    Problem when installing MagicMirror on Raspbian Buster RPB3+
    26 Posts 4 Posters 13.4k Views 4 Watching
      @sdetweil i am building a buster image for myself now
      T 1 Reply Last reply
      • T
        thomaslc @sdetweil
        @sdetweil And do you know why the original Magic Mirror link doesnt work ?
          sdetweil @thomaslc
          @thomaslc said in Problem when installing MagicMirror on Raspbian Buster RPB3+:
          cause it is old, doesn’t handle a bunch of things… which is why I am doing the updated version…
          once tested I will submit mine to replace the one on the MM site
            sdetweil @thomaslc
            @thomaslc thanks for the log… found a bug in the installer on buster… testing fix now
            • T
              thomaslc
              Nice ! Keep me in touch !
                sdetweil @thomaslc
                @thomaslc while I test the installer, u could use the pm2 only script
                see instructions here , fix already added
                https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
                installer also tested and restarts on boot… have to delete the MagicMirror folder again if u go this way
                • T
                  thomaslc
                  It’s not working :(
                  https://ibb.co/4s4GNC2
                  I can send you the log if you want :)
                    sdetweil @thomaslc
                    @thomaslc sure… and the output of
                    pm2 logs --lines=100
                    my email is the same userid as here on gmail…
                    and there is some startup problem… cause pm2 thinks the mirror is running,
                    and then u do npm start AGAIN… but you should get output some output…
                    B 1 Reply Last reply
                      bobwilliams @sdetweil
                      @sdetweil Yesterday I installed pi 3 B + on the raspberry, it was installed without problems.
                        sdetweil @bobwilliams
                        @bobwilliams thanks… your original problem was with update, which is where i see a problem i need to correct
                          @sdetweil on pi zero also decided … so everything is in order …
                            @bobwilliams yes, install is good… update still has a problem…
                              @sdetweil thank you for your hard work
