    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 18.2k Views 2 Watching
      sdetweil @DazTypeR
      @DazTypeR if you ran it without any parms at the end, it did not make ANY changes… it was a test, to make u feel comfortable and see the process once… (I don’t want to mess up your system, so it it find an error it cant fix, it tells you, and stops
      now, run it again and add the word ‘apply’ at the end
        DazTypeR
        Sorry, probably didnt make myself clear.
        I knew the 1st script would not make any changes, how do i know the script worked and did not mess anything up?
        I dont see any messages output to the command line, it just finished.
        Sorry about my lack of understanding, I`m trying to learn as I go but its a long slog.
        This is the last thing it put out…
                fi
                # return to original folder
                cd - >/dev/null
                date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
        else
                echo It appears MagicMirror has not been installed on this system
                echo please run the installer, "raspberry.sh" first
        fi
          sdetweil @DazTypeR
          @DazTypeR
          ok… the UPDATE script only updates… do you have a ~/MagicMirror folder??
          it sounded like you did, cause you were trying to do a git pull
          just go run your mirror again… again, it makes NO changes to your local working copy.
          (it did download updates to the local git repo (~/MagicMirror/.git folder), but did not apply any updates)
          post the log from ~/MagicMirorr/installers/upgrade.log
          please use the markdown code block feature…
          paste the log text, select the text.
          push the </> button
            DazTypeR
            Yes I have a MagicMirror folder as I have managed to run my mirror for 10 months and have managed to do 2 upgrades in that time but in the past it has always told me what the error is and mostly how to fix it.
            With regards to posting the log, there is no upgrade.log file in that directory?
              sdetweil @DazTypeR
              @DazTypeR no log file… hm…
              which sounds like your MagicMirror folder is not called ‘MagicMirror’
              look in user home folder ~/
                DazTypeR
                It is called MagicMirror…
                pi@raspberrypi:~/MagicMirror
                  sdetweil @DazTypeR
                  @DazTypeR ok, show me the log ~/upgrade.log or ~/MagicMirror/installers/upgrade.log
                    the upgrade script does this at the beginning
                    # if the MagicMirroe folder exists
                    if [ -d ~/MagicMirror ]; then
                    	# put the log where the script is located
                    	logdir=$(dirname $($cmd -f "$0"))
                    	# if the script was execute from the web
                    	if [[ $logdir != *"MagicMirror/installers"* ]]; then
                    		# use the MagicMirror/installers folder
                    		cd ~/MagicMirror/installers >/dev/null
                    		logdir=$(pwd)
                    		cd - >/dev/null
                    	fi
                    	logfile=$logdir/upgrade.log
                      DazTypeR
                      I can’t find an upgrade.log either in home or in the MagicMirror/installers folder.
                        sdetweil @DazTypeR
                        @DazTypeR well then
                        so, when u run it it says
                        if so, rerun the script like this
                        bash -c -x  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                          DazTypeR
                          Hang on, I just ran this command…
                          Should I have run this command…
                          bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)”
                          No idea what the bash -c does?
                          Would this have made a difference?
                            sdetweil @DazTypeR
                            @DazTypeR yes… if you do it without bash -c, then it downloads the file, and throws it away
                            if you do the bash -c, then it executes the script (single command -c)
                            watch out for the double quotes… sometimes those turn into MS word document quotes, which linux shells don’t like
                              DazTypeR
                              OK, so its official, I am a numpty :)
                              This is what I get now when I run it…
                              the log will be /home/pi/MagicMirror/installers/upgrade.log
                              doing test run = true
                              saving custom.css
                              upgrading from version 2.9.0 to 2.9.0
                              fetching latest revisions
                              bash: line 159: On branch master: command not found
                              there are 28 local files that are different than the master repo
                              .eslintrc.json
                              .gitignore
                              .travis.yml
                              CHANGELOG.md
                              LICENSE.md
                              installers/raspberry.sh
                              js/main.js
                              modules/default/calendar/vendor/ical.js/node-ical.js
                              modules/default/clock/clock.js
                              modules/default/currentweather/currentweather.js
                              modules/default/newsfeed/newsfeed.js
                              modules/default/updatenotification/node_helper.js
                              modules/default/updatenotification/updatenotification.js
                              modules/default/weather/providers/darksky.js
                              modules/default/weather/providers/openweathermap.js
                              modules/default/weather/providers/ukmetoffice.js
                              modules/default/weather/providers/weathergov.js
                              modules/default/weather/weather.js
                              modules/default/weather/weatherprovider.js
                              modules/default/weatherforecast/weatherforecast.js
                              package.json
                              run-start.sh
                              tests/e2e/vendor_spec.js
                              translations/en.json
                              translations/es.json
                              translations/translations.js
                              vendor/package-lock.json
                              package-lock.json
                              any *-lock.json files do not need to be saved
                              do you want to save these files for later (Y/n)?n
                              skipping restore for .eslintrc.json, doing test run
                              skipping restore for .gitignore, doing test run
                              skipping restore for .travis.yml, doing test run
                              skipping restore for CHANGELOG.md, doing test run
                              skipping restore for LICENSE.md, doing test run
                              skipping restore for installers/raspberry.sh, doing test run
                              skipping restore for js/main.js, doing test run
                              skipping restore for modules/default/calendar/vendor/ical.js/node-ical.js, doing test run
                              skipping restore for modules/default/clock/clock.js, doing test run
                              skipping restore for modules/default/currentweather/currentweather.js, doing test run
                              skipping restore for modules/default/newsfeed/newsfeed.js, doing test run
                              skipping restore for modules/default/updatenotification/node_helper.js, doing test run
                              skipping restore for modules/default/updatenotification/updatenotification.js, doing test run
                              skipping restore for modules/default/weather/providers/darksky.js, doing test run
                              skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
                              skipping restore for modules/default/weather/providers/ukmetoffice.js, doing test run
                              skipping restore for modules/default/weather/providers/weathergov.js, doing test run
                              skipping restore for modules/default/weather/weather.js, doing test run
                              skipping restore for modules/default/weather/weatherprovider.js, doing test run
                              skipping restore for modules/default/weatherforecast/weatherforecast.js, doing test run
                              skipping restore for package.json, doing test run
                              skipping restore for run-start.sh, doing test run
                              skipping restore for tests/e2e/vendor_spec.js, doing test run
                              skipping restore for translations/en.json, doing test run
                              skipping restore for translations/es.json, doing test run
                              skipping restore for translations/translations.js, doing test run
                              skipping restore for vendor/package-lock.json, doing test run
                              skipping restore for package-lock.json, doing test run
                              processing for module MMM-GooglePhotos please wait
                              skipped processing for MMM-GooglePhotos, doing test run
                              processing complete for module MMM-GooglePhotos
                              restoring custom.css
                              It then put me back to the command line.
