    Missing Club Logos in MMM-Soccer
    14 Posts 4 Posters 5.0k Views 3 Watching
    • T Offline
      tino
      @broberg said in Missing Club Logos:
      Execute node scripts/downloader COUNTRYNAME
      Hi broberg,
      thx for your fast reply. yes, i’ve tried it serveral times to execute your script to get the logos.
      pi@raspberrypi:~/MagicMirror/modules/MMM-soccer $ node scripts/downloader GERMANY
      same result.
      i also placed some manually downloaded logos in SVG format into the public folder
      pi@raspberrypi:~/MagicMirror/modules/MMM-soccer/public $ ls
      25px-1.FC_Union_Berlin_1966-_1990.gif ‘Hertha BSC.svg’
      ‘BV Borussia 09 Dortmund.svg’ SC_Freiburg.svg
      FCSchalke04.svg
      same result.
      To activate the logos i use the “logos: true,” . This should be correct , or?
        sdetweil @tino
        @tino said in Missing Club Logos in MMM-Soccer:
        “logos: true,”
        try
        “logos”: true,
        • T Offline
          tino
          also “logos”: true, will not show the logos.
            the code does NOT look in the public folder, from the njk file
            /MMM-soccer/{{standing[index].team.name}}.svg
            or
            /MMM-soccer/{{entry.team.name}}.svg
            might want to edit the njk, and change those to
            /MMM-soccer/public/
            also, many of your files are
            this is svg
            FCSchalke04.svg
            but I don’t think ‘FCSchalke04’ is the team name
            • T Offline
              tino
              ok, i have now added the /public to the path like this src=“/MMM-soccer/public/{{standing[index].team.name}}.svg”
              The install discription says : “the logos need to be in svg format and the name of the file has to match the displayed name.”
              I my case f.e. now FC Schalke 04.svg . The displayed name is “FC Schalke 04”
              ‘BV Borussia 09 Dortmund.svg’ ‘SC Freiburg.svg’
              ‘FC Schalke 04.svg’ SC_Paderborn_07_Logo.svg
              ‘Hertha BSC.svg’
              same result …strange
                sdetweil @tino
                @tino if you open the developers window, ctrl-shift-i, and select the tab labeled console, and scroll up,
                maybe put ‘soccer’ (no quotes) in the filter field to just see messages from one module, you should see the errors from loading some url…
                • T Offline
                  tino
                  You made my day!!
                  THX for your tip with the Debug console.
                  System could not find the path to the public folder.
                  false: src=“/MMM-soccer/public/{{standing[index].team.name}}.svg”
                  right: src=“/modules/MMM-soccer/public/{{standing[index].team.name}}.svg”
                  now it works perfect …thumbs up
                    sdetweil @tino
                    @tino woohoo!
                    Glad u solved it!
                      ambujsethi @sdetweil
                      @sdetweil I’m having the same issue but I don’t understand what you mean by the developers window here. What is that, exactly?
                      Thanks.
                        sdetweil @ambujsethi
                        @ambujsethi on the mirror screen, press ctrl-shift-i. This will split screen with the developers window on the right side
                        you can also open the developers window with npm start dev (as long as u stopped the pm instance)
