    updated installer script available for testing
    211 Posts 18 Posters 337.7k Views 19 Watching
      sdetweil @mrdenmark
      @mrdenmark thanks… can u try
      rm -rf node_modules
      npm install
      please advise results
      • N
        Newbie007
        Hey, it worked for me thanks!
          mrdenmark
          no joy for me,heres a copy of the terminal output-
          pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
          pi@raspberrypi:~/MagicMirror $ npm install
          npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
          npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
          npm ERR! code ENOENT
          npm ERR! syscall chmod
          npm ERR! path /home/pi/MagicMirror/node_modules/jsesc/bin/jsesc
          npm ERR! errno -2
          npm ERR! enoent ENOENT: no such file or directory, chmod ‘/home/pi/MagicMirror/node_modules/jsesc/bin/jsesc’
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR! /home/pi/.npm/_logs/2019-10-25T19_15_39_049Z-debug.log
          pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
          magicmirror@2.9.0 start /home/pi/MagicMirror
          sh run-start.sh
          run-start.sh: 7: run-start.sh: electron: not found
          npm ERR! code ELIFECYCLE
          npm ERR! syscall spawn
          npm ERR! file sh
          npm ERR! errno ENOENT
          npm ERR! magicmirror@2.9.0 start: sh run-start.sh
          npm ERR! spawn ENOENT
          npm ERR!
          npm ERR! Failed at the magicmirror@2.9.0 start script.
          npm ERR! /home/pi/.npm/_logs/2019-10-25T19_16_09_123Z-debug.log
          pi@raspberrypi:~/MagicMirror $ ^C
          any suggestions?
          many thanks for your help so far!
            mrdenmark
            heres the debug log-
            1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
            2 info using npm@6.12.0
            3 info using node@v12.13.0
            4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
            5 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0
            6 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0
            7 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true
            8 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
            9 verbose lifecycle magicmirror@2.9.0~start: CWD: /home/pi/MagicMirror
            10 silly lifecycle magicmirror@2.9.0~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
            11 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
            12 verbose stack Error: magicmirror@2.9.0 start: sh run-start.sh
            12 verbose stack spawn ENOENT
            12 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
            12 verbose stack at ChildProcess.emit (events.js:210:5)
            12 verbose stack at maybeClose (internal/child_process.js:1021:16)
            12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
            13 verbose pkgid magicmirror@2.9.0
            14 verbose cwd /home/pi/MagicMirror
            15 verbose Linux 4.19.75-v7+
            16 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
            17 verbose node v12.13.0
            18 verbose npm v6.12.0
            19 error code ELIFECYCLE
            20 error syscall spawn
            21 error file sh
            22 error errno ENOENT
            23 error magicmirror@2.9.0 start: sh run-start.sh
            23 error spawn ENOENT
            24 error Failed at the magicmirror@2.9.0 start script.
            24 error This is probably not a problem with npm. There is likely additional logging output above.
            25 verbose exit [ 1, true ]
            S 2 Replies Last reply
              sdetweil @mrdenmark
              @mrdenmark great info! Let me research this
                sdetweil @mrdenmark
                @mrdenmark said in Anyone want to try updated installer...:
                can you do
                sudo npm i -g npm
                the try the npm install from the MagicMirror folder
                also, show me the output of uname -a
                what OS is this?
                i don’t have node_modules/jsec installed either, but no error…
                  sdetweil @mrdenmark
                  @mrdenmark i am installing in text mode OS… first time… will report
                  M 1 Reply Last reply
                    mrdenmark @sdetweil
                    terminal output below of everything i just tried,uname at the bottom.
                    do you want the debug logs pasting?
                    pi@raspberrypi:~/MagicMirror $ sudo npm i 0g npm
                    npm ERR! code ENOVERSIONS
                    npm ERR! No valid versions available for 0g
                    npm ERR! /root/.npm/_logs/2019-10-26T03_33_41_912Z-debug.log
                    pi@raspberrypi:~/MagicMirror $ cd
                    pi@raspberrypi:~ $ sudo npm i 0g npm
                    npm ERR! /root/.npm/_logs/2019-10-26T03_34_31_151Z-debug.log
                    npm WARN tarball cached data for json5@^2.1.0 (sha512-l+3HXD0GEI3huGq1njuqtzYK8OYJyXMkOLtQ53pjWh89tvWS2h6l+1zMkYWqlb57+SiQodKZyvMEFb2X+KrFhQ==) seems to be corrupted. Refreshing cache.
