Unsolved MMM-MyCommute
pi@raspberrypi3:~ $ pm2 reloadLogs Reloading all logs... All logs reloaded pi@raspberrypi3:~ $ pm2 logs [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option) /home/pi/.pm2/pm2.log last 15 lines: PM2 | [2019-09-07T14:54:18.048Z] PM2 log: pid=17526 msg=failed to kill - retrying in 100ms PM2 | [2019-09-07T14:54:18.145Z] PM2 log: pid=17526 msg=failed to kill - retrying in 100ms PM2 | [2019-09-07T14:54:18.224Z] PM2 log: App [mm] with id [0] and pid [17526], exited with code [0] via signal [SIGINT] PM2 | [2019-09-07T14:54:18.245Z] PM2 log: pid=17526 msg=process killed PM2 | [2019-09-07T14:54:27.372Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0 PM2 | [2019-09-07T14:54:27.383Z] PM2 log: App name:mm id:0 online PM2 | [2019-09-07T15:18:47.949Z] PM2 log: Process 0 in a stopped status, starting it PM2 | [2019-09-07T15:18:47.954Z] PM2 log: Stopping app:mm id:0 PM2 | [2019-09-07T15:18:48.369Z] PM2 log: pid=597 msg=failed to kill - retrying in 100ms PM2 | [2019-09-07T15:18:48.372Z] PM2 log: App [mm] with id [0] and pid [597], exited with code [0] via signal [SIGINT] PM2 | [2019-09-07T15:18:48.469Z] PM2 log: pid=597 msg=process killed PM2 | [2019-09-07T15:18:48.473Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0 PM2 | [2019-09-07T15:18:48.493Z] PM2 log: App name:mm id:0 online PM2 | [2019-09-07T16:10:56.689Z] PM2 log: Reloading logs... PM2 | [2019-09-07T16:10:56.693Z] PM2 log: Reloading logs for process id 0 /home/pi/.pm2/logs/mm-error.log last 15 lines: 0|mm | MESA-LOADER: failed to retrieve device information 0|mm | MESA-LOADER: failed to retrieve device information 0|mm | ATTENTION: default value of option force_s3tc_enable overridden by environment. 0|mm | libGL error: MESA-LOADER: failed to retrieve device information 0|mm | MESA-LOADER: failed to retrieve device information 0|mm | MESA-LOADER: failed to retrieve device information 0|mm | ATTENTION: default value of option force_s3tc_enable overridden by environment. 0|mm | libGL error: MESA-LOADER: failed to retrieve device information 0|mm | MESA-LOADER: failed to retrieve device information 0|mm | MESA-LOADER: failed to retrieve device information 0|mm | ATTENTION: default value of option force_s3tc_enable overridden by environment. 0|mm | libGL error: MESA-LOADER: failed to retrieve device information 0|mm | MESA-LOADER: failed to retrieve device information 0|mm | MESA-LOADER: failed to retrieve device information 0|mm | ATTENTION: default value of option force_s3tc_enable overridden by environment. /home/pi/.pm2/logs/mm-out.log last 15 lines: 0|mm | Connecting socket for: MMM-MyCommute 0|mm | ====================== Starting node_helper for module [MMM-MyCommute] 0|mm | Connecting socket for: MMM-GoogleMapsTraffic 0|mm | Starting node_helper for module: MMM-GoogleMapsTraffic 0|mm | Connecting socket for: MMM-DarkSkyForecast 0|mm | ====================== Starting node_helper for module [MMM-DarkSkyForecast] 0|mm | Connecting socket for: MMM-MyCalendar 0|mm | Starting node helper for: MMM-MyCalendar 0|mm | Sockets connected & modules started ... 0|mm | Launching application. 0|mm | Create new news fetcher for url: https://api.20min.ch/rss/view/1 - Interval: 300000 0|mm | WatchDog started. Maximum timeout: 10s. 0|mm | Create new news fetcher for url: https://api.20min.ch/rss/view/67 - Interval: 300000 0|mm | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: 'standard' } 0|mm | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXXXXX%40gmail.com/private-b6dbd8fd617ffcffc29ab3478af2b6f1/basic.ics - Interval: 300000
@CyruS1337 got to be more than that
Here are the logs from
