    328 Posts 27 Posters 740.6k Views 24 Watching
      sdetweil @bobwilliams
      @bobwilliams and one thing to try, is to reinstall again…
      mv MagicMirror MagicMirror.save
      then use my updated installer
      bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
      so we can see if the install works, and then work on the update again..
        bobwilliams
        Well, let’s start reinstalling
          bobwilliams @sdetweil
          Installation was successful, but the mirror did not start
            @bobwilliams can you show me the pm2 logs
              bobwilliams
              no longer, I removed raspbian, and put it all over again …
                bobwilliams
                I think the problem was not in your script, but in my system
                  bobwilliams
                  I will reinstall now and let you know
                    bobwilliams
                    the mirror did not start, although for the first time it started immediately …
                      @bobwilliams Post the install.log
                      And the pm2.log
                      or send to me
                        @bobwilliams Not sure what u said.
                          @sdetweil unfortunately I can’t. in the morning, raspberry did not turn on
                            @sdetweil a month ago when I installed the mirror according to your script, everything worked right away. but did not start yesterday.
                              @bobwilliams Ok. Send me the log if u get a chance. Thx
                              • buzzkcB
                                buzzkc
                                @sdetweil I did run this the other day when I was having an issue with node_helper not found. It didn’t fix that, but another message you posted did. The upgrade worked fine, but may be worth adding that git checkout of the node_helper index file to the script as a quick fix.
                                Darren
                                My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
                                  sdetweil @buzzkc
                                  @buzzkc Good idea. I can check if the file is present and restore it if not
                                    @sdetweil a few days ago I copied the image from a flash drive, now I restored it and everything repeats, again these files that he asks to save or not … if you say yes, the update does not work, if you say no then the mirror stops working
                                      @bobwilliams i need to see the MagicMirror/installers/upgrade.log…
                                      and also, open the developers window (ctrl-shift-i) and select the tab labebed ‘console’ and scroll up to find any errors…
                                      also the pm2.log
                                        @sdetweil ok try to do tomorrow, today was a hard day very tired
                                          @sdetweil Everything has appeared to be simpler than we thought. I moved the files which were the obstacle on the way of working of your script to another folder, then updated the mirror using your script. After that I moved those files back and now mirror is working.
                                            @bobwilliams What files? My script should handle it. So I want to understand.
                                            • 16
                                            • 17
                                            • 7 / 17
