    Update to v2.9.0 fail
    48 Posts 3 Posters 21.6k Views 3 Watching
      sdetweil @bdream
      @bdream said in Update to v2.9.0 fail:
      pi@MagicMirror:~/MagicMirror $ echo $LC_ALL
      de_DE.UTF-8
      bingo… things you learn!..
      LC_ALL overrides LANG or LANGUAGE=
      I just have to fix my alias…
      would u be willing to test the fix… no changes to your local running system
      package-lock.json should exist
      ls package-lock.json
      then
      bash -c "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
      when u see the message about saving files, just hit ctrl-c to exit
        bdream
        @sdetweil said in Update to v2.9.0 fail:
        I was to slow for hitting ctrl-c :nerd_face:
        As this is a huge of lines my buffer is to small.
        Is there a log or is there no interest to u of the outcome?
        cheers, bdream
          sdetweil @bdream
          @bdream yes the install.log
          but it should have waited for you to reply about writing over package-lock.json
          hm… if package.lock.json does NOT exist
          then create it
          touch package-lock.json
            bdream
            nono, it did exist
            pi@MagicMirror:~/MagicMirror $  ls pack*
            package.json  package-lock.json
            but the script run fast
            what path I can find the install.log?
            cheers, bdream
              sdetweil @bdream
              @bdream sorry, not install… upgrade.log
              doing test run = false
              on the package-lock.json… it is the same as the update… thus why it didn’t stop
              could edit it an add a space someplace
                bdream
                @sdetweil upgrade.log is here from …force… no it isn’t.
                I can’t copy the 2738 lines in here.
                How can I bring it to you?
                And what does this mean?
                cheers, bdream
                  sdetweil @bdream
                  you can email it , same userid as here on gmail
                  the upgrade should have stopped at the package-lock.json file, just like before…
                  but it didn’t… so I looked back at the 2.9.0 package being installed, and it has a package-lock.json file…
                  so, the one now on the disk is the new one… and a git status will show it hasn’t changed…
                  so, we could MAKE it be different, by using a text editor (like the one you use on the config.js file)
                  and add 1 space character (hit the spacebar)
                  and then save it… then it will be different
                    bdream
                    got u mail from me? I would send you logs then.
                    Is this you ask me to do? and rund your script again to see if it works now?
                    cheers, bdream
                      sdetweil @bdream
                      @bdream i got one mail and replied. have not got any more
                      yes, was a way to test. if u can
                        bdream
                        if u can
                        Got it
                        Upgrade started - Mi Okt 16 20:03:22 CEST 2019
                        user requested to apply changes
                        saving custom.css
                        not english or locale not set, set git alias
                        alias egrep='egrep --color=auto'
                        alias fgrep='fgrep --color=auto'
                        alias git='LC_ALL=en_US.UTF-8 git'
                        alias grep='grep --color=auto'
                        alias ls='ls --color=auto'
                        remote name = origin
                        local version 2.9.0 already same as master 2.9.0
                        restoring custom.css
                        removing git alias
                        Upgrade ended - Mi Okt 16 20:03:22 CEST 2019
                        there is no statement about the package-lock.json where I added spaces and saved it.
                        Seems it works fine :grinning_face_with_smiling_eyes:
                        One question I have now.
                        Would it make sense changing the guide for update MM using your script instead of git pull && npm install?
                        Or is this only a option in case of failure?
                        cheers, bdream
                          sdetweil @bdream
                          if you do apply, then if the versions are the same, it just exits… if you use force then it keeps going…
                          try with force instead of apply
                          … once we get this tested I will submit to add to the product… u are helping me test… and I thank you very much!!
                          i have 3 scripts.
                          1 updated installer
                          2 new updater
                          3 one for fixing pm2 without having to do installer
                          will submit them all
                            bdream
                            Interesting. Now I get 2 package-lock.json listed…
                            pi@MagicMirror:~/MagicMirror $  bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                            saving custom.css
                            upgrading from version 2.9.0 to 2.9.0
                            fetching latest revisions
                            there are 2 local files that are different than the master repo
                               package-lock.json
                               vendor/package-lock.json
                            any *-lock.json files do not need to be saved
                            do you want to save these files for later   (Y/n)?y
                            git: 'git_user_name' ist kein Git-Befehl. Siehe 'git --help'.
                            > magicmirror@2.9.0 install /home/pi/MagicMirror
                            > cd vendor && npm install
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            audited 220 packages in 23.225s
                            found 5 vulnerabilities (4 low, 1 high)
                              run `npm audit fix` to fix them, or `npm audit` for details
                            > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                            > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                            MagicMirror installation successful!
