    Missing Club Logos in MMM-Soccer
    14 Posts 4 Posters 5.0k Views 3 Watching
      the code does NOT look in the public folder, from the njk file
      /MMM-soccer/{{standing[index].team.name}}.svg
      or
      /MMM-soccer/{{entry.team.name}}.svg
      might want to edit the njk, and change those to
      /MMM-soccer/public/
      also, many of your files are
      this is svg
      FCSchalke04.svg
      but I don’t think ‘FCSchalke04’ is the team name
      • T Offline
        tino
        ok, i have now added the /public to the path like this src=“/MMM-soccer/public/{{standing[index].team.name}}.svg”
        The install discription says : “the logos need to be in svg format and the name of the file has to match the displayed name.”
        I my case f.e. now FC Schalke 04.svg . The displayed name is “FC Schalke 04”
        pi@raspberrypi:~/MagicMirror/modules/MMM-soccer/public $ ls
        ‘BV Borussia 09 Dortmund.svg’ ‘SC Freiburg.svg’
        ‘FC Schalke 04.svg’ SC_Paderborn_07_Logo.svg
        ‘Hertha BSC.svg’
        same result …strange
          sdetweil @tino
          @tino if you open the developers window, ctrl-shift-i, and select the tab labeled console, and scroll up,
          maybe put ‘soccer’ (no quotes) in the filter field to just see messages from one module, you should see the errors from loading some url…
          • T Offline
            tino
            You made my day!!
            THX for your tip with the Debug console.
            System could not find the path to the public folder.
            false: src=“/MMM-soccer/public/{{standing[index].team.name}}.svg”
            right: src=“/modules/MMM-soccer/public/{{standing[index].team.name}}.svg”
            now it works perfect …thumbs up
              sdetweil @tino
              @tino woohoo!
              Glad u solved it!
                ambujsethi @sdetweil
                @sdetweil I’m having the same issue but I don’t understand what you mean by the developers window here. What is that, exactly?
                Thanks.
                  sdetweil @ambujsethi
                  @ambujsethi on the mirror screen, press ctrl-shift-i. This will split screen with the developers window on the right side
                  you can also open the developers window with npm start dev (as long as u stopped the pm instance)
                    @sdetweil Thank you! I’ll try it out and hopefully solve the issue. :)
                      @ambujsethi i think we have the resolution… edit the module njk file and fix the paths to the images
                      from
                      /MMM-Soccer
                      to
                      /modules/MMM-Soccer/public
