    updated installer script available for testing
    211 Posts 18 Posters 319.4k Views 19 Watching
      sdetweil @mrdenmark
      @mrdenmark i am installing in text mode OS… first time… will report
        mrdenmark @sdetweil
        terminal output below of everything i just tried,uname at the bottom.
        do you want the debug logs pasting?
        pi@raspberrypi:~/MagicMirror $ sudo npm i 0g npm
        npm ERR! code ENOVERSIONS
        npm ERR! No valid versions available for 0g
        npm ERR! /root/.npm/_logs/2019-10-26T03_33_41_912Z-debug.log
        pi@raspberrypi:~/MagicMirror $ cd
        pi@raspberrypi:~ $ sudo npm i 0g npm
        npm ERR! /root/.npm/_logs/2019-10-26T03_34_31_151Z-debug.log
        pi@raspberrypi:~/MagicMirror $ npm install
        npm WARN tarball cached data for json5@^2.1.0 (sha512-l+3HXD0GEI3huGq1njuqtzYK8OYJyXMkOLtQ53pjWh89tvWS2h6l+1zMkYWqlb57+SiQodKZyvMEFb2X+KrFhQ==) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for jsesc@^2.5.1 (sha512-OYu7XEzjkCQ3C5Ps3QIZsQfNpqoJyZZA99wd9aWd05NCtC5pWOkShK2mkL6HXQR6/Cy2lbNdPlZBpuQHXE63gA==) seems to be corrupted. Refreshing cache.
        magicmirror@2.9.0 install /home/pi/MagicMirror
        cd vendor && npm install
        npm WARN tarball cached data for is-extendable@0.1.1 (sha1-YrEQ4omkcUGOPsNqYX1HLjAd/Ik=) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for lcid@1.0.0 (sha1-MIrMr6C8SDo4Z7S28rlQYlHRuDU=) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for minimatch@3.0.4 (sha512-yJHVQEhyqPLUTgt9B83PXu6W3rx4MvvHvSUvToogpwoGDOUQ+yDrR0HRot+yOCdCO7u4hX3pWft6kWBBcqh0UA==) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for invert-kv@1.0.0 (sha1-EEqOSqym09jNFXqO+L+rLXo//bY=) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for os-locale@1.4.0 (sha1-IPnxeuKe00XoveWDsT0gCYA8FNk=) seems to be corrupted. Refreshing cache.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
        added 82 packages from 56 contributors and audited 220 packages in 204.709s
        found 5 vulnerabilities (4 low, 1 high)
        run npm audit fix to fix them, or npm audit for details
        magicmirror@2.9.0 postinstall /home/pi/MagicMirror
        sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
        MagicMirror installation successful!
        magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
        cd fonts && npm install
        added 1 package from 1 contributor and audited 1 package in 25.735s
        found 0 vulnerabilities
        added 50 packages from 51 contributors, removed 7 packages, updated 10 packages, moved 1 package and audited 3714 packages in 543.232s
        found 29 vulnerabilities (1 low, 1 moderate, 27 high)
        magicmirror@2.9.0 start /home/pi/MagicMirror
        sh run-start.sh
        run-start.sh: 7: run-start.sh: electron: not found
        npm ERR! code ELIFECYCLE
        npm ERR! syscall spawn
        npm ERR! file sh
        npm ERR! errno ENOENT
        npm ERR! magicmirror@2.9.0 start: sh run-start.sh
        npm ERR! spawn ENOENT
        npm ERR!
        npm ERR! Failed at the magicmirror@2.9.0 start script.
        npm ERR! /home/pi/.npm/_logs/2019-10-26T03_48_33_404Z-debug.log
        pi@raspberrypi:~ $ uname -a
        Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
        pi@raspberrypi:~ $
          mrdenmark
          i never thought to mention it before but i have MM working on a windows laptop-i’ve been playing around with it while i waited for all my parts to arrive-are there any files that i can copy between the 2 machines to fix the problem?
            sdetweil @mrdenmark
            @mrdenmark said in Anyone want to try updated installer...:
            sudo npm i 0g npm
            oops… I miss typed
            sudo npm i -g npm
            then lets erase the node_modules folder again
            rm -rf node_modules
            then
            npm install
            i don’t like the ‘seems to be corrupted’
            maybe some problem with the memory card?
              mrdenmark
              still no luck-
              did i run the commands in the correct folder?
              pi@raspberrypi:~/MagicMirror $ sudo npm i -g npm
              /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
              /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
              • npm@6.12.0
                updated 1 package in 252.773s
                pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
              electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
              node ./download-chromedriver.js
              internal/modules/cjs/loader.js:797
              throw err;
              Error: Cannot find module ‘ms’
              Require stack:
              • /home/pi/MagicMirror/node_modules/debug/src/debug.js
              • /home/pi/MagicMirror/node_modules/debug/src/node.js
              • /home/pi/MagicMirror/node_modules/debug/src/index.js
              • /home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/electron-download/lib/index.js
              • /home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:794:15)
                at Function.Module._load (internal/modules/cjs/loader.js:687:27)
                at Module.require (internal/modules/cjs/loader.js:849:19)
                at require (internal/modules/cjs/helpers.js:74:18)
                at Object. (/home/pi/MagicMirror/node_modules/debug/src/debug.js:14:20)
                at Module._compile (internal/modules/cjs/loader.js:956:30)
                at Object.Module._extensions…js (internal/modules/cjs/loader.js:973:10)
                at Module.load (internal/modules/cjs/loader.js:812:32)
                at Function.Module._load (internal/modules/cjs/loader.js:724:14)
                at Module.require (internal/modules/cjs/loader.js:849:19) {
                code: ‘MODULE_NOT_FOUND’,
                requireStack: [
                ‘/home/pi/MagicMirror/node_modules/debug/src/debug.js’,
                ‘/home/pi/MagicMirror/node_modules/debug/src/node.js’,
                ‘/home/pi/MagicMirror/node_modules/debug/src/index.js’,
                ‘/home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/electron-download/lib/index.js’,
                ‘/home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js’
                npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
              npm ERR! errno 1
              npm ERR! electron-chromedriver@1.8.0 install: node ./download-chromedriver.js
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
              npm ERR! /home/pi/.npm/_logs/2019-10-26T18_37_05_007Z-debug.log
              sh run-start.sh
              /home/pi/MagicMirror/node_modules/electron/index.js:14
              throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
              Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
              at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
              at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
              at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
              npm ERR! errno 1
              npm ERR!
