    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 17.9k Views 2 Watching
      sdetweil @DazTypeR
      @DazTypeR please try the new upgrade script (will be part of next release)
      see https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
        DazTypeR
        So i just CD into the MagicMirror directory and then run the top command, if that works, then run the 2nd?
          sdetweil @DazTypeR
          @DazTypeR no… don’t need to cd, just execute the script, it will figure it out and ask you to save any changed files
          note… first time is a test install, doesn’t change anything…
          then, if all is good, run it again with apply parameter
            DazTypeR
            OK, so I ran the first script, how do i actually know if it worked?
              sdetweil @DazTypeR
              @DazTypeR if you ran it without any parms at the end, it did not make ANY changes… it was a test, to make u feel comfortable and see the process once… (I don’t want to mess up your system, so it it find an error it cant fix, it tells you, and stops
              now, run it again and add the word ‘apply’ at the end
                DazTypeR
                Sorry, probably didnt make myself clear.
                I knew the 1st script would not make any changes, how do i know the script worked and did not mess anything up?
                I dont see any messages output to the command line, it just finished.
                Sorry about my lack of understanding, I`m trying to learn as I go but its a long slog.
                This is the last thing it put out…
                        fi
                        # return to original folder
                        cd - >/dev/null
                        date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
                else
                        echo It appears MagicMirror has not been installed on this system
                        echo please run the installer, "raspberry.sh" first
                fi
                  sdetweil @DazTypeR
                  @DazTypeR
                  ok… the UPDATE script only updates… do you have a ~/MagicMirror folder??
                  it sounded like you did, cause you were trying to do a git pull
                  just go run your mirror again… again, it makes NO changes to your local working copy.
                  (it did download updates to the local git repo (~/MagicMirror/.git folder), but did not apply any updates)
                  post the log from ~/MagicMirorr/installers/upgrade.log
                  please use the markdown code block feature…
                  paste the log text, select the text.
                  push the </> button
                    DazTypeR
                    Yes I have a MagicMirror folder as I have managed to run my mirror for 10 months and have managed to do 2 upgrades in that time but in the past it has always told me what the error is and mostly how to fix it.
                    With regards to posting the log, there is no upgrade.log file in that directory?
                      sdetweil @DazTypeR
                      @DazTypeR no log file… hm…
                      which sounds like your MagicMirror folder is not called ‘MagicMirror’
                      look in user home folder ~/
                        DazTypeR
                        It is called MagicMirror…
                        pi@raspberrypi:~/MagicMirror
                          sdetweil @DazTypeR
                          @DazTypeR ok, show me the log ~/upgrade.log or ~/MagicMirror/installers/upgrade.log
                            the upgrade script does this at the beginning
                            # if the MagicMirroe folder exists
                            if [ -d ~/MagicMirror ]; then
                            	# put the log where the script is located
                            	logdir=$(dirname $($cmd -f "$0"))
                            	# if the script was execute from the web
                            	if [[ $logdir != *"MagicMirror/installers"* ]]; then
                            		# use the MagicMirror/installers folder
                            		cd ~/MagicMirror/installers >/dev/null
                            		logdir=$(pwd)
                            		cd - >/dev/null
                            	fi
                            	logfile=$logdir/upgrade.log
                              DazTypeR
                              I can’t find an upgrade.log either in home or in the MagicMirror/installers folder.
                                sdetweil @DazTypeR
                                @DazTypeR well then
                                so, when u run it it says
                                if so, rerun the script like this
                                bash -c -x  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                                  DazTypeR
                                  Hang on, I just ran this command…
                                  Should I have run this command…
                                  bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)”
                                  No idea what the bash -c does?
                                  Would this have made a difference?
                                    sdetweil @DazTypeR
                                    @DazTypeR yes… if you do it without bash -c, then it downloads the file, and throws it away
                                    if you do the bash -c, then it executes the script (single command -c)
                                    watch out for the double quotes… sometimes those turn into MS word document quotes, which linux shells don’t like
                                      DazTypeR
                                      OK, so its official, I am a numpty :)
                                      This is what I get now when I run it…
                                      the log will be /home/pi/MagicMirror/installers/upgrade.log
                                      doing test run = true
                                      saving custom.css
                                      upgrading from version 2.9.0 to 2.9.0
                                      fetching latest revisions
                                      bash: line 159: On branch master: command not found
                                      there are 28 local files that are different than the master repo
                                      .eslintrc.json
                                      .gitignore
                                      .travis.yml
                                      CHANGELOG.md
                                      LICENSE.md
                                      installers/raspberry.sh
                                      js/main.js
                                      modules/default/calendar/vendor/ical.js/node-ical.js
                                      modules/default/clock/clock.js
                                      modules/default/currentweather/currentweather.js
                                      modules/default/newsfeed/newsfeed.js
                                      modules/default/updatenotification/node_helper.js
                                      modules/default/updatenotification/updatenotification.js
                                      modules/default/weather/providers/darksky.js
                                      modules/default/weather/providers/openweathermap.js
                                      modules/default/weather/providers/ukmetoffice.js
                                      modules/default/weather/providers/weathergov.js
                                      modules/default/weather/weather.js
                                      modules/default/weather/weatherprovider.js
                                      modules/default/weatherforecast/weatherforecast.js