                    npm WARN tarball cached data for jsesc@^2.5.1 (sha512-OYu7XEzjkCQ3C5Ps3QIZsQfNpqoJyZZA99wd9aWd05NCtC5pWOkShK2mkL6HXQR6/Cy2lbNdPlZBpuQHXE63gA==) seems to be corrupted. Refreshing cache.
                    magicmirror@2.9.0 install /home/pi/MagicMirror
                    cd vendor && npm install
                    npm WARN tarball cached data for is-extendable@0.1.1 (sha1-YrEQ4omkcUGOPsNqYX1HLjAd/Ik=) seems to be corrupted. Refreshing cache.
                    npm WARN tarball cached data for lcid@1.0.0 (sha1-MIrMr6C8SDo4Z7S28rlQYlHRuDU=) seems to be corrupted. Refreshing cache.
                    npm WARN tarball cached data for minimatch@3.0.4 (sha512-yJHVQEhyqPLUTgt9B83PXu6W3rx4MvvHvSUvToogpwoGDOUQ+yDrR0HRot+yOCdCO7u4hX3pWft6kWBBcqh0UA==) seems to be corrupted. Refreshing cache.
                    npm WARN tarball cached data for invert-kv@1.0.0 (sha1-EEqOSqym09jNFXqO+L+rLXo//bY=) seems to be corrupted. Refreshing cache.
                    npm WARN tarball cached data for os-locale@1.4.0 (sha1-IPnxeuKe00XoveWDsT0gCYA8FNk=) seems to be corrupted. Refreshing cache.
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                    added 82 packages from 56 contributors and audited 220 packages in 204.709s
                    found 5 vulnerabilities (4 low, 1 high)
                    run npm audit fix to fix them, or npm audit for details
                    magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                    sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                    MagicMirror installation successful!
                    magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                    cd fonts && npm install
                    added 1 package from 1 contributor and audited 1 package in 25.735s
                    found 0 vulnerabilities
                    added 50 packages from 51 contributors, removed 7 packages, updated 10 packages, moved 1 package and audited 3714 packages in 543.232s
                    found 29 vulnerabilities (1 low, 1 moderate, 27 high)
                    sh run-start.sh
                    npm ERR! file sh
                    npm ERR!
                    npm ERR! /home/pi/.npm/_logs/2019-10-26T03_48_33_404Z-debug.log
                    pi@raspberrypi:~ $ uname -a
                    Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
                    pi@raspberrypi:~ $
                      mrdenmark
                      i never thought to mention it before but i have MM working on a windows laptop-i’ve been playing around with it while i waited for all my parts to arrive-are there any files that i can copy between the 2 machines to fix the problem?
                        sdetweil @mrdenmark
                        sudo npm i 0g npm
                        oops… I miss typed
                        sudo npm i -g npm
                        then lets erase the node_modules folder again
                        rm -rf node_modules
                        then
                        npm install
                        i don’t like the ‘seems to be corrupted’
                        maybe some problem with the memory card?
                          mrdenmark
                          still no luck-
                          did i run the commands in the correct folder?
                          pi@raspberrypi:~/MagicMirror $ sudo npm i -g npm
                          /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                          /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                          • npm@6.12.0
                            updated 1 package in 252.773s
                          electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                          node ./download-chromedriver.js
                          internal/modules/cjs/loader.js:797
                          throw err;
                          Error: Cannot find module ‘ms’
                          Require stack:
                          • /home/pi/MagicMirror/node_modules/debug/src/debug.js
                          • /home/pi/MagicMirror/node_modules/debug/src/node.js
                          • /home/pi/MagicMirror/node_modules/debug/src/index.js
                          • /home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/electron-download/lib/index.js
                          • /home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js
                            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:794:15)
                            at Function.Module._load (internal/modules/cjs/loader.js:687:27)
                            at Module.require (internal/modules/cjs/loader.js:849:19)
                            at require (internal/modules/cjs/helpers.js:74:18)
                            at Object. (/home/pi/MagicMirror/node_modules/debug/src/debug.js:14:20)
                            at Module._compile (internal/modules/cjs/loader.js:956:30)
                            at Object.Module._extensions…js (internal/modules/cjs/loader.js:973:10)
                            at Module.load (internal/modules/cjs/loader.js:812:32)
                            at Function.Module._load (internal/modules/cjs/loader.js:724:14)
                            at Module.require (internal/modules/cjs/loader.js:849:19) {
                            code: ‘MODULE_NOT_FOUND’,
                            requireStack: [
                            ‘/home/pi/MagicMirror/node_modules/debug/src/debug.js’,
                            ‘/home/pi/MagicMirror/node_modules/debug/src/node.js’,
                            ‘/home/pi/MagicMirror/node_modules/debug/src/index.js’,
                            ‘/home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/electron-download/lib/index.js’,
                            ‘/home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js’
                          npm ERR! errno 1
                          npm ERR! electron-chromedriver@1.8.0 install: node ./download-chromedriver.js
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                          npm ERR! /home/pi/.npm/_logs/2019-10-26T18_37_05_007Z-debug.log
                          sh run-start.sh
                          /home/pi/MagicMirror/node_modules/electron/index.js:14
                          throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
                          Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                          at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
                          at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
                          at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                          npm ERR! errno 1
                          npm ERR!
