMk2 just to call simple Hotword as a command.
                                            Make your own .pmdl(“hide modules”). Then make a command of MMM-Hotword to be executed when “hide modules” be called.
