    Need help for last two problems.
    4 Posts 2 Posters 1.1k Views 2 Watching
    • T Offline
      TimGV
      The Weather forecaster after update stopped showing the day for the forecast.
      SmartWebDisplay i have set for middle_center and I would like to lower the complete display about an inch. I want to use all of my screen. I believe the settings would go into the custom.css file but I can not figure out the exact command.
      I was going to upload a picture but can not figure it out.
      Thanks for any help. Tim
      • BKeyportB Offline
        BKeyport Module Developer
        I gave up on the default modules except for the clock - I use MMM-DarkSkyForecast
        This is what I use to maximize the entire display edge to edge. (It works, but it’s technically incorrect)
        Custom.css
        /* maximize screen usage for MagicMirror. */
         body {
          margin: 4px;
          height: calc(100vh - 10px);
          width: calc(100vw - 5px);
        If you want a particular module to take the entire screen, you could use ‘fullscreen_below’ as the position.
        • T Offline
          TimGV
          I have my screen set up so it does full width but what I would like to do is to drop the middle_center down one inch. Once I can do this all my modules line up good.
          Thanks for your help. Tim
          • T Offline
            TimGV
            I figured out how to change the position of my center_middle. I went to the main.css file and changed the following lines. The -50% I changed to -62%. This number was selected by trial and error. Now my middle section is spaced exactly the same on the top and bottom.
            .region.middle.center {
              width: 100%;
              text-align: center;
              -moz-transform: translateY(-62%);
              -o-transform: translateY(-62%);
              -webkit-transform: translateY(-62%);
              -ms-transform: translateY(-62%);
              top: 62%;
