    Problem when installing MagicMirror on Raspbian Buster RPB3+
    26 Posts 4 Posters 13.4k Views 4 Watching
      sdetweil @thomaslc
      @thomaslc said in Problem when installing MagicMirror on Raspbian Buster RPB3+:
      And do you know why the original Magic Mirror link doesnt work ?
      cause it is old, doesn’t handle a bunch of things… which is why I am doing the updated version…
      once tested I will submit mine to replace the one on the MM site
        sdetweil @thomaslc
        @thomaslc thanks for the log… found a bug in the installer on buster… testing fix now
        • T
          thomaslc
          Nice ! Keep me in touch !
            sdetweil @thomaslc
            @thomaslc while I test the installer, u could use the pm2 only script
            see instructions here , fix already added
            https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
            installer also tested and restarts on boot… have to delete the MagicMirror folder again if u go this way
            • T
              thomaslc
              It’s not working :(
              https://ibb.co/4s4GNC2
              I can send you the log if you want :)
                sdetweil @thomaslc
                @thomaslc sure… and the output of
                pm2 logs --lines=100
                my email is the same userid as here on gmail…
                and there is some startup problem… cause pm2 thinks the mirror is running,
                and then u do npm start AGAIN… but you should get output some output…
                B 1 Reply Last reply
                  bobwilliams @sdetweil
                  @sdetweil Yesterday I installed pi 3 B + on the raspberry, it was installed without problems.
                    sdetweil @bobwilliams
                    @bobwilliams thanks… your original problem was with update, which is where i see a problem i need to correct
                      @sdetweil on pi zero also decided … so everything is in order …
                        @bobwilliams yes, install is good… update still has a problem…
                          @sdetweil thank you for your hard work
