    updated installer script available for testing
    211 Posts 18 Posters 337.7k Views 19 Watching
    • N
      Newbie007
      @sdetweil said in Anyone want to try updated installer...:
      What kind of pi are u using?
      Raspberry Pi 2 Model B Rev 1.1
      I don’t have to delete/uninstall previous one?
        sdetweil @Newbie007
        @Newbie007 no, just rename. If u are happy, just delete the older folder
          I have submitted these changes under pull request 1789
            mrdenmark
            i’ve tried running this installer a couple of times now but i keep getting the message-unable to install dependencies-any suggestions on how to proceed?
              sdetweil @mrdenmark
              @mrdenmark show me the install.log from the MagicMirror folder… email to me if cannot post…
              email userid is same as here on gmail
                mrdenmark
                [0_1571974919417_install.log](Uploading 100%)
                  mrdenmark
                  email sent,
                    sdetweil @mrdenmark
                    @mrdenmark thanks… can u try
                    rm -rf node_modules
                    npm install
                    please advise results
                    • N
                      Newbie007
                      Hey, it worked for me thanks!
                        mrdenmark
                        no joy for me,heres a copy of the terminal output-
                        pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                        pi@raspberrypi:~/MagicMirror $ npm install
                        npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                        npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                        npm ERR! code ENOENT
                        npm ERR! syscall chmod
                        npm ERR! path /home/pi/MagicMirror/node_modules/jsesc/bin/jsesc
                        npm ERR! errno -2
                        npm ERR! enoent ENOENT: no such file or directory, chmod ‘/home/pi/MagicMirror/node_modules/jsesc/bin/jsesc’
                        npm ERR! enoent This is related to npm not being able to find a file.
                        npm ERR! enoent
                        npm ERR! /home/pi/.npm/_logs/2019-10-25T19_15_39_049Z-debug.log
                        pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                        magicmirror@2.9.0 start /home/pi/MagicMirror
                        sh run-start.sh
                        run-start.sh: 7: run-start.sh: electron: not found
                        npm ERR! code ELIFECYCLE
                        npm ERR! syscall spawn
                        npm ERR! file sh
                        npm ERR! errno ENOENT
                        npm ERR! magicmirror@2.9.0 start: sh run-start.sh
                        npm ERR! spawn ENOENT
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.9.0 start script.
                        npm ERR! /home/pi/.npm/_logs/2019-10-25T19_16_09_123Z-debug.log
                        pi@raspberrypi:~/MagicMirror $ ^C
                        any suggestions?
                        many thanks for your help so far!
                          mrdenmark
                          heres the debug log-
                          1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
                          2 info using npm@6.12.0
                          3 info using node@v12.13.0
                          4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                          5 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0
                          6 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0
                          7 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true
                          8 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                          9 verbose lifecycle magicmirror@2.9.0~start: CWD: /home/pi/MagicMirror
                          10 silly lifecycle magicmirror@2.9.0~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
                          11 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
                          12 verbose stack Error: magicmirror@2.9.0 start: sh run-start.sh
                          12 verbose stack spawn ENOENT
                          12 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
                          12 verbose stack at ChildProcess.emit (events.js:210:5)
                          12 verbose stack at maybeClose (internal/child_process.js:1021:16)
                          12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
                          13 verbose pkgid magicmirror@2.9.0
                          14 verbose cwd /home/pi/MagicMirror
                          15 verbose Linux 4.19.75-v7+
                          16 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                          17 verbose node v12.13.0
                          18 verbose npm v6.12.0
                          19 error code ELIFECYCLE
                          20 error syscall spawn
                          21 error file sh
                          22 error errno ENOENT
                          23 error magicmirror@2.9.0 start: sh run-start.sh
                          23 error spawn ENOENT
                          24 error Failed at the magicmirror@2.9.0 start script.
                          24 error This is probably not a problem with npm. There is likely additional logging output above.
                          25 verbose exit [ 1, true ]
                          S 2 Replies Last reply
                            sdetweil @mrdenmark
                            @mrdenmark great info! Let me research this
                              sdetweil @mrdenmark
                              @mrdenmark said in Anyone want to try updated installer...:
                              can you do
                              sudo npm i -g npm
                              the try the npm install from the MagicMirror folder
                              also, show me the output of uname -a
                              what OS is this?
