    SmartThings
    28 Posts 5 Posters 14.1k Views 6 Watching
    • johnnyboyJ
      johnnyboy @cowboysdude
      @cowboysdude said in SmartThings:
      @johnnyboy trying… trying LOL Great to see you!!!
      As @buzzkc has stated about Device Handlers, and Im sure you have (Must have?) already done this… these can be found in the IDE, which are C&P from github.
      There is a constantly updated list of DH’s on the ST Forum, so worth checking that out to compare with the devices you have, and wish to manipulate.
      Me personaly, I use WebCoRE to do my manipulation… and If I need to add anything that is not the “Norm” then I would simply create a Virtual switch on the IDE, and then point towards that, with my chosen manipulation… and if you have used WebCoRE before, then you know it has limitless possibilities. Bad comparason, but I look at WebCoRE as IFTTT on Steroids :-)
      Some things I do, requires using several items… like my door sensor for example - It opens (Trigger ) and it then informs ST… which then informs WebCoRE, whitch then informs EchoSpeaks to then go through Amazon, to speak my chosen text, on my chosen Amazon devices - “Warning, Side door has been opened… Alarm sequence will initiate in T-Minus 20 seconds”
      I also added in another “Then” which will turn my chosen lights on @ 100%, until door is closed… and also to turn on my smart plug, which has a Siren attached, to activate after the 20 second time, also to start recording on CCTV in that location.
      The lag on this is about 2 seconds… so not a real concern given the hoops it has to jump through beforehand.
      I have only ever needed to slightly alter a DH once, for a Hive Sensor… but that was to simply change a 6second delay to a 12 second delay… purely because the original usage would be going through 1 loop, and I was going through 4, so need to extend the timeout.
      I also have my Hive Heating controllable through ST of sorts, using ActionTiles and placing Hive on the screen there.
      IF my MM was Touchscreen, and I had the time to work it out, I would have loved to be able to place several icons/Tiles (Virtual Switches) onto it, and control numerous ST devices from there… But I found it far far quicker, and easier, to simply use a Tablet… with the benefit that I can add several other tablets throughout the house, each with either control of that zone only, or the ability to swipe to another zone from the same screen… by creating a Link tile in every window to go to a chosen zone.
      You could also create Media Tiles… showing a constant stream of several cameras… and make that Tile as small or as big as you like… I have Netflix/Amazon/Kodi/IPTV as tiles too, so one click, and it pops up for me.
      And, as mentioned, it will aslo link to any app you have on the device you are using, by creating a link tile to it… which will open up for you directly in that screen/tile… and I find this usefull when playing music through my Sonos system, and can bring up the full library to choose from, and be able to control the speakers too.
      I’m not sure by your OP that you are wanting to manipulate the data to then create something to use on the MM framework, or whether you simply want to manipulate the data just to alter things to your own suiting?
      But if you have read anything above that you need any more info on, then ask away…
      Reply Quote 2
      • buzzkcB
        buzzkc
        I’m finally starting to make some progress on this. I’ve been doing development in a docker instance and found editing files while the container is running corrupts files. :-)
        So I have it connecting and bringing back device information at this point. I still need to parse that info. I’m working through the steps get all the info in the correct order to model it (get device ids>>get device components>>get device capabilities>>statuses etc.)
        I do have two hubs and found that it brings back devices for all hubs, so I’ll need to get the hub info too.
        Darren
        My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
        • cowboysdudeC
          This is something that I want to seriously look at this winter. Time right now is very hard for me to do anything…but I am keeping an eye on this and I appreciate ALL the input!!!
          I am trying first to get my thermostat to work via the mirror… module form. I can do it other ways but I want to learn how to use this IDE. But it gets to be too much… but you both have excellent ideas that I will be picking your brains soon!!! :)
          Keep posting please!!
          • buzzkcB
            buzzkc
            I’ve made a little more progress on this, but nothing to display the device info yet. I found the node-smarthings library uses promises to return results, which I’ve not worked with specifically, so been struggling with tying the device information to the device capability status results. I think I’ve finally worked passed it, but still have some testing to do.
            I’ve been trying to pass the device object from the first call to the call back function for the capability status, but not figured out how to do that. All of the status results were tied to the last device processed from the device callback. I did finally move the looping of devices to where only one device was sent to the socket notification that calls the capability status and seems to be working that way.