                                sdetweil @DazTypeR
                                @DazTypeR cool,just like it should have… altho… line 159 bothers me
                                can you run it again without apply, and use the debug flag
                                you will have to scroll back up in the terminal window, but I’d like to see the few lines above/below the error line 159
                                thx
                                  DazTypeR
                                  Hope this has everything you need…
                                  • echo current branch = master
                                    ++ git status
                                  • ‘On branch master’ ‘Your branch and ‘'‘origin/master’'’ have diverged,’ ‘and have 4 and 76 different commits each, respectively.’ ’ (use “git pull” to merge the remote branch into yours)’ ‘You have unmerged paths.’ ’ (fix conflicts and run “git commit”)’ ’ (use “git merge --abort” to abort the merge)’ ‘Changes to be committed:’ ’ modified: .eslintrc.json’ ’ modified: .gitignore’ ’ modified: .travis.yml’ ’ modified: CHANGELOG.md’ ’ modified: LICENSE.md’ ’ deleted: css/custom.css’ ’ modified: installers/raspberry.sh’ ’ modified: js/main.js’ ’ modified: modules/default/calendar/vendor/ical.js/node-ical.js’ ’ modified: modules/default/clock/clock.js’ ’ modified: modules/default/currentweather/currentweather.js’ ’ modified: modules/default/newsfeed/newsfeed.js’ ’ modified: modules/default/updatenotification/node_helper.js’ ’ modified: modules/default/updatenotification/updatenotification.js’ ’ modified: modules/default/weather/providers/darksky.js’ ’ modified: modules/default/weather/providers/openweathermap.js’ ’ modified: modules/default/weather/providers/ukmetoffice.js’ ’ modified: modules/default/weather/providers/weathergov.js’ ’ modified: modules/default/weather/weather.js’ ’ modified: modules/default/weather/weatherprovider.js’ ’ modified: modules/default/weatherforecast/weatherforecast.js’ ’ modified: package.json’ ’ modified: run-start.sh’ ’ new file: tests/configs/modules/weather/currentweather_default.js’ ’ new file: tests/configs/modules/weather/currentweather_options.js’ ’ new file: tests/configs/modules/weather/currentweather_units.js’ ’ new file: tests/configs/modules/weather/forecastweather_default.js’ ’ new file: tests/configs/modules/weather/forecastweather_options.js’ ’ new file: tests/e2e/modules/mocks/index.js’ ’ new file: tests/e2e/modules/mocks/weather_current.js’ ’ new file: tests/e2e/modules/mocks/weather_forecast.js’ ’ new file: tests/e2e/modules/weather_spec.js’ ’ modified: tests/e2e/vendor_spec.js’ ’ new file: tests/node_modules/webdriverajaxstub/index.js’ ’ modified: translations/en.json’ ’ modified: translations/es.json’ ’ new file: translations/ms-my.json’ ’ modified: translations/translations.js’ ’ new file: untrack-css.sh’ ’ modified: vendor/package-lock.json’ ‘Unmerged paths:’ ’ (use “git add …” to mark resolution)’ ’ both modified: package-lock.json’ ‘Untracked files:’ ’ (use “git add …” to include in what will be committed)’ ’ css/save_custom.css’ ’ installers/dumpactivemodules.js’
                                    ++ git status
                                    ++ grep modified
                                    ++ awk -F: ‘{print $2}’
                                  • diffs=’ .eslintrc.json
                                    .gitignore
                                    .travis.yml
                                    CHANGELOG.md
                                    LICENSE.md
                                    js/main.js
                                    sdetweil @DazTypeR
                                    @DazTypeR cool, can u try that one more time (without apply) to see if I fixed the line 159 problem
                                      DazTypeR
                                      Just ran it again without the extra logging and a block of the output shows this…
                                      saving custom.css
                                        sdetweil @DazTypeR
                                        @DazTypeR can I beg one more try?
                                          DazTypeR
                                          saving custom.css
                                          bash: line 154: [: missing `]’
                                          MagicMirror git fetch failed
                                            sdetweil @DazTypeR
                                            @DazTypeR one last time
