Need help for last two problems.
4 Posts 2 Posters 1.0k Views 2 Watching
  • T Offline
    TimGV
    The Weather forecaster after update stopped showing the day for the forecast.
    SmartWebDisplay i have set for middle_center and I would like to lower the complete display about an inch. I want to use all of my screen. I believe the settings would go into the custom.css file but I can not figure out the exact command.
    I was going to upload a picture but can not figure it out.
    Thanks for any help. Tim
      BKeyport Module Developer
      I gave up on the default modules except for the clock - I use MMM-DarkSkyForecast
      This is what I use to maximize the entire display edge to edge. (It works, but it’s technically incorrect)
      Custom.css
      /* maximize screen usage for MagicMirror. */
       body {
        margin: 4px;
        height: calc(100vh - 10px);
        width: calc(100vw - 5px);
      If you want a particular module to take the entire screen, you could use ‘fullscreen_below’ as the position.
      • T Offline
        TimGV
        I have my screen set up so it does full width but what I would like to do is to drop the middle_center down one inch. Once I can do this all my modules line up good.
        Thanks for your help. Tim
        • T Offline
          TimGV
          I figured out how to change the position of my center_middle. I went to the main.css file and changed the following lines. The -50% I changed to -62%. This number was selected by trial and error. Now my middle section is spaced exactly the same on the top and bottom.
          .region.middle.center {
            width: 100%;
            text-align: center;
            -moz-transform: translateY(-62%);
            -o-transform: translateY(-62%);
            -webkit-transform: translateY(-62%);
            -ms-transform: translateY(-62%);
            top: 62%;
