Error when trying to run MMM-AssistantMk2
10 Posts 5 Posters 3.4k Views 5 Watching
  • I Offline
    INMD1
    [AMK2] assistant ready
    /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
    npm ERR! code ELIFECYCLE
    npm ERR! syscall spawn
    npm ERR! file sh
    npm ERR! errno ENOENT
    npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
    npm ERR! spawn ENOENT
    npm ERR!
    npm ERR! Failed at the magicmirror@2.9.0 start script.
    npm ERR!     /home/pi/.npm/_logs/2019-10-24T05_25_04_096Z-debug.log
    I am trying to install mmm-hotword, MMM-AssistantMk2 to make Magic Mirror today, but I am having an error. What’s the cause?
    S 1 Reply Last reply Oct 24, 2019, 11:31 AM Reply Quote 0
      sdetweil @INMD1
      @INMD1 you need to follow the rest of the installation steps, which cover errors like this,
      • W Offline
        waseemghaly
        @sdetweil I have followed all the steps in the installation guide and still getting the same error as @INMD1 please let me know if there is a certain set of instructions that needs to be followed. Thank you
        S 1 Reply Last reply Oct 25, 2019, 10:15 AM Reply Quote 0
          sdetweil @waseemghaly
          @waseemghaly @INMD1 we will neeed to wait for @Sean to help, he is the module author
            A Former User
            Well. I’m not sure because, someone still has this issue despite my instruction in github. But I tested and got success today. So I hope this working for you.
            Reason
            • grpc(which is an essential program to use Google Assistant SDK) installed by npm install in the shell is not compatible with electron of MagicMirror on runtime. Because electron has its own JS engine and it is different with your global level environments. That is why rebuild of grpc for electron is needed.
            • Unfortunately, some last newgrpc versions might have some bug on rebuilding for specific electron. As far as I know, grpc@1.24.0 has one, and grpc@1.24.1 has also (grpc team says it was fixed, but I found another bug on 1.24.1)
            Solution
            In Raspbian Buster / RPI 4B+ I’ve tested.
            1. Check your gcc version. If > = 8, downgrade it to 7.
            sudo apt-get install gcc-7
            gcc -v
            It should say gcc version 7.3.0 (Raspbian 7.30-19) or something similar ( < = 7 )
            If not done well, google it how to downgrade your gcc.
            1. then do this; (I’ll assume you’ve already tried npm install on your previous installation step)
            cd ~/MagicMirror/modules/MMM-AssistantMk2
            npm install grpc@1.23.4
            npm install --save-dev electron-rebuild
            ./node_modules/.bin/electron-rebuild
            It will take 30 minutes ~ 1 hour. Don’t power off or stop it.
            If not done well… Sorry, I cannot help.
            At this moment, this is one and only way to work properly.
            In my RPI4B+(Raspbian) / Mac (Catalina) / Jetson Nano (Ubuntu 18.04) / Khadas Edge-V (Armbian Buster) / Asus Tinkerboard (TinkerOS), worked today.
            C 1 Reply Last reply Feb 10, 2021, 11:34 AM Reply Quote 0
            • W Offline
              waseemghaly
              Issue solved here: https://github.com/eouia/MMM-AssistantMk2/issues/231
                Chethan @Guest
                @sean please help me still am getting this error i hope you will give the solution
                npm ERR! errno 255
                npm ERR! @bugsounet/snowboy@2.0.5 install: bash scripts/installer.sh
                npm ERR! Exit status 255
                npm ERR!
                npm ERR! Failed at the @bugsounet/snowboy@2.0.5 install script.
                npm ERR!     /home/pi/.npm/_logs/2021-02-10T11_13_15_758Z-debug.log
                S 1 Reply Last reply Feb 10, 2021, 12:17 PM Reply Quote 0
                  sdetweil @Chethan
                  @chethan snowboy 2.5 is very old. this module (mk2) has been abandonded, and replaced by MMM-GoogleAssistant, whos author has left the forum.
                  C 1 Reply Last reply Feb 10, 2021, 1:27 PM Reply Quote 0
                    Chethan @sdetweil
                    @sdetweil @sdetweil can you please tell me which one should I install or use give me a link plz and I use last time in the 2020-08-20 on that time i use raspberry pi that time it’s working now it’s not working
                    S 1 Reply Last reply Feb 10, 2021, 3:41 PM Reply Quote 0
                      sdetweil @Chethan
                      @chethan i do not have an answer
                      mk2 will not work
                      mmm-googleassistant may not work due to snowboy issues. snowboy has also been abandonded
                      https://github.com/Kitt-AI/snowboy/
