    Need help with MMM-voice, getting errors
    6 Posts 4 Posters 1.7k Views 3 Watching
      bdream
      Hi bjjsoul,
      please add an comma ‘,’ after the last phrase },
              module: 'MMM-voice',
              position: 'bottom_bar',
                  microphone: 1,
      maybe that help…
      cheers, bdream
      • brobergB Offline
        broberg Project Sponsor @bjjsoul
        @bjjsoul
        Hi, When you are asking for help please don’t make multiple posts about the same issue.
        Secondly, when asking for help with the configuration file we need to see the entire configuration file, just not a single part.
        Many times when you get WARNING! Could not validate config file. there is some symbols missing or added where they are not supposed to be.
        Like a missing { or }
        Like a missing [ or ]
        Like a missing , or " "
        Or maybe you have copied and pasted in a module configuration where it’s not supposed to be.
        bjjsoulB 1 Reply Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @bjjsoul
          @bjjsoul you need to remove the 3 dots from the config. They are only there to show that the module has more config options that would be placed at that position
          • bjjsoulB Offline
            bjjsoul @broberg
            @broberg thanks for your help… but they are differents modules of voice command, check it out and you can see is true .
            i am only trying to install a voice command that works for my magic mirror
            • bjjsoulB Offline
              bjjsoul @strawberry 3.141
              @strawberry-3-141 , thanks i wil try