            Darren
              sdetweil @buzzkc
              @buzzkc so, with promises, you have a ‘then’, with a ‘resolve’ and an ‘error’ callback, and the resolve and reject methods of the promise can provide data to the resolve and error routines…
              just a reminder, the return new Promise() returns IMMEDIATELY… the function inside the promise is called async sometime (milliseconds) later
                 function_name: function(parm1_in, parm2_in) {
                   return new Promise( function (resolve,reject){
                           if( all_good) {
                               resolve(data_item)
                          else {
                              reject(error_data)
              then the method CALLING this function
                  function_name(parm1, parm2).then(
                           resolve_func(data_item){ },
                           error_func(error_data){}
              a working example , using the arrow function (parm) => {
              the arrow function insures that the data context of the outside caller is maintained,
              where as function(parm) { does not (u had to use the ‘self =this’ thing
              let promise = new Promise(function(resolve, reject) {
               if(!setTimeout(() => resolve("done!"), 1000)){
                   reject("settimeout_failed")
              // resolve runs the first function in .then, reject runs the second function
              promise.then(     // this will block until the function inside the promise call resolve or reject
                result => alert(result), // shows "done!" after 1 second
                error => alert(error) // doesn't run .. this will never occurr as settimeout never fails.
              Reply Quote 2
              • buzzkcB
                buzzkc
                Thanks Sam, That does help explain things. The grandkids are visiting, so will be a day or so before I get back to this, unless I just can’t sleep tonight. ;-)
                Darren
                  sdetweil @buzzkc
                  @buzzkc no problem… i’ll be around
                  also, the function in the promise can also be arrow
                  return new Promise(  (resolve,reject) =>{
                              if( all_good) {
                                   resolve(data_item)
                              else {
                                  reject(error_data)
                    and you can nest calls to functions that return Promises.
                       call_function_a(parm1, parm2).then( resolve_function(resolve_parm){
                                     ... processing
                                      call function_b(resolve_parm).then(resolve_function(some_otherdata){
                                      ....     processing
                    the 1st call_function_a routine will return a Promise object immediately
                    and when the function inside the promise resolves, then ‘.then (resolve’ function will be called.
                    the ‘.then’ waits
                    you can also split it up and wait later
                      var p =   call_function_a(parm1, parm2)
                         processing
                         processing
                      Promise(p).then (... etc)
                    i have a piece of code that loads a list of images from multiple difference sources, and knowing these take a ‘long time’ I wrapped them in promises… and start multiple at the same time…
                    now I have a list (array) of promises… but need to wait for all of them to complete (to have the complete list of images)
                    Promise.all(list).then(() => { sort full list of images, note that resolve() can't send back the list as its not complete }
                    you can also wait for one
                    Promise.race(list).then( ... etc)
                    • buzzkcB
                      buzzkc
                      Still working on getting things to refresh, but here is a teaser…
                      alt text
                      Let me know if the pic isn’t showing or disappears, using google photos
                      Darren
                        sdetweil @buzzkc
                        @buzzkc looks good
                        • buzzkcB
                          buzzkc
                          I’ll start a new thread for this, but if anyone wants to try it out or PR it, keep in mind, it’s my first module. ;-)
                          https://github.com/buzzkc/MMM-Smartthings
                          Currently I’m only supporting a subset of device capabilities. I can only run one instance of the module also since everything is returned to a global array. More than one instance all the devices from each module instances get put into the array and the full list of devices displays on all instances rather than what was specified for that instance.
                          For multiple capabilities in the list, the display is sorted by device name, then by capability alphabetically.
                          It also displays devices for all locations, I’ll see if I can make this selective in the future, but fits my needs as it is.
                          Darren
                          • cowboysdudeC
                            Just stopping in and I wanted to say Thank you guys for working on this! I am still hammered as all get out with work and crawl home most nights… I’m running 3 months behind right now. But I wanted to check in and wow… this is amazing!! Thank you guys so much!
                            • buzzkcB
                              buzzkc
                              Well, looks like it’s duplicating some of the items in the array. I’ll get a patch uploaded for it soon.
                              Edit: Found this was due to having more than one browser open, each instance was updating the global array. Working on a fix.
                              Darren
                              • buzzkcB
                                buzzkc
                                I’ve fixed the duplication, added an excluded device name list, fixed some timing issues, and cleaned it up.
                                I’m not entirely happy with the way I’m getting all the data, but I haven’t quite figured out a good way to wait for all the promises returned from the smartthings-node library. I have to loop the capabilities, make a request to get devices by capability, wait for that promise, then loop devices to get the statuses for each, once those promises return I need to pair up the status with its device.
                                So the ugly of it is that I’m just pushing all the data via sockets for each status request into an array that gets updated, then it gets fed to the getDom(). Not pretty, but it’s working.
                                Darren
                                • buzzkcB
                                  buzzkc
                                  Ok, I think I’ve gotten things to where it’s ready to share, I posted it up on the modules forum…Thanks again for all the feedback.
                                  https://forum.magicmirror.builders/topic/11270/mmm-smartthings
                                  Darren
                                  • cowboysdudeC
                                    Someone please close this topic … It has moved here:
                                    Thank you all!! :)
