    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 18.7k Views 2 Watching
      DazTypeR
      OK, so I ran the first script, how do i actually know if it worked?
        sdetweil @DazTypeR
        @DazTypeR if you ran it without any parms at the end, it did not make ANY changes… it was a test, to make u feel comfortable and see the process once… (I don’t want to mess up your system, so it it find an error it cant fix, it tells you, and stops
        now, run it again and add the word ‘apply’ at the end
          DazTypeR
          Sorry, probably didnt make myself clear.
          I knew the 1st script would not make any changes, how do i know the script worked and did not mess anything up?
          I dont see any messages output to the command line, it just finished.
          Sorry about my lack of understanding, I`m trying to learn as I go but its a long slog.
          This is the last thing it put out…
                  fi
                  # return to original folder
                  cd - >/dev/null
                  date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
          else
                  echo It appears MagicMirror has not been installed on this system
                  echo please run the installer, "raspberry.sh" first
          fi
            sdetweil @DazTypeR
            @DazTypeR
            ok… the UPDATE script only updates… do you have a ~/MagicMirror folder??
            it sounded like you did, cause you were trying to do a git pull
            just go run your mirror again… again, it makes NO changes to your local working copy.
            (it did download updates to the local git repo (~/MagicMirror/.git folder), but did not apply any updates)
            post the log from ~/MagicMirorr/installers/upgrade.log
            please use the markdown code block feature…
            paste the log text, select the text.
            push the </> button
              DazTypeR
              Yes I have a MagicMirror folder as I have managed to run my mirror for 10 months and have managed to do 2 upgrades in that time but in the past it has always told me what the error is and mostly how to fix it.
              With regards to posting the log, there is no upgrade.log file in that directory?
                sdetweil @DazTypeR
                @DazTypeR no log file… hm…
                which sounds like your MagicMirror folder is not called ‘MagicMirror’
                look in user home folder ~/
                  DazTypeR
                  It is called MagicMirror…
                  pi@raspberrypi:~/MagicMirror
                    sdetweil @DazTypeR
                    @DazTypeR ok, show me the log ~/upgrade.log or ~/MagicMirror/installers/upgrade.log
                      the upgrade script does this at the beginning
                      # if the MagicMirroe folder exists
                      if [ -d ~/MagicMirror ]; then
                      	# put the log where the script is located
                      	logdir=$(dirname $($cmd -f "$0"))
                      	# if the script was execute from the web
                      	if [[ $logdir != *"MagicMirror/installers"* ]]; then
                      		# use the MagicMirror/installers folder
                      		cd ~/MagicMirror/installers >/dev/null
                      		logdir=$(pwd)
                      		cd - >/dev/null
                      	fi
                      	logfile=$logdir/upgrade.log
                        DazTypeR
                        I can’t find an upgrade.log either in home or in the MagicMirror/installers folder.
                          sdetweil @DazTypeR
                          @DazTypeR well then
                          so, when u run it it says
                          if so, rerun the script like this
                          bash -c -x  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                            DazTypeR
                            Hang on, I just ran this command…
                            Should I have run this command…
                            bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)”
                            No idea what the bash -c does?
                            Would this have made a difference?
                              sdetweil @DazTypeR
                              @DazTypeR yes… if you do it without bash -c, then it downloads the file, and throws it away
                              if you do the bash -c, then it executes the script (single command -c)
                              watch out for the double quotes… sometimes those turn into MS word document quotes, which linux shells don’t like
                                DazTypeR
                                OK, so its official, I am a numpty :)
                                This is what I get now when I run it…
                                the log will be /home/pi/MagicMirror/installers/upgrade.log
                                doing test run = true
                                saving custom.css
                                upgrading from version 2.9.0 to 2.9.0
                                fetching latest revisions
                                bash: line 159: On branch master: command not found
                                there are 28 local files that are different than the master repo
                                .eslintrc.json
                                .gitignore
                                .travis.yml
                                CHANGELOG.md
                                LICENSE.md
                                installers/raspberry.sh
                                js/main.js
                                modules/default/calendar/vendor/ical.js/node-ical.js
                                modules/default/clock/clock.js
                                modules/default/currentweather/currentweather.js
                                modules/default/newsfeed/newsfeed.js
                                modules/default/updatenotification/node_helper.js
                                modules/default/updatenotification/updatenotification.js
                                modules/default/weather/providers/darksky.js
                                modules/default/weather/providers/openweathermap.js
                                modules/default/weather/providers/ukmetoffice.js
                                modules/default/weather/providers/weathergov.js
                                modules/default/weather/weather.js
                                modules/default/weather/weatherprovider.js
                                modules/default/weatherforecast/weatherforecast.js
                                package.json
                                run-start.sh
                                tests/e2e/vendor_spec.js
                                translations/en.json
                                translations/es.json
                                translations/translations.js
                                vendor/package-lock.json
                                package-lock.json
                                any *-lock.json files do not need to be saved
                                do you want to save these files for later (Y/n)?n
                                skipping restore for .eslintrc.json, doing test run
                                skipping restore for .gitignore, doing test run
                                skipping restore for .travis.yml, doing test run
                                skipping restore for CHANGELOG.md, doing test run
                                skipping restore for LICENSE.md, doing test run
                                skipping restore for installers/raspberry.sh, doing test run
                                skipping restore for js/main.js, doing test run
                                skipping restore for modules/default/calendar/vendor/ical.js/node-ical.js, doing test run
                                skipping restore for modules/default/clock/clock.js, doing test run
                                skipping restore for modules/default/currentweather/currentweather.js, doing test run
                                skipping restore for modules/default/newsfeed/newsfeed.js, doing test run
                                skipping restore for modules/default/updatenotification/node_helper.js, doing test run
                                skipping restore for modules/default/updatenotification/updatenotification.js, doing test run
                                skipping restore for modules/default/weather/providers/darksky.js, doing test run
                                skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
                                skipping restore for modules/default/weather/providers/ukmetoffice.js, doing test run
                                skipping restore for modules/default/weather/providers/weathergov.js, doing test run
                                skipping restore for modules/default/weather/weather.js, doing test run
                                skipping restore for modules/default/weather/weatherprovider.js, doing test run
                                skipping restore for modules/default/weatherforecast/weatherforecast.js, doing test run
                                skipping restore for package.json, doing test run
                                skipping restore for run-start.sh, doing test run
                                skipping restore for tests/e2e/vendor_spec.js, doing test run
                                skipping restore for translations/en.json, doing test run
                                skipping restore for translations/es.json, doing test run
                                skipping restore for translations/translations.js, doing test run
                                skipping restore for vendor/package-lock.json, doing test run
                                skipping restore for package-lock.json, doing test run
                                processing for module MMM-GooglePhotos please wait
                                skipped processing for MMM-GooglePhotos, doing test run
                                processing complete for module MMM-GooglePhotos
                                restoring custom.css
                                It then put me back to the command line.
