    Create another config.js file
    config.js
    6 Posts 3 Posters 1.5k Views 3 Watching
      sdetweil @BigMan
      @BigMan I would create different scripts, and copy your specific config.js into the config folder as config.js.
        BigMan
        @sdetweil can you please elaborate more on your response. If you can, with examples too. Thanks!
          sdetweil @BigMan
          @BigMan create a folder called ~/MagicMirror/myConfigs
          place you config1, config2 … confign…js in there
          MM starts with a script installers/mm.sh (or u can create your own)
          anyhow…
          lets create run1.sh in installers
          #!/bin/bash
          # copy my config.js into the folder with the required name
          cp ~/MagicMirror/myConfigs/config1.js ~/MagicMirror/config/config.js
          # then call mm.sh
          exec ~/MagicMirror/installers/mm.sh
          then after saving, do
          chmod +x run1.sh
          then whenever u want to run MM with config1
          just do
          ~/MagicMirror/installers/run1.sh
          u can shorten the commands if u are in the MagicMirror folder at the time…
          create as many run?.sh as u need
          I might save the original config.js in your folder too
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @BigMan
            @BigMan Since version 2.1.1 this is natively supported by MagicMirror²
            Enable ability to set configuration file by the environment variable called MM_CONFIG_FILE.
            To test it you can run MM_CONFIG_FILE=YOUR_PATH_TO_CONFIG_FILE npm start in the terminal.
              @BigMan said in Create another config.js file:
              even easier!
              put all your configs into the config folder
              then just set which on to use
               #!/bin/bash
               # set my config
               export MM_CONFIG_FILE=~/MagicMirror/config/config1.js
               # then call mm.sh
              thanks @strawberry-3-141