                              i don’t have node_modules/jsec installed either, but no error…
                                sdetweil @mrdenmark
                                @mrdenmark i am installing in text mode OS… first time… will report
                                M 1 Reply Last reply
                                  mrdenmark @sdetweil
                                  terminal output below of everything i just tried,uname at the bottom.
                                  do you want the debug logs pasting?
                                  pi@raspberrypi:~/MagicMirror $ sudo npm i 0g npm
                                  npm ERR! code ENOVERSIONS
                                  npm ERR! No valid versions available for 0g
                                  npm ERR! /root/.npm/_logs/2019-10-26T03_33_41_912Z-debug.log
                                  pi@raspberrypi:~/MagicMirror $ cd
                                  pi@raspberrypi:~ $ sudo npm i 0g npm
                                  npm ERR! /root/.npm/_logs/2019-10-26T03_34_31_151Z-debug.log
                                  npm WARN tarball cached data for json5@^2.1.0 (sha512-l+3HXD0GEI3huGq1njuqtzYK8OYJyXMkOLtQ53pjWh89tvWS2h6l+1zMkYWqlb57+SiQodKZyvMEFb2X+KrFhQ==) seems to be corrupted. Refreshing cache.
                                  npm WARN tarball cached data for jsesc@^2.5.1 (sha512-OYu7XEzjkCQ3C5Ps3QIZsQfNpqoJyZZA99wd9aWd05NCtC5pWOkShK2mkL6HXQR6/Cy2lbNdPlZBpuQHXE63gA==) seems to be corrupted. Refreshing cache.
                                  magicmirror@2.9.0 install /home/pi/MagicMirror
                                  cd vendor && npm install
                                  npm WARN tarball cached data for is-extendable@0.1.1 (sha1-YrEQ4omkcUGOPsNqYX1HLjAd/Ik=) seems to be corrupted. Refreshing cache.
                                  npm WARN tarball cached data for lcid@1.0.0 (sha1-MIrMr6C8SDo4Z7S28rlQYlHRuDU=) seems to be corrupted. Refreshing cache.
                                  npm WARN tarball cached data for minimatch@3.0.4 (sha512-yJHVQEhyqPLUTgt9B83PXu6W3rx4MvvHvSUvToogpwoGDOUQ+yDrR0HRot+yOCdCO7u4hX3pWft6kWBBcqh0UA==) seems to be corrupted. Refreshing cache.
                                  npm WARN tarball cached data for invert-kv@1.0.0 (sha1-EEqOSqym09jNFXqO+L+rLXo//bY=) seems to be corrupted. Refreshing cache.
                                  npm WARN tarball cached data for os-locale@1.4.0 (sha1-IPnxeuKe00XoveWDsT0gCYA8FNk=) seems to be corrupted. Refreshing cache.
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                                  added 82 packages from 56 contributors and audited 220 packages in 204.709s
                                  found 5 vulnerabilities (4 low, 1 high)
                                  run npm audit fix to fix them, or npm audit for details
                                  magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                                  sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                                  MagicMirror installation successful!
                                  magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                                  cd fonts && npm install
                                  added 1 package from 1 contributor and audited 1 package in 25.735s
                                  found 0 vulnerabilities
                                  added 50 packages from 51 contributors, removed 7 packages, updated 10 packages, moved 1 package and audited 3714 packages in 543.232s
                                  found 29 vulnerabilities (1 low, 1 moderate, 27 high)
                                  sh run-start.sh
                                  npm ERR! file sh
                                  npm ERR!
                                  npm ERR! /home/pi/.npm/_logs/2019-10-26T03_48_33_404Z-debug.log
                                  pi@raspberrypi:~ $ uname -a
                                  Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
                                  pi@raspberrypi:~ $
                                    mrdenmark
                                    i never thought to mention it before but i have MM working on a windows laptop-i’ve been playing around with it while i waited for all my parts to arrive-are there any files that i can copy between the 2 machines to fix the problem?
                                      sdetweil @mrdenmark
                                      sudo npm i 0g npm
                                      oops… I miss typed
                                      sudo npm i -g npm
                                      then lets erase the node_modules folder again
                                      rm -rf node_modules
                                      then
                                      npm install
                                      i don’t like the ‘seems to be corrupted’
                                      maybe some problem with the memory card?
