    Create another config.js file
    config.js
    6 Posts 3 Posters 1.5k Views 3 Watching
      BigMan
      Hi, so for a project that I’m working on, I want to create multiple config.js files and name them like config1.js, config2.js and etc. But in order to open on of them (so like the config2.js for example) while booting the MagicMirror, I need to change the path or the configuration that defaults it to config.js. Does anyone know how I can do that?
      S strawberry 3.141S 2 Replies Last reply Reply Quote 0
        sdetweil @BigMan
        @BigMan I would create different scripts, and copy your specific config.js into the config folder as config.js.
          BigMan
          @sdetweil can you please elaborate more on your response. If you can, with examples too. Thanks!
            sdetweil @BigMan
            @BigMan create a folder called ~/MagicMirror/myConfigs
            place you config1, config2 … confign…js in there
            MM starts with a script installers/mm.sh (or u can create your own)
            anyhow…
            lets create run1.sh in installers
            #!/bin/bash
            # copy my config.js into the folder with the required name
            cp ~/MagicMirror/myConfigs/config1.js ~/MagicMirror/config/config.js
            # then call mm.sh
            exec ~/MagicMirror/installers/mm.sh
            then after saving, do
            chmod +x run1.sh
            then whenever u want to run MM with config1
            just do
            ~/MagicMirror/installers/run1.sh
            u can shorten the commands if u are in the MagicMirror folder at the time…
            create as many run?.sh as u need
            I might save the original config.js in your folder too
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @BigMan
              @BigMan Since version 2.1.1 this is natively supported by MagicMirror²
              Enable ability to set configuration file by the environment variable called MM_CONFIG_FILE.
              To test it you can run MM_CONFIG_FILE=YOUR_PATH_TO_CONFIG_FILE npm start in the terminal.
                @BigMan said in Create another config.js file:
                even easier!
                put all your configs into the config folder
                then just set which on to use
                 #!/bin/bash
                 # set my config
                 export MM_CONFIG_FILE=~/MagicMirror/config/config1.js
                 # then call mm.sh
                thanks @strawberry-3-141