> magicmirror@2.8.0 start /home/pi/MagicMirror > sh run-start.sh Starting MagicMirror: v2.8.0 Loading config ... Loading module helpers ... No helper found for module: alert. Initializing new module helper ... Module helper loaded: updatenotification Initializing new module helper ... Module helper loaded: MMM-WatchDog Initializing new module helper ... Module helper loaded: MMM-Remote-Control Initializing new module helper ... Module helper loaded: MMM-SystemStats Initializing new module helper ... Module helper loaded: newsfeed Initializing new module helper ... Module helper loaded: MMM-MyCommute Initializing new module helper ... Module helper loaded: MMM-GoogleMapsTraffic Initializing new module helper ... Module helper loaded: MMM-DarkSkyForecast Initializing new module helper ... Module helper loaded: MMM-MyCalendar All module helpers loaded. Starting server on port 8080 ... Server started ... Connecting socket for: updatenotification Connecting socket for: MMM-WatchDog Starting module helper: MMM-WatchDog Connecting socket for: MMM-Remote-Control Starting node helper for: MMM-Remote-Control Connecting socket for: MMM-SystemStats Connecting socket for: newsfeed Starting module: newsfeed Connecting socket for: MMM-MyCommute ====================== Starting node_helper for module [MMM-MyCommute] Connecting socket for: MMM-GoogleMapsTraffic Starting node_helper for module: MMM-GoogleMapsTraffic Connecting socket for: MMM-DarkSkyForecast ====================== Starting node_helper for module [MMM-DarkSkyForecast] Connecting socket for: MMM-MyCalendar Starting node helper for: MMM-MyCalendar Sockets connected & modules started ... Launching application. Create new news fetcher for url: https://api.20min.ch/rss/view/1 - Interval: 300000 WatchDog started. Maximum timeout: 10s. Create new news fetcher for url: https://api.20min.ch/rss/view/67 - Interval: 300000 Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: 'standard' } Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXX%40gmail.com/private-b6dbd8fd617ffcffc29ab3478af2b6f1/basic.ics - Interval: 300000
And here are the logs from
libGL error: MESA-LOADER: failed to retrieve device information MESA-LOADER: failed to retrieve device information MESA-LOADER: failed to retrieve device information libGL error: MESA-LOADER: failed to retrieve device information MESA-LOADER: failed to retrieve device information MESA-LOADER: failed to retrieve device information ATTENTION: default value of option force_s3tc_enable overridden by environment.
I had a similar problem. Just tried out some module configurations and forks.
I now use MMM-GoogleMapsTraffic from here https://github.com/sdetweil/MMM-GoogleMapsTraffic.git (see this thread MMM-GoogleMapsTraffic freezes Magic Mirror)
and MMM-MyCommute from here https://github.com/qistoph/MMM-MyCommute.git
This seems to work for me.
There is also a small error in your configuration. The first destination has a comma after the last configuration endTime. This needs to be removed for a propor JSON file.
Regards Dirk -
So you suggest that I delete the module and download the specified links as “git”?
And sorry for the late reply. Lately there was a lot going on (baby, house building, etc.)
@CyruS1337 there is a bug in the googlemapstraffic module, I have a fixed version… you can rename the current module folder out of the way, and then git clone the fixed one from my repo.
Hi @sdetweil
Mhmmm sorry if I ask so stupid. How do I do that then I download the module from you …
@CyruS1337 https://github.com/sdetweil/MMM-GoogleMapsTraffic.git from the post a few back
Sorry for replying in an old thread, but you wrote apikey in the config, it should be apiKey
