    Conflict between GoogleMapsTraffic and WeatherBackground?
    6 Posts 3 Posters 1.6k Views 3 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @jungo
      @jungo I never used the carousel, but from just reading the config I think it works differently than you expected.
      MMM-WeatherBackground doesn’t have a position, it doesn’t get rendered through the MM² framework. Therefore it shouldn’t have a carouselId. Not sure why you exclude ignoreModules: ['alert', 'MMM-WeatherBackground'], in the first place when you then specify an id.
      From looking into the google maps source code it looks like there might be something breaking the code for the other modules. Can you inspect the console (start the mirror with npm start dev or press ctrl+shift+i). Can you see errors? Something like console.log is not a function?
        there is a bug in GoogleMapsTraffic…
        I have a fix, and have submitted it back
        please use my repo
        rename the existing folder out of the way
        then git clone my repo
        https://github.com/sdetweil/MMM-GoogleMapsTraffic
          strawberry 3.141 Project Sponsor Module Developer @sdetweil
          @sdetweil your fork still contains the bug https://github.com/vicmora/MMM-GoogleMapsTraffic/pull/24/files
            sdetweil @strawberry 3.141
            @strawberry-3-141 thanks… that one didn’t seem to be the problem… fixed it now in my repo too
              jungo @strawberry 3.141
              @strawberry-3-141 Thanks for taking a look. The ignoreModules section was a holdover from one of the eleventeen-thousand configurations I tried thinking I was missing something
              @sdetweil It works as advertised.
              Thanks to both of you for the quick help.
