    updated installer script available for testing
    211 Posts 18 Posters 337.9k Views 19 Watching
      mrdenmark
      i’ve tried running this installer a couple of times now but i keep getting the message-unable to install dependencies-any suggestions on how to proceed?
        sdetweil @mrdenmark
        @mrdenmark show me the install.log from the MagicMirror folder… email to me if cannot post…
        email userid is same as here on gmail
          mrdenmark
          [0_1571974919417_install.log](Uploading 100%)
            mrdenmark
            email sent,
              sdetweil @mrdenmark
              @mrdenmark thanks… can u try
              rm -rf node_modules
              npm install
              please advise results
              • N
                Newbie007
                Hey, it worked for me thanks!
                  mrdenmark
                  no joy for me,heres a copy of the terminal output-
                  pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                  pi@raspberrypi:~/MagicMirror $ npm install
                  npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                  npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                  npm ERR! code ENOENT
                  npm ERR! syscall chmod
                  npm ERR! path /home/pi/MagicMirror/node_modules/jsesc/bin/jsesc
                  npm ERR! errno -2
                  npm ERR! enoent ENOENT: no such file or directory, chmod ‘/home/pi/MagicMirror/node_modules/jsesc/bin/jsesc’
                  npm ERR! enoent This is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR! /home/pi/.npm/_logs/2019-10-25T19_15_39_049Z-debug.log
                  pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                  magicmirror@2.9.0 start /home/pi/MagicMirror
                  sh run-start.sh
                  run-start.sh: 7: run-start.sh: electron: not found
                  npm ERR! code ELIFECYCLE
                  npm ERR! syscall spawn
                  npm ERR! file sh
                  npm ERR! errno ENOENT
                  npm ERR! magicmirror@2.9.0 start: sh run-start.sh
                  npm ERR! spawn ENOENT
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.9.0 start script.
                  npm ERR! /home/pi/.npm/_logs/2019-10-25T19_16_09_123Z-debug.log
                  pi@raspberrypi:~/MagicMirror $ ^C
                  any suggestions?
                  many thanks for your help so far!
                    mrdenmark
                    heres the debug log-
                    1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
                    2 info using npm@6.12.0
                    3 info using node@v12.13.0
                    4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                    5 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0
                    6 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0
                    7 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true
                    8 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                    9 verbose lifecycle magicmirror@2.9.0~start: CWD: /home/pi/MagicMirror
                    10 silly lifecycle magicmirror@2.9.0~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
                    11 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
                    12 verbose stack Error: magicmirror@2.9.0 start: sh run-start.sh
                    12 verbose stack spawn ENOENT
                    12 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
                    12 verbose stack at ChildProcess.emit (events.js:210:5)
                    12 verbose stack at maybeClose (internal/child_process.js:1021:16)
                    12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
                    13 verbose pkgid magicmirror@2.9.0
                    14 verbose cwd /home/pi/MagicMirror
                    15 verbose Linux 4.19.75-v7+
                    16 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                    17 verbose node v12.13.0
                    18 verbose npm v6.12.0
                    19 error code ELIFECYCLE
                    20 error syscall spawn
                    21 error file sh
                    22 error errno ENOENT
                    23 error magicmirror@2.9.0 start: sh run-start.sh
                    23 error spawn ENOENT
                    24 error Failed at the magicmirror@2.9.0 start script.
                    24 error This is probably not a problem with npm. There is likely additional logging output above.
                    25 verbose exit [ 1, true ]
                    S 2 Replies Last reply
                      sdetweil @mrdenmark
                      @mrdenmark great info! Let me research this
                        sdetweil @mrdenmark
                        @mrdenmark said in Anyone want to try updated installer...:
                        can you do
                        sudo npm i -g npm
                        the try the npm install from the MagicMirror folder
                        also, show me the output of uname -a
                        what OS is this?
                        i don’t have node_modules/jsec installed either, but no error…
                          sdetweil @mrdenmark
                          @mrdenmark i am installing in text mode OS… first time… will report
                          M 1 Reply Last reply
                            mrdenmark @sdetweil
                            terminal output below of everything i just tried,uname at the bottom.
