    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 16.4k Views 2 Watching
      DazTypeR
      Hi all,
      Trying to update Magic Mirror to the latest version after receiving a message on my mirror, I have always had issues updating the Mirror software but the messages provided to me in the past have always been helpful and I have manged to muddle my way through and get updated.
      Now after issuing git pull && npm install in the Magicmirror directory, all I get is the below…
      hint: Fix them up in the work tree, and then use ‘git add/rm ’
      hint: as appropriate to mark resolution and make a commit.
      fatal: Exiting because of an unresolved conflict.
      I have no idea what these can be, in the past I have always had issues with package lock json and vendor package lock json but the errors provided previously have always helped and offered explanations.
      I am running the stock mirror software with the Google Photos module added, can anybody help me to understand what the above message means and where I can fix it to enable me to update?
      Thank you in advance.
        sdetweil @DazTypeR
        @DazTypeR please try the new upgrade script (will be part of next release)
        see https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
          DazTypeR
          So i just CD into the MagicMirror directory and then run the top command, if that works, then run the 2nd?
            sdetweil @DazTypeR
            @DazTypeR no… don’t need to cd, just execute the script, it will figure it out and ask you to save any changed files
            note… first time is a test install, doesn’t change anything…
            then, if all is good, run it again with apply parameter
              DazTypeR
              OK, so I ran the first script, how do i actually know if it worked?
                sdetweil @DazTypeR
                @DazTypeR if you ran it without any parms at the end, it did not make ANY changes… it was a test, to make u feel comfortable and see the process once… (I don’t want to mess up your system, so it it find an error it cant fix, it tells you, and stops
                now, run it again and add the word ‘apply’ at the end
                  DazTypeR
                  Sorry, probably didnt make myself clear.
                  I knew the 1st script would not make any changes, how do i know the script worked and did not mess anything up?
                  I dont see any messages output to the command line, it just finished.
                  Sorry about my lack of understanding, I`m trying to learn as I go but its a long slog.
                  This is the last thing it put out…
                          fi
                          # return to original folder
                          cd - >/dev/null
                          date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
                  else
                          echo It appears MagicMirror has not been installed on this system
                          echo please run the installer, "raspberry.sh" first
                  fi
                    sdetweil @DazTypeR
                    @DazTypeR
                    ok… the UPDATE script only updates… do you have a ~/MagicMirror folder??
                    it sounded like you did, cause you were trying to do a git pull
                    just go run your mirror again… again, it makes NO changes to your local working copy.
                    (it did download updates to the local git repo (~/MagicMirror/.git folder), but did not apply any updates)
                    post the log from ~/MagicMirorr/installers/upgrade.log
                    please use the markdown code block feature…
                    paste the log text, select the text.
                    push the </> button
                      DazTypeR
                      Yes I have a MagicMirror folder as I have managed to run my mirror for 10 months and have managed to do 2 upgrades in that time but in the past it has always told me what the error is and mostly how to fix it.
                      With regards to posting the log, there is no upgrade.log file in that directory?
                        sdetweil @DazTypeR
                        @DazTypeR no log file… hm…
                        which sounds like your MagicMirror folder is not called ‘MagicMirror’
                        look in user home folder ~/
                          DazTypeR
                          It is called MagicMirror…
                          pi@raspberrypi:~/MagicMirror
                            sdetweil @DazTypeR
                            @DazTypeR ok, show me the log ~/upgrade.log or ~/MagicMirror/installers/upgrade.log
                              the upgrade script does this at the beginning
                              # if the MagicMirroe folder exists
                              if [ -d ~/MagicMirror ]; then
                              	# put the log where the script is located
                              	logdir=$(dirname $($cmd -f "$0"))
                              	# if the script was execute from the web
                              	if [[ $logdir != *"MagicMirror/installers"* ]]; then
                              		# use the MagicMirror/installers folder
                              		cd ~/MagicMirror/installers >/dev/null
                              		logdir=$(pwd)
                              		cd - >/dev/null
                              	fi
                              	logfile=$logdir/upgrade.log
                                DazTypeR
                                I can’t find an upgrade.log either in home or in the MagicMirror/installers folder.
