Solved MMM-Lunartic not working
Hi, I think the website is down…
Anyone the same Problem -
@Stoffbeuteluwe said in MMM-Lunartic not working:
Anyone the same ProblemYes, the US Naval Obvservatory api that supplies the images is down. This happened once before and I’ve included a temporary fix MMM-Lunartic.js file in the repo for just such an occasion. Rename your current MMM-Lunartic.js file to MMM-Lunartic.bak and copy the file from the temporary fix folder and paste it at the root of the MMM-Lunartic folder. Run your mirror.
I will notify when the api is up. It might be April before that happens but the module will work as expected.
it’s working for me…
@Mykle1 Thank you very much :folded_hands_medium_skin_tone:
Thank you very much
Can you verify that the fix works for you?
@Mykle1 Works :thumbs_up_medium_skin_tone:
Works! April till its operational? Thats ~6 months from now.
@BD0G said in MMM-Lunartic not working:
The module works with the fix I’ve provided. You won’t notice the difference, but yes, the USNO api is undergoing maintenance and has set that date for its completion.
@Mykle1 Thank you for the fix! and for the module, its awesome
So you just pulled the static images from that USNO site and have them stored locally on the Pi. Then just call each static image as the phases of the moon change. Correct? With this approach it hardly seems like we are missing anything by not connecting to the USNO site and downloading them.