                            do you want the debug logs pasting?
                            pi@raspberrypi:~/MagicMirror $ sudo npm i 0g npm
                            npm ERR! code ENOVERSIONS
                            npm ERR! No valid versions available for 0g
                            npm ERR! /root/.npm/_logs/2019-10-26T03_33_41_912Z-debug.log
                            pi@raspberrypi:~/MagicMirror $ cd
                            pi@raspberrypi:~ $ sudo npm i 0g npm
                            npm ERR! /root/.npm/_logs/2019-10-26T03_34_31_151Z-debug.log
                            npm WARN tarball cached data for json5@^2.1.0 (sha512-l+3HXD0GEI3huGq1njuqtzYK8OYJyXMkOLtQ53pjWh89tvWS2h6l+1zMkYWqlb57+SiQodKZyvMEFb2X+KrFhQ==) seems to be corrupted. Refreshing cache.
                            npm WARN tarball cached data for jsesc@^2.5.1 (sha512-OYu7XEzjkCQ3C5Ps3QIZsQfNpqoJyZZA99wd9aWd05NCtC5pWOkShK2mkL6HXQR6/Cy2lbNdPlZBpuQHXE63gA==) seems to be corrupted. Refreshing cache.
                            magicmirror@2.9.0 install /home/pi/MagicMirror
                            cd vendor && npm install
                            npm WARN tarball cached data for is-extendable@0.1.1 (sha1-YrEQ4omkcUGOPsNqYX1HLjAd/Ik=) seems to be corrupted. Refreshing cache.
                            npm WARN tarball cached data for lcid@1.0.0 (sha1-MIrMr6C8SDo4Z7S28rlQYlHRuDU=) seems to be corrupted. Refreshing cache.
                            npm WARN tarball cached data for minimatch@3.0.4 (sha512-yJHVQEhyqPLUTgt9B83PXu6W3rx4MvvHvSUvToogpwoGDOUQ+yDrR0HRot+yOCdCO7u4hX3pWft6kWBBcqh0UA==) seems to be corrupted. Refreshing cache.
                            npm WARN tarball cached data for invert-kv@1.0.0 (sha1-EEqOSqym09jNFXqO+L+rLXo//bY=) seems to be corrupted. Refreshing cache.
                            npm WARN tarball cached data for os-locale@1.4.0 (sha1-IPnxeuKe00XoveWDsT0gCYA8FNk=) seems to be corrupted. Refreshing cache.
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                            added 82 packages from 56 contributors and audited 220 packages in 204.709s
                            found 5 vulnerabilities (4 low, 1 high)
                            run npm audit fix to fix them, or npm audit for details
                            magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                            sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                            MagicMirror installation successful!
                            magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                            cd fonts && npm install
                            added 1 package from 1 contributor and audited 1 package in 25.735s
                            found 0 vulnerabilities
                            added 50 packages from 51 contributors, removed 7 packages, updated 10 packages, moved 1 package and audited 3714 packages in 543.232s
                            found 29 vulnerabilities (1 low, 1 moderate, 27 high)
                            sh run-start.sh
                            npm ERR! file sh
                            npm ERR!
                            npm ERR! /home/pi/.npm/_logs/2019-10-26T03_48_33_404Z-debug.log
                            pi@raspberrypi:~ $ uname -a
                            Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
                            pi@raspberrypi:~ $
                              mrdenmark
                              i never thought to mention it before but i have MM working on a windows laptop-i’ve been playing around with it while i waited for all my parts to arrive-are there any files that i can copy between the 2 machines to fix the problem?
                                sdetweil @mrdenmark
                                sudo npm i 0g npm
                                oops… I miss typed
                                sudo npm i -g npm
                                then lets erase the node_modules folder again
                                rm -rf node_modules
                                then
                                npm install
                                i don’t like the ‘seems to be corrupted’
                                maybe some problem with the memory card?
                                  mrdenmark
                                  still no luck-
                                  did i run the commands in the correct folder?