                          npm ERR! /home/pi/.npm/_logs/2019-10-26T18_42_43_684Z-debug.log
                            mrdenmark
                            debug-
                            11 silly lifecycle magicmirror@2.9.0~start: Returned: code: 1 signal: null
                            12 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
                            13 verbose stack Error: magicmirror@2.9.0 start: sh run-start.sh
                            13 verbose stack Exit status 1
                            13 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                            13 verbose stack at EventEmitter.emit (events.js:210:5)
                            13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                            13 verbose stack at ChildProcess.emit (events.js:210:5)
                            13 verbose stack at maybeClose (internal/child_process.js:1021:16)
                            13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
                            14 verbose pkgid magicmirror@2.9.0
                            15 verbose cwd /home/pi/MagicMirror
                            16 verbose Linux 4.19.75-v7+
                            17 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                            18 verbose node v12.13.0
                            19 verbose npm v6.12.0
                            20 error code ELIFECYCLE
                            21 error errno 1
                            22 error magicmirror@2.9.0 start: sh run-start.sh
                            22 error Exit status 1
                            23 error Failed at the magicmirror@2.9.0 start script.
                            23 error This is probably not a problem with npm. There is likely additional logging output above.
                            24 verbose exit [ 1, true ]
                              sdetweil @mrdenmark
                              @mrdenmark wow. I can only think there is something wrong with your memory card. You are getting garbage results.
                                mrdenmark
                                i’ll see if i can dig out a spare one and try again,thanks again for your assistance!
                                  mrdenmark
                                  new sd card-works first time-thanks again for your time and effort.
                                    sdetweil @mrdenmark
                                    @mrdenmark outstanding! Thx for the feedback and patience
                                      BD0G
                                      I have a Raspberry Pi Zero W and have installed a fresh image of Raspbian Jesse 20017-07-05. Rebooted. Configured WiFi. Changed default password. Set Time , Timezone, Locale. Rebooted.
                                      Then opened a terminal window and copied and pasted the command in the first post to install MM2. Install progressed and I recieved the message Cloning MagicMirror Done! Then I received an error “Unable to install dependencies” . I am using an 8 Gig MicroSD card.
                                      I changed directories to MagicMirror to look for the install.log file, but I cannot find one to upload.
                                        sdetweil @BD0G
                                        @BD0G said in Anyone want to try updated installer...:
                                        install.log is in /home/pi the messages from the installer say that (at the beginning)
                                        cause the MagicMirror folder doesn’t exist yet
                                        one other user has experienced this, (mrdenmark, he posted a bunch right before you), and it was the memory card…
                                          BD0G
                                          I have ordered a new Micro SD card -16 Gig Class 10 card. That should be large enough and fast enough I imagine. I will repeat the steps to image and use your installer once it arrives. 2 Days from now (Gotta love Amazon Prime).
                                          I will let you know how it goes. Thanks for the information.
                                            BD0G
                                            New Micro SD Card Arrived. I imaged it with Raspian Jesse and attempted the install of Magic Mirror from the command posted in the first post. Same Error.
                                            Unable to install dependencies.
                                            Here is a link to the install.log file in my dropbox account.
                                            https://www.dropbox.com/s/rqhsgvapviqpzrn/install.log?dl=0
                                            I would appreciate some assistance with troubleshooting this issue.
                                            • 10
                                            • 11
                                            • 4 / 11