                                  sdetweil @DazTypeR
                                  @DazTypeR well then
                                  so, when u run it it says
                                  if so, rerun the script like this
                                  bash -c -x  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                                    DazTypeR
                                    Hang on, I just ran this command…
                                    Should I have run this command…
                                    bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)”
                                    No idea what the bash -c does?
                                    Would this have made a difference?
                                      sdetweil @DazTypeR
                                      @DazTypeR yes… if you do it without bash -c, then it downloads the file, and throws it away
                                      if you do the bash -c, then it executes the script (single command -c)
                                      watch out for the double quotes… sometimes those turn into MS word document quotes, which linux shells don’t like
                                        DazTypeR
                                        OK, so its official, I am a numpty :)
                                        This is what I get now when I run it…
                                        the log will be /home/pi/MagicMirror/installers/upgrade.log
                                        doing test run = true
                                        saving custom.css
                                        upgrading from version 2.9.0 to 2.9.0
                                        fetching latest revisions
                                        bash: line 159: On branch master: command not found
                                        there are 28 local files that are different than the master repo
                                        .eslintrc.json
                                        .gitignore
                                        .travis.yml
                                        CHANGELOG.md
                                        LICENSE.md
                                        installers/raspberry.sh
                                        js/main.js
                                        modules/default/calendar/vendor/ical.js/node-ical.js
                                        modules/default/clock/clock.js
                                        modules/default/currentweather/currentweather.js
                                        modules/default/newsfeed/newsfeed.js
                                        modules/default/updatenotification/node_helper.js
                                        modules/default/updatenotification/updatenotification.js
                                        modules/default/weather/providers/darksky.js
                                        modules/default/weather/providers/openweathermap.js
                                        modules/default/weather/providers/ukmetoffice.js
                                        modules/default/weather/providers/weathergov.js
                                        modules/default/weather/weather.js
                                        modules/default/weather/weatherprovider.js
                                        modules/default/weatherforecast/weatherforecast.js
                                        package.json
                                        run-start.sh
                                        tests/e2e/vendor_spec.js
                                        translations/en.json
                                        translations/es.json
                                        translations/translations.js
                                        vendor/package-lock.json
                                        package-lock.json
                                        any *-lock.json files do not need to be saved
                                        do you want to save these files for later (Y/n)?n
                                        skipping restore for .eslintrc.json, doing test run
                                        skipping restore for .gitignore, doing test run
                                        skipping restore for .travis.yml, doing test run
                                        skipping restore for CHANGELOG.md, doing test run
                                        skipping restore for LICENSE.md, doing test run
                                        skipping restore for installers/raspberry.sh, doing test run
                                        skipping restore for js/main.js, doing test run
                                        skipping restore for modules/default/calendar/vendor/ical.js/node-ical.js, doing test run
                                        skipping restore for modules/default/clock/clock.js, doing test run
                                        skipping restore for modules/default/currentweather/currentweather.js, doing test run
                                        skipping restore for modules/default/newsfeed/newsfeed.js, doing test run
                                        skipping restore for modules/default/updatenotification/node_helper.js, doing test run
                                        skipping restore for modules/default/updatenotification/updatenotification.js, doing test run
                                        skipping restore for modules/default/weather/providers/darksky.js, doing test run
                                        skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
                                        skipping restore for modules/default/weather/providers/ukmetoffice.js, doing test run
                                        skipping restore for modules/default/weather/providers/weathergov.js, doing test run
                                        skipping restore for modules/default/weather/weather.js, doing test run
                                        skipping restore for modules/default/weather/weatherprovider.js, doing test run
                                        skipping restore for modules/default/weatherforecast/weatherforecast.js, doing test run
                                        skipping restore for package.json, doing test run
                                        skipping restore for run-start.sh, doing test run
                                        skipping restore for tests/e2e/vendor_spec.js, doing test run
                                        skipping restore for translations/en.json, doing test run
                                        skipping restore for translations/es.json, doing test run
                                        skipping restore for translations/translations.js, doing test run
                                        skipping restore for vendor/package-lock.json, doing test run
                                        skipping restore for package-lock.json, doing test run
                                        processing for module MMM-GooglePhotos please wait
                                        skipped processing for MMM-GooglePhotos, doing test run
                                        processing complete for module MMM-GooglePhotos
                                        restoring custom.css
                                        It then put me back to the command line.