                                        mrdenmark
                                        still no luck-
                                        did i run the commands in the correct folder?
                                        pi@raspberrypi:~/MagicMirror $ sudo npm i -g npm
                                        /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                        /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                        • npm@6.12.0
                                          updated 1 package in 252.773s
                                        electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                                        node ./download-chromedriver.js
                                        internal/modules/cjs/loader.js:797
                                        throw err;
                                        Error: Cannot find module ‘ms’
                                        Require stack:
                                        • /home/pi/MagicMirror/node_modules/debug/src/debug.js
                                        • /home/pi/MagicMirror/node_modules/debug/src/node.js
                                        • /home/pi/MagicMirror/node_modules/debug/src/index.js
                                        • /home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/electron-download/lib/index.js
                                        • /home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js
                                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:794:15)
                                          at Function.Module._load (internal/modules/cjs/loader.js:687:27)
                                          at Module.require (internal/modules/cjs/loader.js:849:19)
                                          at require (internal/modules/cjs/helpers.js:74:18)
                                          at Object. (/home/pi/MagicMirror/node_modules/debug/src/debug.js:14:20)
                                          at Module._compile (internal/modules/cjs/loader.js:956:30)
                                          at Object.Module._extensions…js (internal/modules/cjs/loader.js:973:10)
                                          at Module.load (internal/modules/cjs/loader.js:812:32)
                                          at Function.Module._load (internal/modules/cjs/loader.js:724:14)
                                          at Module.require (internal/modules/cjs/loader.js:849:19) {
                                          code: ‘MODULE_NOT_FOUND’,
                                          requireStack: [
                                          ‘/home/pi/MagicMirror/node_modules/debug/src/debug.js’,
                                          ‘/home/pi/MagicMirror/node_modules/debug/src/node.js’,
                                          ‘/home/pi/MagicMirror/node_modules/debug/src/index.js’,
                                          ‘/home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/electron-download/lib/index.js’,
                                          ‘/home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js’
                                        npm ERR! errno 1
                                        npm ERR! electron-chromedriver@1.8.0 install: node ./download-chromedriver.js
                                        npm ERR! Exit status 1
                                        npm ERR!
                                        npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                                        npm ERR! /home/pi/.npm/_logs/2019-10-26T18_37_05_007Z-debug.log
                                        sh run-start.sh
                                        /home/pi/MagicMirror/node_modules/electron/index.js:14
                                        throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
                                        Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                                        at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
                                        at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
                                        at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                                        npm ERR! errno 1
                                        npm ERR!
                                        npm ERR! /home/pi/.npm/_logs/2019-10-26T18_42_43_684Z-debug.log
                                          mrdenmark
                                          debug-
                                          11 silly lifecycle magicmirror@2.9.0~start: Returned: code: 1 signal: null
                                          12 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
                                          13 verbose stack Error: magicmirror@2.9.0 start: sh run-start.sh
                                          13 verbose stack Exit status 1
                                          13 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                          13 verbose stack at EventEmitter.emit (events.js:210:5)
                                          13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                          13 verbose stack at ChildProcess.emit (events.js:210:5)
                                          13 verbose stack at maybeClose (internal/child_process.js:1021:16)
                                          13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
                                          14 verbose pkgid magicmirror@2.9.0
                                          15 verbose cwd /home/pi/MagicMirror
                                          16 verbose Linux 4.19.75-v7+
                                          17 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                                          18 verbose node v12.13.0
                                          19 verbose npm v6.12.0
                                          20 error code ELIFECYCLE
                                          21 error errno 1
                                          22 error magicmirror@2.9.0 start: sh run-start.sh
                                          22 error Exit status 1
                                          23 error Failed at the magicmirror@2.9.0 start script.
                                          23 error This is probably not a problem with npm. There is likely additional logging output above.
                                          24 verbose exit [ 1, true ]
                                            sdetweil @mrdenmark
                                            @mrdenmark wow. I can only think there is something wrong with your memory card. You are getting garbage results.
                                            • 10
                                            • 11
                                            • 3 / 11
