MMM-Facial-Recognition
31 Posts 2 Posters 10.9k Views 2 Watching
    Buncie
    Whenever I try loading the magic mirror, it keeps showing a black screen. I’m using a Logitech Camera C270. I did make useUsb = true. Could there be something I missed?
    S 1 Reply Last reply Oct 24, 2019, 4:38 PM Reply Quote 0
    • S Away
      sdetweil @Buncie
      @Buncie open the developers window ctrl-shift-i, then select the console tab and scroll up to see any errors.
      You can put a word in the filter field to limit messages to a specific module
      Facial for you ( not case sensitive)
        Buncie
        Where would I open the developers window. Im connected to the pi using Mac command line ssh if that helps.
        S 1 Reply Last reply Oct 24, 2019, 5:12 PM Reply Quote 0
        • S Away
          sdetweil @Buncie
          @Buncie u have to do it on the mirror screen
            Buncie
            [0_1571938086869_AF1QipMMEwZBijpc66gjmdGmou7LnGLnF-qIh0I9nhBU.html](Uploading 100%) It’s giving an error message about the example_module.
            S 1 Reply Last reply Oct 24, 2019, 5:41 PM Reply Quote 0
            • S Away
              sdetweil @Buncie
              @Buncie sorry, not quite sure I understand. Your image did not display.
              UseUsb??? We don’t have that in MagicMirror, unless it is a module
              Also, example module?
                Buncie
                The title, MMM-Facial-Recongnition, is the module I’m having issue with.
                https://github.com/paviro/MMM-Facial-Recognition![0_1571939212539_675ae4b6-638c-4e26-bad1-fcc2aeb98e1a-image.png](/assets/uploads/files/1571939212802-675ae4b6-638c-4e26-bad1-fcc2aeb98e1a-image.png)
                https://photos.google.com/share/AF1QipMuv9hNbRVSByJFSfhnhDa2a6Rf_fe7nGFPtInNnsAPE7uQ9CWc07MknObyU_nUqQ?key=WmU4d0VXQmhSLUZ3Z0t2aXVKbzRqeHhrRnlGNmhn
                S 1 Reply Last reply Oct 24, 2019, 5:52 PM Reply Quote 0
                • S Away
                  sdetweil @Buncie
                  @Buncie ah. The facial module executes a script when it detects a face… sounds like u have more config work to do
                    Buncie
                    Is there anyway to change that. All I want is to make it show the camera and when you step in front of it, a box will appear around your face and it will show your name. Here is the config file for the magic mirror so far.
                    https://photos.google.com/share/AF1QipMBomD6bUWkKLSLd51oXRsYx766DFKdZYNFbn7gHo9iK2OBuMQ1yA2blZ25nfAXIQ?key=OUZ5MkhDVndtMzdPcmdWODBRVlFqX0pNTk5GLUFR
                    S 1 Reply Last reply Oct 24, 2019, 5:58 PM Reply Quote 0
                    • S Away
                      sdetweil @Buncie
                      @Buncie sorry, I don’t know anything about the module. Maybe another user or the author will come by and be able to help.
                      • 1 / 4
                      1 / 4
