    328 Posts 27 Posters 701.1k Views 24 Watching
      sdetweil @bobwilliams
      @bobwilliams i need to see the MagicMirror/installers/upgrade.log…
      and also, open the developers window (ctrl-shift-i) and select the tab labebed ‘console’ and scroll up to find any errors…
      also the pm2.log
        bobwilliams @sdetweil
        @sdetweil ok try to do tomorrow, today was a hard day very tired
          @sdetweil Everything has appeared to be simpler than we thought. I moved the files which were the obstacle on the way of working of your script to another folder, then updated the mirror using your script. After that I moved those files back and now mirror is working.
            @bobwilliams What files? My script should handle it. So I want to understand.
              @sdetweil /MagicMirror/installers/mm.sh
              /MagicMirror/modules/default/calendar/calendar.js
                /MagicMirror/modules/default/currentweather/currentweather.js
              /MagicMirror/modules/default/weather/weather.js /MagicMirror/modules/default/weatherforecast/weatherforecast.js
              /MagicMirror/package-lock.json
              /MagicMirror/run-start.sh
              when updating, your script asked to save these files or not. if I wrote yes, it was not updated, if I wrote no, the update went fine but the mirror stopped working. I just moved these files, updated the mirror, and put them back in place. and the mirror works
                @bobwilliams Ok. I put a fix in for Save=yes. Save=No should replace them w local repo version…and then upgrade.
                Will have to build test. Really want to see the upgrade log, and pm2 logs for why it stoppexy
                  @sdetweil sent by mail
                    @bobwilliams got them thanks… you didn’t happen to save that ‘failing’ MagicMirror folder did you?
                      @sdetweil no, it didn’t work out
                        @sdetweil Have you looked at what was the problem?
                          @bobwilliams yes, the merge returns an error i don’t handle… but I don’t know what the error means…
                          so was hoping u had the folder saved, so I could get a copy to test with…
                            I have submitted this script as part of pull request 1789
                            • swvalentiS Offline
                              swvalenti Project Sponsor
                              @sdetweil Idk why or if this is even the case but I updated MMM-EventHorizon and now I get a black screen and server shows errored below…any ideas how to fix?
                              pi@raspberrypi:~ $ pm2 restart mm
                              [PM2] Applying action restartProcessId on app [mm](ids: 1)
                              [PM2] [mm](1) ✓
                              │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
                              │ mm          │ 1  │ N/A  │ fork   │ online  │ 5   │ 0%     │ 2.5 MB   │
                              │ omx_stream1 │ 2  │ N/A  │ fork   │ online  │ 28  │ 0%     │ 2.8 MB   │
                              │ omx_stream2 │ 3  │ N/A  │ fork   │ online  │ 28  │ 0%     │ 2.7 MB   │
                              │ omx_stream3 │ 4  │ N/A  │ fork   │ online  │ 28  │ 0%     │ 2.7 MB   │
                              │ server      │ 0  │ N/A  │ fork   │ errored │ 0   │ 0%     │ 0 B      │
                              swvalentiS Mykle1M 2 Replies Last reply Reply Quote 0
                                swvalenti Project Sponsor @swvalenti
                                @sdetweil Actually idk what the issue is…black screen even though all show online. Odd
                                  @sdetweil I fixed the server issue and it shows online. But still get a black screen when start MM. So frustrating
                                    @sdetweil I stand corrected I did not fix server issue…
                                        pi@raspberrypi:~ $ pm2 logs
                                        /home/pi/.pm2/pm2.log last 15 lines:
                                        PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream1:2] exited with code [1] via signal [SIGINT]
                                        PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream1:2] starting in -fork mode-
                                        PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream1:2] online
                                        PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream2:3] exited with code [1] via signal [SIGINT]
                                        PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream2:3] starting in -fork mode-
                                        PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream2:3] online
                                        PM2        | 2019-12-07T15:04:13: PM2 log: App [omx_stream3:4] exited with code [1] via signal [SIGINT]
                                        PM2        | 2019-12-07T15:04:13: PM2 log: App [omx_stream3:4] starting in -fork mode-
                                        PM2        | 2019-12-07T15:04:13: PM2 log: App [omx_stream3:4] online
                                        PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream1:2] exited with code [1] via signal [SIGINT]
                                        PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream1:2] starting in -fork mode-
                                        PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream1:2] online
                                        PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream2:3] exited with code [1] via signal [SIGINT]
                                        PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream2:3] starting in -fork mode-
                                        PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream2:3] online
                                        /home/pi/.pm2/logs/omx-stream2-error.log last 15 lines:
                                        /home/pi/.pm2/logs/omx-stream3-error.log last 15 lines:
                                        /home/pi/.pm2/logs/omx-stream1-error.log last 15 lines:
                                        2|omx_stre |
                                        2|omx_stre | #
                                        2|omx_stre | # Fatal process OOM in heap setup
                                        2|omx_stre | #
                                        2|omx_stre |
                                        2|omx_stre | /usr/bin/env: error while loading shared libraries: /usr/lib/arm-linux-gnueabihf/libarmmem.so: cannot make segment writable for relocation: Cannot allocate memory
                                        2|omx_stre | /usr/bin/omxplayer: xmalloc: .././subst.c:3868: cannot allocate 131 bytes (159744 bytes allocated)
                                        2|omx_stre | /usr/bin/omxplayer: line 67:  5417 Aborted                 (core dumped) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                        2|omx_stre | /usr/bin/omxplayer.bin: error while loading shared libraries: libmpg123.so.0: failed to map segment from shared object
                                        2|omx_stre | /usr/bin/omxplayer: line 67:  9527 Aborted                 (core dumped) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                        2|omx_stre | /usr/bin/omxplayer: line 67: 10115 Killed                  LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                        2|omx_stre | /usr/bin/omxplayer: line 67: 13967 Killed                  LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                        2|omx_stre | process 25324: arguments to dbus_message_new_method_call() were incorrect, assertion "destination == NULL || _dbus_check_is_valid_bus_name (destination)" failed in file ../../../dbus/dbus-message.c line 1370.