              npm ERR! /home/pi/.npm/_logs/2019-10-26T18_42_43_684Z-debug.log
                mrdenmark
                debug-
                1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
                2 info using npm@6.12.0
                3 info using node@v12.13.0
                4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                5 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0
                6 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0
                7 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true
                8 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                9 verbose lifecycle magicmirror@2.9.0~start: CWD: /home/pi/MagicMirror
                10 silly lifecycle magicmirror@2.9.0~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
                11 silly lifecycle magicmirror@2.9.0~start: Returned: code: 1 signal: null
                12 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
                13 verbose stack Error: magicmirror@2.9.0 start: sh run-start.sh
                13 verbose stack Exit status 1
                13 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                13 verbose stack at EventEmitter.emit (events.js:210:5)
                13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                13 verbose stack at ChildProcess.emit (events.js:210:5)
                13 verbose stack at maybeClose (internal/child_process.js:1021:16)
                13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
                14 verbose pkgid magicmirror@2.9.0
                15 verbose cwd /home/pi/MagicMirror
                16 verbose Linux 4.19.75-v7+
                17 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                18 verbose node v12.13.0
                19 verbose npm v6.12.0
                20 error code ELIFECYCLE
                21 error errno 1
                22 error magicmirror@2.9.0 start: sh run-start.sh
                22 error Exit status 1
                23 error Failed at the magicmirror@2.9.0 start script.
                23 error This is probably not a problem with npm. There is likely additional logging output above.
                24 verbose exit [ 1, true ]
                  sdetweil @mrdenmark
                  @mrdenmark wow. I can only think there is something wrong with your memory card. You are getting garbage results.
                    mrdenmark
                    i’ll see if i can dig out a spare one and try again,thanks again for your assistance!
                      mrdenmark
                      new sd card-works first time-thanks again for your time and effort.
                        sdetweil @mrdenmark
                        @mrdenmark outstanding! Thx for the feedback and patience
                          BD0G
                          I have a Raspberry Pi Zero W and have installed a fresh image of Raspbian Jesse 20017-07-05. Rebooted. Configured WiFi. Changed default password. Set Time , Timezone, Locale. Rebooted.
                          Then opened a terminal window and copied and pasted the command in the first post to install MM2. Install progressed and I recieved the message Cloning MagicMirror Done! Then I received an error “Unable to install dependencies” . I am using an 8 Gig MicroSD card.
                          I changed directories to MagicMirror to look for the install.log file, but I cannot find one to upload.
                            sdetweil @BD0G
                            @BD0G said in Anyone want to try updated installer...:
                            install.log is in /home/pi the messages from the installer say that (at the beginning)
                            cause the MagicMirror folder doesn’t exist yet
                            one other user has experienced this, (mrdenmark, he posted a bunch right before you), and it was the memory card…
                              BD0G
                              I have ordered a new Micro SD card -16 Gig Class 10 card. That should be large enough and fast enough I imagine. I will repeat the steps to image and use your installer once it arrives. 2 Days from now (Gotta love Amazon Prime).
                              I will let you know how it goes. Thanks for the information.
                                BD0G
                                New Micro SD Card Arrived. I imaged it with Raspian Jesse and attempted the install of Magic Mirror from the command posted in the first post. Same Error.
                                Unable to install dependencies.
                                Here is a link to the install.log file in my dropbox account.
                                https://www.dropbox.com/s/rqhsgvapviqpzrn/install.log?dl=0
                                I would appreciate some assistance with troubleshooting this issue.
                                  sdetweil @BD0G
                                  @BD0G don’t see the link
                                    BD0G @sdetweil
                                    I was having an issue uploading , but finally got it. I modified my post above to include it.
                                      sdetweil @BD0G
                                      @BD0G that is wild… how did that happen
                                      installed Nodejs v0.10.29
                                      ok, working on it…
                                      standby
                                        sdetweil @BD0G
                                        @BD0G ok, give it a try, same installer script command
                                        seems they pulled ANY install support for node on armv6l devices… have to do it manually…
                                        now works good on my pi 0 w
                                          BD0G
                                          So I discovered a bug! Yipeee! I will run the installer again from the first post in this thread and post results!
                                          I am making the assumption that I do not have to delete the Magic Mirror directory and sub -directories so I will just install over them. Its a good way to enjoy the morning coffee. Thanks for putting in effort!
                                            sdetweil @BD0G
                                            @BD0G no… the installer wants to start fresh… just rename the folder out of the way…
                                            you can copy any things you added from old to new
                                            • 10
                                            • 11
                                            • 4 / 11
