    Missing Club Logos in MMM-Soccer
    14 Posts 4 Posters 6.0k Views 3 Watching
    • brobergB
      broberg Project Sponsor @tino
      @tino
      Have you run the downloader that is mentioned in the modules readme?
      Logos
      As the v2 api doesn't provide logos anymore, I developed a club logo downloader. It supports the five major leagues as above named. To run the downloader you need to execute the following steps.
          Go to the module directory cd ~/MagicMirror/modules/MMM-soccer.
          Execute node scripts/downloader COUNTRYNAME.
          Run this command for all the leagues you want to display on the mirror.
          Don't forget to activate the display of the logos in the config.
      If there isn't every club logo, you can also place them manually in the public directory of the module, the logos need to be in svg format and the name of the file has to match the displayed name.
      • T
        tino
        @broberg said in Missing Club Logos:
        Hi broberg,
        thx for your fast reply. yes, i’ve tried it serveral times to execute your script to get the logos.
        pi@raspberrypi:~/MagicMirror/modules/MMM-soccer $ node scripts/downloader GERMANY
        same result.
        i also placed some manually downloaded logos in SVG format into the public folder
        pi@raspberrypi:~/MagicMirror/modules/MMM-soccer/public $ ls
        25px-1.FC_Union_Berlin_1966-_1990.gif ‘Hertha BSC.svg’
        ‘BV Borussia 09 Dortmund.svg’ SC_Freiburg.svg
        FCSchalke04.svg
        same result.
        To activate the logos i use the “logos: true,” . This should be correct , or?
          sdetweil @tino
          @tino said in Missing Club Logos in MMM-Soccer:
          “logos: true,”
          try
          “logos”: true,
          • T
            tino
            also “logos”: true, will not show the logos.
              the code does NOT look in the public folder, from the njk file
              /MMM-soccer/{{standing[index].team.name}}.svg
              or
              /MMM-soccer/{{entry.team.name}}.svg
              might want to edit the njk, and change those to
              /MMM-soccer/public/
              also, many of your files are
              this is svg
              FCSchalke04.svg
              but I don’t think ‘FCSchalke04’ is the team name
              • T
                tino
                ok, i have now added the /public to the path like this src=“/MMM-soccer/public/{{standing[index].team.name}}.svg”
                The install discription says : “the logos need to be in svg format and the name of the file has to match the displayed name.”
                I my case f.e. now FC Schalke 04.svg . The displayed name is “FC Schalke 04”
                ‘BV Borussia 09 Dortmund.svg’ ‘SC Freiburg.svg’
                ‘FC Schalke 04.svg’ SC_Paderborn_07_Logo.svg
                ‘Hertha BSC.svg’
                same result …strange
                  sdetweil @tino
                  @tino if you open the developers window, ctrl-shift-i, and select the tab labeled console, and scroll up,
                  maybe put ‘soccer’ (no quotes) in the filter field to just see messages from one module, you should see the errors from loading some url…
                  A 1 Reply Last reply
                  • T
                    tino
                    You made my day!!
                    THX for your tip with the Debug console.
                    System could not find the path to the public folder.
                    false: src=“/MMM-soccer/public/{{standing[index].team.name}}.svg”
                    right: src=“/modules/MMM-soccer/public/{{standing[index].team.name}}.svg”
                    now it works perfect …thumbs up
                      sdetweil @tino
                      @tino woohoo!
                      Glad u solved it!
                      • A
                        ambujsethi @sdetweil
                        @sdetweil I’m having the same issue but I don’t understand what you mean by the developers window here. What is that, exactly?
                        Thanks.
                          sdetweil @ambujsethi
                          @ambujsethi on the mirror screen, press ctrl-shift-i. This will split screen with the developers window on the right side
                          you can also open the developers window with npm start dev (as long as u stopped the pm instance)
                          • A
                            @sdetweil Thank you! I’ll try it out and hopefully solve the issue. :)
                              @ambujsethi i think we have the resolution… edit the module njk file and fix the paths to the images
                              from
                              /MMM-Soccer
                              to
                              /modules/MMM-Soccer/public
