    Update to v2.9.0 fail
    48 Posts 3 Posters 22.3k Views 3 Watching
      sdetweil @bdream
      @bdream what a battle!
      in the short term, erase package-lock.json
      also show me output of
      echo $LC_ALL
        bdream
        @sdetweil said in Update to v2.9.0 fail:
        done!
        seems update is working now :grinning_face:
        pi@MagicMirror:~/MagicMirror $ bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
        doing test run = false
        saving custom.css
        upgrading from version 2.8.0 to 2.9.0
        fetching latest revisions
        > electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
        > node install.js
        Downloading tmp-5207-1-SHASUMS256.txt-3.0.13
        [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
        > magicmirror@2.9.0 install /home/pi/MagicMirror
        > cd vendor && npm install
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        audited 220 packages in 12.241s
        found 5 vulnerabilities (4 low, 1 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
        > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
        We'll remove from the repository the css/custom.css
        This script apply git update-index --skip-worktree css/custom.css
        rm 'css/custom.css'
        MagicMirror installation successful!
        > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
        > cd fonts && npm install
        audited 1 package in 1.629s
        found 0 vulnerabilities
        npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
        added 173 packages from 113 contributors, removed 132 packages, updated 181 packages, moved 1 package and audited 3475 packages in 1071.546s
        found 28 vulnerabilities (1 low, 1 moderate, 26 high)
        processing for module MMM-Carousel please wait
        audited 859 packages in 17.666s
        found 2 high severity vulnerabilities
        processing complete for module MMM-Carousel
        processing for module MMM-PublicTransportHafas please wait
        audited 41 packages in 2.153s
        processing complete for module MMM-PublicTransportHafas
        audited 41 packages in 3.251s
        audited 41 packages in 3.956s
        restoring custom.css
          pm2 start mm
        …and it looks GOOD! :rolling_on_the_floor_laughing:
        It’s great after such a … work? … getting it solved.
        Thank you sooo much. On my own I would install from scatch :frowning_face: and this is nothing I can bring to my family.
        and here you asked
        pi@MagicMirror:~/MagicMirror $  echo $LC_ALL
        de_DE.UTF-8
        would say this is one of the first thing I do installing Raspian :grimacing_face:
        cheers, bdream
          sdetweil @bdream
          @bdream said in Update to v2.9.0 fail:
          de_DE.UTF-8
          bingo… things you learn!..
          LC_ALL overrides LANG or LANGUAGE=
          I just have to fix my alias…
          would u be willing to test the fix… no changes to your local running system
          package-lock.json should exist
          ls package-lock.json
          then
          bash -c "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
          when u see the message about saving files, just hit ctrl-c to exit
            bdream
            I was to slow for hitting ctrl-c :nerd_face:
            As this is a huge of lines my buffer is to small.
            Is there a log or is there no interest to u of the outcome?
            cheers, bdream
              sdetweil @bdream
              @bdream yes the install.log
              but it should have waited for you to reply about writing over package-lock.json
              hm… if package.lock.json does NOT exist
              then create it
              touch package-lock.json
                bdream
                nono, it did exist
                pi@MagicMirror:~/MagicMirror $  ls pack*
                package.json  package-lock.json
                but the script run fast
                what path I can find the install.log?
                cheers, bdream
                  sdetweil @bdream
                  @bdream sorry, not install… upgrade.log
                  on the package-lock.json… it is the same as the update… thus why it didn’t stop
                  could edit it an add a space someplace
                    bdream
                    @sdetweil upgrade.log is here from …force… no it isn’t.
                    I can’t copy the 2738 lines in here.
                    How can I bring it to you?
                    And what does this mean?
                    cheers, bdream
                      sdetweil @bdream
                      you can email it , same userid as here on gmail
                      the upgrade should have stopped at the package-lock.json file, just like before…
                      but it didn’t… so I looked back at the 2.9.0 package being installed, and it has a package-lock.json file…
                      so, the one now on the disk is the new one… and a git status will show it hasn’t changed…
                      so, we could MAKE it be different, by using a text editor (like the one you use on the config.js file)
                      and add 1 space character (hit the spacebar)
                      and then save it… then it will be different
                        bdream
                        got u mail from me? I would send you logs then.
                        Is this you ask me to do? and rund your script again to see if it works now?
                        cheers, bdream
                          sdetweil @bdream
                          @bdream i got one mail and replied. have not got any more
                          yes, was a way to test. if u can
                            bdream
                            if u can
                            Got it
                            Upgrade started - Mi Okt 16 20:03:22 CEST 2019
                            user requested to apply changes
                            saving custom.css
                            not english or locale not set, set git alias
                            alias egrep='egrep --color=auto'
                            alias fgrep='fgrep --color=auto'
                            alias git='LC_ALL=en_US.UTF-8 git'
                            alias grep='grep --color=auto'
                            alias ls='ls --color=auto'
                            remote name = origin
                            local version 2.9.0 already same as master 2.9.0
                            removing git alias
                            Upgrade ended - Mi Okt 16 20:03:22 CEST 2019
                            there is no statement about the package-lock.json where I added spaces and saved it.