                                  pi@raspberrypi:~/MagicMirror $ sudo npm i -g npm
                                  /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                  /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                  • npm@6.12.0
                                    updated 1 package in 252.773s
                                  electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                                  node ./download-chromedriver.js
                                  internal/modules/cjs/loader.js:797
                                  throw err;
                                  Error: Cannot find module ‘ms’
                                  Require stack:
                                  • /home/pi/MagicMirror/node_modules/debug/src/debug.js
                                  • /home/pi/MagicMirror/node_modules/debug/src/node.js
                                  • /home/pi/MagicMirror/node_modules/debug/src/index.js
                                  • /home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/electron-download/lib/index.js
                                  • /home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js
                                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:794:15)
                                    at Function.Module._load (internal/modules/cjs/loader.js:687:27)
                                    at Module.require (internal/modules/cjs/loader.js:849:19)
                                    at require (internal/modules/cjs/helpers.js:74:18)
                                    at Object. (/home/pi/MagicMirror/node_modules/debug/src/debug.js:14:20)
                                    at Module._compile (internal/modules/cjs/loader.js:956:30)
                                    at Object.Module._extensions…js (internal/modules/cjs/loader.js:973:10)
                                    at Module.load (internal/modules/cjs/loader.js:812:32)
                                    at Function.Module._load (internal/modules/cjs/loader.js:724:14)
                                    at Module.require (internal/modules/cjs/loader.js:849:19) {
                                    code: ‘MODULE_NOT_FOUND’,
                                    requireStack: [
                                    ‘/home/pi/MagicMirror/node_modules/debug/src/debug.js’,
                                    ‘/home/pi/MagicMirror/node_modules/debug/src/node.js’,
                                    ‘/home/pi/MagicMirror/node_modules/debug/src/index.js’,
                                    ‘/home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/electron-download/lib/index.js’,
                                    ‘/home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js’
                                  npm ERR! errno 1
                                  npm ERR! electron-chromedriver@1.8.0 install: node ./download-chromedriver.js
                                  npm ERR! Exit status 1
                                  npm ERR!
                                  npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                                  npm ERR! /home/pi/.npm/_logs/2019-10-26T18_37_05_007Z-debug.log
                                  sh run-start.sh
                                  /home/pi/MagicMirror/node_modules/electron/index.js:14
                                  throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
                                  Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                                  at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
                                  at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
                                  at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                                  npm ERR! errno 1
                                  npm ERR!
                                  npm ERR! /home/pi/.npm/_logs/2019-10-26T18_42_43_684Z-debug.log
                                    mrdenmark
                                    debug-
                                    11 silly lifecycle magicmirror@2.9.0~start: Returned: code: 1 signal: null
                                    12 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
                                    13 verbose stack Error: magicmirror@2.9.0 start: sh run-start.sh
                                    13 verbose stack Exit status 1
                                    13 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                    13 verbose stack at EventEmitter.emit (events.js:210:5)
                                    13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                    13 verbose stack at ChildProcess.emit (events.js:210:5)
                                    13 verbose stack at maybeClose (internal/child_process.js:1021:16)
                                    13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
                                    14 verbose pkgid magicmirror@2.9.0
                                    15 verbose cwd /home/pi/MagicMirror
                                    16 verbose Linux 4.19.75-v7+
                                    17 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                                    18 verbose node v12.13.0
                                    19 verbose npm v6.12.0
                                    20 error code ELIFECYCLE
                                    21 error errno 1
                                    22 error magicmirror@2.9.0 start: sh run-start.sh
                                    22 error Exit status 1
                                    23 error Failed at the magicmirror@2.9.0 start script.
                                    23 error This is probably not a problem with npm. There is likely additional logging output above.
                                    24 verbose exit [ 1, true ]
                                      sdetweil @mrdenmark
                                      @mrdenmark wow. I can only think there is something wrong with your memory card. You are getting garbage results.
                                        mrdenmark
                                        i’ll see if i can dig out a spare one and try again,thanks again for your assistance!
                                          mrdenmark
                                          new sd card-works first time-thanks again for your time and effort.
                                            sdetweil @mrdenmark
                                            @mrdenmark outstanding! Thx for the feedback and patience
                                            • 10
                                            • 11
                                            • 4 / 11