                                          sdetweil @DazTypeR
                                          @DazTypeR cool,just like it should have… altho… line 159 bothers me
                                          can you run it again without apply, and use the debug flag
                                          you will have to scroll back up in the terminal window, but I’d like to see the few lines above/below the error line 159
                                          thx
                                            DazTypeR
                                            Hope this has everything you need…
                                            • echo current branch = master
                                              ++ git status
                                            • ‘On branch master’ ‘Your branch and ‘'‘origin/master’'’ have diverged,’ ‘and have 4 and 76 different commits each, respectively.’ ’ (use “git pull” to merge the remote branch into yours)’ ‘You have unmerged paths.’ ’ (fix conflicts and run “git commit”)’ ’ (use “git merge --abort” to abort the merge)’ ‘Changes to be committed:’ ’ modified: .eslintrc.json’ ’ modified: .gitignore’ ’ modified: .travis.yml’ ’ modified: CHANGELOG.md’ ’ modified: LICENSE.md’ ’ deleted: css/custom.css’ ’ modified: installers/raspberry.sh’ ’ modified: js/main.js’ ’ modified: modules/default/calendar/vendor/ical.js/node-ical.js’ ’ modified: modules/default/clock/clock.js’ ’ modified: modules/default/currentweather/currentweather.js’ ’ modified: modules/default/newsfeed/newsfeed.js’ ’ modified: modules/default/updatenotification/node_helper.js’ ’ modified: modules/default/updatenotification/updatenotification.js’ ’ modified: modules/default/weather/providers/darksky.js’ ’ modified: modules/default/weather/providers/openweathermap.js’ ’ modified: modules/default/weather/providers/ukmetoffice.js’ ’ modified: modules/default/weather/providers/weathergov.js’ ’ modified: modules/default/weather/weather.js’ ’ modified: modules/default/weather/weatherprovider.js’ ’ modified: modules/default/weatherforecast/weatherforecast.js’ ’ modified: package.json’ ’ modified: run-start.sh’ ’ new file: tests/configs/modules/weather/currentweather_default.js’ ’ new file: tests/configs/modules/weather/currentweather_options.js’ ’ new file: tests/configs/modules/weather/currentweather_units.js’ ’ new file: tests/configs/modules/weather/forecastweather_default.js’ ’ new file: tests/configs/modules/weather/forecastweather_options.js’ ’ new file: tests/e2e/modules/mocks/index.js’ ’ new file: tests/e2e/modules/mocks/weather_current.js’ ’ new file: tests/e2e/modules/mocks/weather_forecast.js’ ’ new file: tests/e2e/modules/weather_spec.js’ ’ modified: tests/e2e/vendor_spec.js’ ’ new file: tests/node_modules/webdriverajaxstub/index.js’ ’ modified: translations/en.json’ ’ modified: translations/es.json’ ’ new file: translations/ms-my.json’ ’ modified: translations/translations.js’ ’ new file: untrack-css.sh’ ’ modified: vendor/package-lock.json’ ‘Unmerged paths:’ ’ (use “git add …” to mark resolution)’ ’ both modified: package-lock.json’ ‘Untracked files:’ ’ (use “git add …” to include in what will be committed)’ ’ css/save_custom.css’ ’ installers/dumpactivemodules.js’
                                              ++ git status
                                              ++ grep modified
                                              ++ awk -F: ‘{print $2}’
                                            • diffs=’ .eslintrc.json
                                              .gitignore
                                              .travis.yml
                                              CHANGELOG.md
                                              LICENSE.md
                                              js/main.js