                                      package.json
                                      run-start.sh
                                      tests/e2e/vendor_spec.js
                                      translations/en.json
                                      translations/es.json
                                      translations/translations.js
                                      vendor/package-lock.json
                                      package-lock.json
                                      any *-lock.json files do not need to be saved
                                      do you want to save these files for later (Y/n)?n
                                      skipping restore for .eslintrc.json, doing test run
                                      skipping restore for .gitignore, doing test run
                                      skipping restore for .travis.yml, doing test run
                                      skipping restore for CHANGELOG.md, doing test run
                                      skipping restore for LICENSE.md, doing test run
                                      skipping restore for installers/raspberry.sh, doing test run
                                      skipping restore for js/main.js, doing test run
                                      skipping restore for modules/default/calendar/vendor/ical.js/node-ical.js, doing test run
                                      skipping restore for modules/default/clock/clock.js, doing test run
                                      skipping restore for modules/default/currentweather/currentweather.js, doing test run
                                      skipping restore for modules/default/newsfeed/newsfeed.js, doing test run
                                      skipping restore for modules/default/updatenotification/node_helper.js, doing test run
                                      skipping restore for modules/default/updatenotification/updatenotification.js, doing test run
                                      skipping restore for modules/default/weather/providers/darksky.js, doing test run
                                      skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
                                      skipping restore for modules/default/weather/providers/ukmetoffice.js, doing test run
                                      skipping restore for modules/default/weather/providers/weathergov.js, doing test run
                                      skipping restore for modules/default/weather/weather.js, doing test run
                                      skipping restore for modules/default/weather/weatherprovider.js, doing test run
                                      skipping restore for modules/default/weatherforecast/weatherforecast.js, doing test run
                                      skipping restore for package.json, doing test run
                                      skipping restore for run-start.sh, doing test run
                                      skipping restore for tests/e2e/vendor_spec.js, doing test run
                                      skipping restore for translations/en.json, doing test run
                                      skipping restore for translations/es.json, doing test run
                                      skipping restore for translations/translations.js, doing test run
                                      skipping restore for vendor/package-lock.json, doing test run
                                      skipping restore for package-lock.json, doing test run
                                      processing for module MMM-GooglePhotos please wait
                                      skipped processing for MMM-GooglePhotos, doing test run
                                      processing complete for module MMM-GooglePhotos
                                      restoring custom.css
                                      It then put me back to the command line.
                                        sdetweil @DazTypeR
                                        @DazTypeR cool,just like it should have… altho… line 159 bothers me
                                        can you run it again without apply, and use the debug flag
                                        you will have to scroll back up in the terminal window, but I’d like to see the few lines above/below the error line 159
                                        thx
                                          DazTypeR
                                          Hope this has everything you need…
                                          • echo current branch = master
                                            ++ git status
                                          • ‘On branch master’ ‘Your branch and ‘'‘origin/master’'’ have diverged,’ ‘and have 4 and 76 different commits each, respectively.’ ’ (use “git pull” to merge the remote branch into yours)’ ‘You have unmerged paths.’ ’ (fix conflicts and run “git commit”)’ ’ (use “git merge --abort” to abort the merge)’ ‘Changes to be committed:’ ’ modified: .eslintrc.json’ ’ modified: .gitignore’ ’ modified: .travis.yml’ ’ modified: CHANGELOG.md’ ’ modified: LICENSE.md’ ’ deleted: css/custom.css’ ’ modified: installers/raspberry.sh’ ’ modified: js/main.js’ ’ modified: modules/default/calendar/vendor/ical.js/node-ical.js’ ’ modified: modules/default/clock/clock.js’ ’ modified: modules/default/currentweather/currentweather.js’ ’ modified: modules/default/newsfeed/newsfeed.js’ ’ modified: modules/default/updatenotification/node_helper.js’ ’ modified: modules/default/updatenotification/updatenotification.js’ ’ modified: modules/default/weather/providers/darksky.js’ ’ modified: modules/default/weather/providers/openweathermap.js’ ’ modified: modules/default/weather/providers/ukmetoffice.js’ ’ modified: modules/default/weather/providers/weathergov.js’ ’ modified: modules/default/weather/weather.js’ ’ modified: modules/default/weather/weatherprovider.js’ ’ modified: modules/default/weatherforecast/weatherforecast.js’ ’ modified: package.json’ ’ modified: run-start.sh’ ’ new file: tests/configs/modules/weather/currentweather_default.js’ ’ new file: tests/configs/modules/weather/currentweather_options.js’ ’ new file: tests/configs/modules/weather/currentweather_units.js’ ’ new file: tests/configs/modules/weather/forecastweather_default.js’ ’ new file: tests/configs/modules/weather/forecastweather_options.js’ ’ new file: tests/e2e/modules/mocks/index.js’ ’ new file: tests/e2e/modules/mocks/weather_current.js’ ’ new file: tests/e2e/modules/mocks/weather_forecast.js’ ’ new file: tests/e2e/modules/weather_spec.js’ ’ modified: tests/e2e/vendor_spec.js’ ’ new file: tests/node_modules/webdriverajaxstub/index.js’ ’ modified: translations/en.json’ ’ modified: translations/es.json’ ’ new file: translations/ms-my.json’ ’ modified: translations/translations.js’ ’ new file: untrack-css.sh’ ’ modified: vendor/package-lock.json’ ‘Unmerged paths:’ ’ (use “git add …” to mark resolution)’ ’ both modified: package-lock.json’ ‘Untracked files:’ ’ (use “git add …” to include in what will be committed)’ ’ css/save_custom.css’ ’ installers/dumpactivemodules.js’
                                            ++ git status
                                            ++ grep modified
                                            ++ awk -F: ‘{print $2}’
                                          • diffs=’ .eslintrc.json
                                            .gitignore
                                            .travis.yml
                                            CHANGELOG.md
                                            LICENSE.md
                                            js/main.js
                                            sdetweil @DazTypeR
                                            @DazTypeR cool, can u try that one more time (without apply) to see if I fixed the line 159 problem