                            Seems it works fine :grinning_face_with_smiling_eyes:
                            One question I have now.
                            Would it make sense changing the guide for update MM using your script instead of git pull && npm install?
                            Or is this only a option in case of failure?
                            cheers, bdream
                              sdetweil @bdream
                              if you do apply, then if the versions are the same, it just exits… if you use force then it keeps going…
                              try with force instead of apply
                              … once we get this tested I will submit to add to the product… u are helping me test… and I thank you very much!!
                              i have 3 scripts.
                              1 updated installer
                              2 new updater
                              3 one for fixing pm2 without having to do installer
                              will submit them all
                                bdream
                                Interesting. Now I get 2 package-lock.json listed…
                                pi@MagicMirror:~/MagicMirror $  bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                                saving custom.css
                                upgrading from version 2.9.0 to 2.9.0
                                there are 2 local files that are different than the master repo
                                   package-lock.json
                                   vendor/package-lock.json
                                any *-lock.json files do not need to be saved
                                do you want to save these files for later   (Y/n)?y
                                git: 'git_user_name' ist kein Git-Befehl. Siehe 'git --help'.
                                audited 220 packages in 23.225s
                                audited 1 package in 0.999s
                                npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                                audited 3475 packages in 88.305s
                                audited 859 packages in 16.958s
                                audited 41 packages in 2.814s
                                audited 41 packages in 3.741s
                                audited 41 packages in 3.333s
                                we stashed a set of files that appear changed from the latest repo versions. you should review them
                                Keine Stash-Einträge gefunden.
                                see installers/stashed_files for the list
                                you can use git checkout stash@{0} -- filename to extract one file from the stash
                                or git stash pop to restore them all
                                WARNING..
                                WARNING.. either will overlay the file just installed by the update
                                WARNING..
                                and the log:
                                Upgrade started - Mi Okt 16 20:15:10 CEST 2019
                                user requested to force apply changes
                                saving custom.css
                                current branch = master
                                Auf Branch master
                                Ihr Branch ist auf demselben Stand wie 'origin/master'.
                                Zum Commit vorgemerkte Änderungen:
                                  (benutzen Sie "git reset HEAD <Datei>..." zum Entfernen aus der Staging-Area)
                                	gelöscht:       css/custom.css
                                Änderungen, die nicht zum Commit vorgemerkt sind:
                                  (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                                  (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                                	geändert:       package-lock.json
                                	geändert:       vendor/package-lock.json
                                Unversionierte Dateien:
                                	%logfile
                                	core
                                	css/save_custom.css
                                	installers/dumpactivemodules.js
                                	installers/pm2_MagicMirror_new.json
                                	mm.sh
                                	nohup.out
                                   package-lock.json
                                save/restore files selection = y
                                test merge result rc='' , if empty, no conflicts
                                executing merge, apply specified
                                merge result rc= 0
                                 Already up to date.
                                processor architecture is armv7l
                                removing git alias
                                Upgrade ended - Mi Okt 16 20:17:37 CEST 2019
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream cool… don’t know why we got the german there… issued same command back to back, one to log, one to script…
                                  log one came out in german
                                  script one came out in english
                                  fixed a bug, which should have said
                                  any *-lock.json files do not need to be saved"
                                  that is all u had, so you would have selected n, instead of y
                                    bdream
                                    Sorry, is this I have to run script again and select n instead of yes?
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream if you have edited the package-lock.json file
                                        bdream
                                        reedited and run script
                                        saving custom.css
                                           package-lock.json
                                        do you want to save these files for later   (Y/n)?n
                                        audited 220 packages in 13.98s
                                        audited 1 package in 1.385s
                                        updated 1 package and audited 3475 packages in 106.649s
                                        audited 859 packages in 13.644s
                                        audited 41 packages in 3.408s
                                        audited 41 packages in 2.67s
                                        audited 41 packages in 3.904s
                                        upgrade.log
                                        Upgrade started - Mi Okt 16 22:11:36 CEST 2019
                                        saving custom.css
                                        Auf Branch master
                                        	%logfile
                                        	core
                                        	css/save_custom.css
                                        	installers/upgrade.log.bak2
                                        	mm.sh
                                        	nohup.out
                                           package-lock.json
                                        save/restore files selection = n
                                        restoring package-lock.json from repo
                                        restoring vendor/package-lock.json from repo
                                        merge result rc= 0
                                         Already up to date.
                                        removing git alias
                                        Upgrade ended - Mi Okt 16 22:14:11 CEST 2019
                                        do I need to akt in any way here or other point?
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream thank you for your help and patience… all looks great!!
                                          no, you do not need to do anything about the last two entries.
                                            bdream
                                            so we are done and I set post to solved.
                                            Many thanks for your great help and patience with this newbe-stuff :smiling_face_with_sunglasses:
                                            cheers, bdream
                                            • 2 / 3
