    Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
    9 Posts 4 Posters 2.7k Views 4 Watching
    • FLOW THE NOOBF
      FLOW THE NOOB
      I have a problem when I start the magic mirror. Everything seems to boot as it should but the google assistant does not listen to me. So I press the widget to start it manually but doesn’t listen either.
      Here you can see the part of the log where it gets errors:
      [HOTWORD] begins.
      [HOTWORD] Detector starts listening.
      [HOTWORD] stops.
      [HOTWORD] Final Result: { detected: false }
      [HOTWORD] begins.
      [AMK2] assistant ready
      [AMK2] Conversation starts.
      [AMK2] Started with text query: brief today
      { requestId: ‘5dbd29c0-0000-2458-852e-089e08276030’ } { profileFile: ‘default.json’, lang: ‘en-US’ }
      [AMK2] Device Action: { requestId: ‘5dbd29c0-0000-2458-852e-089e08276030’ }
      [AMK2] Assistant Text Response:
      [AMK2] Conversation Completed
      [HOTWORD] stops.
      [HOTWORD] begins.
      [AMK2] Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
      at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:91:15)
      at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:233:26)
      at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:211:8)
      at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1306:15)
      at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:568:42)
      at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:618:8)
      at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1123:18
      code: 14,
      metadata:
      Metadata { _internal_repr: { ‘content-disposition’: [Array] }, flags: 0 },
      details: ‘Service unavailable.’ }
      1_1572718840181_Captura de pantalla (18).png 0_1572718840181_Captura de pantalla (17).png
        A Former User
        Remove useWelcomeMessage. It needs more complex configuration. If you don’t need it really, just remove from config.js
        • FLOW THE NOOBF
          FLOW THE NOOB
          Still doesn’t work. It shouldn’t be a mic problem because it gets detected and I can record myself.
          Getting this log:
          pi@raspberrypi:~ $ cd MagicMirror
          magicmirror@2.9.0 start /home/pi/MagicMirror
          sh run-start.sh
          Starting MagicMirror: v2.9.0
          Loading config …
          Loading module helpers …
          Module helper loaded: MMM-Hotword
          Module helper loaded: MMM-AssistantMk2
          All module helpers loaded.
          Starting server on port 8080 …
          Server started …
          Starting module: newsfeed
          Connecting socket for: MMM-Hotword
          [HOTWORD] MMM-Hotword starts
          Connecting socket for: MMM-AssistantMk2
          Sockets connected & modules started …
          Launching application.
          Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
          Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          [AMK2] Recipe is loaded: hide_and_show_all_modules.js
          [AMK2] Recipe is loaded: reboot.js
          [AMK2] Recipe is loaded: screen_onoff.js
          [AMK2] Recipe is loaded: shutdown.js
          [AMK2] Temporal storage directory is clearing.
          [HOTWORD] begins.
          [HOTWORD] stops.
          [HOTWORD] begins.
          code: 14,
          metadata:
          • FLOW THE NOOBF
            FLOW THE NOOB
            I solved it!!. The assistant mk2 module now hears to my mic! and answers!
            0 1 Reply Last reply Reply Quote 0
            • 0
              09succotash @FLOW THE NOOB
              @FLOW-THE-NOOB How did you solve it? Im having the same issue, please tell me.
              FLOW THE NOOBF 1 Reply Last reply Reply Quote 0
              • FLOW THE NOOBF
                FLOW THE NOOB @09succotash
                @09succotash Go to your desktop. Right click on the volume icon. Choose your recording and playback devices. Adjust their volumes to max in audio device settings.
                • 0
                  09succotash
                  Oh, ok. That makes sense.
                    juantata @FLOW THE NOOB
                    @FLOW-THE-NOOB
                    Hi. I have the same problem, the only difference is that I have the speakers for HDMI. Any solution?
                    • FLOW THE NOOBF
                      FLOW THE NOOB @juantata
                      @juantata
                      Putting sound through hdmi didn’t work for me neither. Only USB and headphone jack worked for me for speakers. The mic has to be a usb one though.