                                        2|omx_stre | This is normally a bug in some application using the D-Bus library.
                                        /home/pi/.pm2/logs/server-error.log last 15 lines:
                                        0|server   |     at _handle.lookup (dgram.js:266:18)
                                        0|server   |     at args.(anonymous function) (/usr/lib/node_modules/pm2/node_modules/event-loop-inspector/index.js:138:29)
                                        0|server   |     at process._tickCallback (internal/process/next_tick.js:178:19)
                                        0|server   | Error: bind EADDRNOTAVAIL 10.30.1.223:1905
                                        0|server   |     at state.handle.lookup (dgram.js:242:18)
                                        0|server   |     at process._tickCallback (internal/process/next_tick.js:63:19)
                                        /home/pi/.pm2/logs/server-out.log last 15 lines:
                                        0|server   |         { roomName: 'TV Room', volume: 15 } ],
                                        0|server   |      playMode: { shuffle: true, repeat: 'all', crossfade: false },
                                        0|server   |      pauseOthers: false } }
                                        0|server   | 2019-12-07T19:32:42.519Z INFO http server listening on 0.0.0.0 port 5005
                                        0|server   | 2019-12-07T19:37:02.420Z INFO Could not find file /home/pi/node-sonos-http-api/settings.json
                                        0|server   | 2019-12-07T19:37:03.086Z INFO Presets loaded: { example:
                                        0|server   |    { players:
                                        0|server   |       [ { roomName: 'Bathroom', volume: 10 },
                                        0|server   |         { roomName: 'Kitchen', volume: 10 },
                                        0|server   |         { roomName: 'Office', volume: 10 },
                                        0|server   |         { roomName: 'Bedroom', volume: 10 },
                                        0|server   | 2019-12-07T19:37:07.083Z INFO http server listening on 0.0.0.0 port 5005
                                        1|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:563:3)
                                        1|mm       |     at Module._compile (internal/modules/cjs/loader.js:711:30)
                                        1|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                        1|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32)
                                        1|mm       | { Error: Cannot find module 'node_helper'
                                        1|mm       |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                                        1|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                        1|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                                        1|mm       |     at Module.require (internal/modules/cjs/loader.js:658:17)
                                        1|mm       |     at require (internal/modules/cjs/helpers.js:20:18)
                                        1|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:9:18)
                                        1|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
                                        1|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        1|mm       | Launching application.
                                        1|mm       | Shutting down server...
                                        1|mm       |
                                        1|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
                                        1|mm       | > sh run-start.sh
                                        1|mm       |
                                        1|mm       | Starting MagicMirror: v2.8.0
                                        1|mm       | Loading config ...
                                        1|mm       | Loading module helpers ...
                                        1|mm       | Whoops! There was an uncaught exception...
                                        1|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          Mykle1 Project Sponsor Module Developer @swvalenti
                                          @swvalenti
                                          I updated MMM-EventHorizon and now I get a black screen and server shows errored . . .
                                          If MMM-EventHorizon is the cause simply disable it.
                                          We can troubleshoot in another topic instead of hijacking this one.
                                            sdetweil @swvalenti
                                            @swvalenti said in new update/upgrade script, ready for testing:
                                            looks like the omxplayer task is hung, holding onto ports… reboot time…
                                            • 10
                                            • 16
                                            • 17
                                            • 8 / 17
