    328 Posts 27 Posters 706.4k Views 24 Watching
      sdetweil @bobwilliams
      @bobwilliams Post the install.log
      And the pm2.log
      or send to me
        @bobwilliams Not sure what u said.
          bobwilliams @sdetweil
          @sdetweil unfortunately I can’t. in the morning, raspberry did not turn on
            @sdetweil a month ago when I installed the mirror according to your script, everything worked right away. but did not start yesterday.
              @bobwilliams Ok. Send me the log if u get a chance. Thx
              • buzzkcB Offline
                buzzkc
                @sdetweil I did run this the other day when I was having an issue with node_helper not found. It didn’t fix that, but another message you posted did. The upgrade worked fine, but may be worth adding that git checkout of the node_helper index file to the script as a quick fix.
                Darren
                My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
                  sdetweil @buzzkc
                  @buzzkc Good idea. I can check if the file is present and restore it if not
                    @sdetweil a few days ago I copied the image from a flash drive, now I restored it and everything repeats, again these files that he asks to save or not … if you say yes, the update does not work, if you say no then the mirror stops working
                      @bobwilliams i need to see the MagicMirror/installers/upgrade.log…
                      and also, open the developers window (ctrl-shift-i) and select the tab labebed ‘console’ and scroll up to find any errors…
                      also the pm2.log
                        @sdetweil ok try to do tomorrow, today was a hard day very tired
                          @sdetweil Everything has appeared to be simpler than we thought. I moved the files which were the obstacle on the way of working of your script to another folder, then updated the mirror using your script. After that I moved those files back and now mirror is working.
                            @bobwilliams What files? My script should handle it. So I want to understand.
                              @sdetweil /MagicMirror/installers/mm.sh
                              /MagicMirror/modules/default/calendar/calendar.js
                                /MagicMirror/modules/default/currentweather/currentweather.js
                              /MagicMirror/modules/default/weather/weather.js /MagicMirror/modules/default/weatherforecast/weatherforecast.js
                              /MagicMirror/package-lock.json
                              /MagicMirror/run-start.sh
                              when updating, your script asked to save these files or not. if I wrote yes, it was not updated, if I wrote no, the update went fine but the mirror stopped working. I just moved these files, updated the mirror, and put them back in place. and the mirror works
                                @bobwilliams Ok. I put a fix in for Save=yes. Save=No should replace them w local repo version…and then upgrade.
                                Will have to build test. Really want to see the upgrade log, and pm2 logs for why it stoppexy
                                  @sdetweil sent by mail
                                    @bobwilliams got them thanks… you didn’t happen to save that ‘failing’ MagicMirror folder did you?
                                      @sdetweil no, it didn’t work out
                                        @sdetweil Have you looked at what was the problem?
                                          @bobwilliams yes, the merge returns an error i don’t handle… but I don’t know what the error means…
                                          so was hoping u had the folder saved, so I could get a copy to test with…
                                            I have submitted this script as part of pull request 1789
                                            • 10
                                            • 16
                                            • 17
                                            • 8 / 17