                            > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                            > cd fonts && npm install
                            audited 1 package in 0.999s
                            found 0 vulnerabilities
                            npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                            npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                            audited 3475 packages in 88.305s
                            found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                            processing for module MMM-Carousel please wait
                            audited 859 packages in 16.958s
                            found 2 high severity vulnerabilities
                            processing complete for module MMM-Carousel
                            processing for module MMM-PublicTransportHafas please wait
                            audited 41 packages in 2.814s
                            processing complete for module MMM-PublicTransportHafas
                            audited 41 packages in 3.741s
                            audited 41 packages in 3.333s
                            we stashed a set of files that appear changed from the latest repo versions. you should review them
                            Keine Stash-Einträge gefunden.
                            see installers/stashed_files for the list
                            you can use git checkout stash@{0} -- filename to extract one file from the stash
                            or git stash pop to restore them all
                            WARNING..
                            WARNING.. either will overlay the file just installed by the update
                            WARNING..
                            and the log:
                            Upgrade started - Mi Okt 16 20:15:10 CEST 2019
                            user requested to force apply changes
                            saving custom.css
                            current branch = master
                            Auf Branch master
                            Ihr Branch ist auf demselben Stand wie 'origin/master'.
                            Zum Commit vorgemerkte Änderungen:
                              (benutzen Sie "git reset HEAD <Datei>..." zum Entfernen aus der Staging-Area)
                            	gelöscht:       css/custom.css
                            Änderungen, die nicht zum Commit vorgemerkt sind:
                              (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                              (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                            	geändert:       package-lock.json
                            	geändert:       vendor/package-lock.json
                            Unversionierte Dateien:
                            	%logfile
                            	core
                            	css/save_custom.css
                            	installers/dumpactivemodules.js
                            	installers/pm2_MagicMirror_new.json
                            	mm.sh
                            	nohup.out
                               package-lock.json
                            save/restore files selection = y
                            test merge result rc='' , if empty, no conflicts
                            executing merge, apply specified
                            merge result rc= 0
                             Already up to date.
                            processor architecture is armv7l
                            removing git alias
                            Upgrade ended - Mi Okt 16 20:17:37 CEST 2019
                            cheers, bdream
                              sdetweil @bdream
                              @bdream cool… don’t know why we got the german there… issued same command back to back, one to log, one to script…
                              log one came out in german
                              script one came out in english
                              fixed a bug, which should have said
                              any *-lock.json files do not need to be saved"
                              that is all u had, so you would have selected n, instead of y
                                bdream
                                Sorry, is this I have to run script again and select n instead of yes?
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream if you have edited the package-lock.json file
                                    bdream
                                    reedited and run script
                                    saving custom.css
                                       package-lock.json
                                    do you want to save these files for later   (Y/n)?n
                                    audited 220 packages in 13.98s
                                    audited 1 package in 1.385s
                                    updated 1 package and audited 3475 packages in 106.649s
                                    audited 859 packages in 13.644s
                                    audited 41 packages in 3.408s
                                    audited 41 packages in 2.67s
                                    audited 41 packages in 3.904s
                                    upgrade.log
                                    Upgrade started - Mi Okt 16 22:11:36 CEST 2019
                                    saving custom.css
                                    Auf Branch master
                                    	%logfile
                                    	core
                                    	css/save_custom.css
                                    	installers/upgrade.log.bak2
                                    	mm.sh
                                    	nohup.out
                                       package-lock.json
                                    save/restore files selection = n
                                    restoring package-lock.json from repo
                                    restoring vendor/package-lock.json from repo
                                    merge result rc= 0
                                     Already up to date.
                                    removing git alias
                                    Upgrade ended - Mi Okt 16 22:14:11 CEST 2019
                                    do I need to akt in any way here or other point?
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream thank you for your help and patience… all looks great!!
                                      no, you do not need to do anything about the last two entries.
                                        bdream
                                        so we are done and I set post to solved.
                                        Many thanks for your great help and patience with this newbe-stuff :smiling_face_with_sunglasses:
                                        cheers, bdream
                                          sdetweil @bdream
                                          you are welcome… and why I want to make these scripts solid
                                          • F Offline
                                            fiaskogaul
                                            Is the Link dead? I get 404 or when I execute the script “Syntaxfehler beim unerwarteten Wort `newline’”
                                            • 2 / 3