                                  sdetweil @DazTypeR
                                  @DazTypeR cool,just like it should have… altho… line 159 bothers me
                                  can you run it again without apply, and use the debug flag
                                  you will have to scroll back up in the terminal window, but I’d like to see the few lines above/below the error line 159
                                  thx
                                    DazTypeR
                                    Hope this has everything you need…
                                    • echo current branch = master
                                      ++ git status
                                    • ‘On branch master’ ‘Your branch and ‘'‘origin/master’'’ have diverged,’ ‘and have 4 and 76 different commits each, respectively.’ ’ (use “git pull” to merge the remote branch into yours)’ ‘You have unmerged paths.’ ’ (fix conflicts and run “git commit”)’ ’ (use “git merge --abort” to abort the merge)’ ‘Changes to be committed:’ ’ modified: .eslintrc.json’ ’ modified: .gitignore’ ’ modified: .travis.yml’ ’ modified: CHANGELOG.md’ ’ modified: LICENSE.md’ ’ deleted: css/custom.css’ ’ modified: installers/raspberry.sh’ ’ modified: js/main.js’ ’ modified: modules/default/calendar/vendor/ical.js/node-ical.js’ ’ modified: modules/default/clock/clock.js’ ’ modified: modules/default/currentweather/currentweather.js’ ’ modified: modules/default/newsfeed/newsfeed.js’ ’ modified: modules/default/updatenotification/node_helper.js’ ’ modified: modules/default/updatenotification/updatenotification.js’ ’ modified: modules/default/weather/providers/darksky.js’ ’ modified: modules/default/weather/providers/openweathermap.js’ ’ modified: modules/default/weather/providers/ukmetoffice.js’ ’ modified: modules/default/weather/providers/weathergov.js’ ’ modified: modules/default/weather/weather.js’ ’ modified: modules/default/weather/weatherprovider.js’ ’ modified: modules/default/weatherforecast/weatherforecast.js’ ’ modified: package.json’ ’ modified: run-start.sh’ ’ new file: tests/configs/modules/weather/currentweather_default.js’ ’ new file: tests/configs/modules/weather/currentweather_options.js’ ’ new file: tests/configs/modules/weather/currentweather_units.js’ ’ new file: tests/configs/modules/weather/forecastweather_default.js’ ’ new file: tests/configs/modules/weather/forecastweather_options.js’ ’ new file: tests/e2e/modules/mocks/index.js’ ’ new file: tests/e2e/modules/mocks/weather_current.js’ ’ new file: tests/e2e/modules/mocks/weather_forecast.js’ ’ new file: tests/e2e/modules/weather_spec.js’ ’ modified: tests/e2e/vendor_spec.js’ ’ new file: tests/node_modules/webdriverajaxstub/index.js’ ’ modified: translations/en.json’ ’ modified: translations/es.json’ ’ new file: translations/ms-my.json’ ’ modified: translations/translations.js’ ’ new file: untrack-css.sh’ ’ modified: vendor/package-lock.json’ ‘Unmerged paths:’ ’ (use “git add …” to mark resolution)’ ’ both modified: package-lock.json’ ‘Untracked files:’ ’ (use “git add …” to include in what will be committed)’ ’ css/save_custom.css’ ’ installers/dumpactivemodules.js’
                                      ++ git status
                                      ++ grep modified
                                      ++ awk -F: ‘{print $2}’
                                    • diffs=’ .eslintrc.json
                                      .gitignore
                                      .travis.yml
                                      CHANGELOG.md
                                      LICENSE.md
                                      js/main.js
                                      sdetweil @DazTypeR
                                      @DazTypeR cool, can u try that one more time (without apply) to see if I fixed the line 159 problem
                                        DazTypeR
                                        Just ran it again without the extra logging and a block of the output shows this…
                                        saving custom.css
                                          sdetweil @DazTypeR
                                          @DazTypeR can I beg one more try?
                                            DazTypeR
                                            saving custom.css
                                            bash: line 154: [: missing `]’
                                            MagicMirror git fetch failed
