    MMM-DumpsterDay
    83 Posts 11 Posters 68.9k Views 12 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @DeanoNoire
      @DeanoNoire a blue can would be Perfect Thanks :folded_hands_medium-light_skin_tone:
        BD0G @Stoffbeuteluwe
        @Stoffbeuteluwe Its included within the trashcan.css file , but waiting on configuration options and how to setup.
          Stoffbeuteluwe Project Sponsor @BD0G
          @BD0G ok Thanks
            DeanoNoire @BD0G
            @BD0G Hi there,
            I added the install instructions and example of config with descriptions to the readme file.
            I’ll copy it here also:
            	module:"trashcan",
            	position:"lower_third",
            		refreshInterval: 18000000, // Default: 18000000 = 5 hours
            		pulse: true, 			   // Default: true - Makes the module pulsating
            		enableBasic: true, 				// Enable basic trashcan
            		basicStartDate: "24.10.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
            		basicDateDiff_1: 14,			// Trashday reoccurance - Default: 14 (every 14 days)
            		basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
            		enablePlastic: true,			// Same values as basic but for Plastic
            		plasticStartDate: "16.01.2019",
            		plasticDateDiff_1: 28,
            		plasticNotifyDayBefore: true,
            		enableLandscape: false,			// Same values as basic but for Landscape
            		landscapeStartDate: "29.10.2019",
            		landscapeDateDiff_1: 28,
            		landscapeNotifyDayBefore: true,
            I hope it’s clear now :)
            Also note the module should not appear today, as it’s not a dumpster day :) Try changing the Start date in the config to make it appear it’s dumpster day today to test it. I may also implement a AlwaysOn config key for testing purposes. Maybe during the week :)
            If anything is unclear or can be improved, please let me know :)
              BD0G
              Many of the other modules that are published use the following syntax to copy the files needed to the MagicMirror/modules directory.
              git clone https://github.com/DeanoNoire/MMM-DumpsterDay.git
              So perhaps it would be advantageous to add the following as the first step.
              1. Navigate to the MagicMirror/modules sub-directory
              2. Run the following command “git clone https://github.com/DeanoNoire/MMM-DumpsterDay.git” (this will copy the needed files into the sub-directory)
                BD0G
                Also the code for the config.js appears to be missing
                at the end.
                  BD0G
                  I switched to the sub directory MagicMirror/modules and did a git clone git clone https://github.com/DeanoNoire/MMM-DumpsterDay.git
                  That created a directory named MMM-DumpsterDay with the files below that directory.
                  Then I added the code you posted to my MagicMirror/config/config.js file exactly as you posted. I found that there was a missing }, at the end of the code.
                  I modified the config.js to reflect today as trashday and launched Magic Mirror . Nothing was displayed onscreen.
                  Shoundlnt the config.js code for module be MMM-DumpsterDay
                    BD0G
                      BD0G
                      Here is my current config.js after renaming the module portion to MMM-DumpsterDay
                      	module:"MMM-DumpsterDay",
                      	position:"bottom_bar",
                      		basicStartDate: "11.10.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                      		basicDateDiff_1: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
                      		enablePlastic: false,			// Same values as basic but for Plastic
                      		enableLandscape: true,			// Same values as basic but for Landscape
                      		landscapeStartDate: "11.10.2019",
                      		landscapeDateDiff_1: 14,
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar"
                      			module: "clock",
                      			position: "top_left"
                        DeanoNoire @BD0G
                        @BD0G this seems right :)
                        Thanks for the tips! I will change the installation process :) I’m still new, this is my first real programming project, so this colaboration process is new to me.
                          BD0G
                          Well I am kinda forced to collaborate if I want to use this awesome module . Right? :) LOL
                          My config.js does not work so I want to get it going so we can all use this module!
                            DeanoNoire @BD0G
                            @BD0G i will give it a try with your config and check what’s wrong and let you know.
                              DeanoNoire @BD0G
                              @BD0G Hey there, I changed the file names of the modules and the paths, so it can be used the way you described - via clone.
                              Can pull the current version and give it a try? Also change the date accordingly :) I believe we’re getting there! :D
                              Have a good one.
                                BD0G @DeanoNoire
                                @DeanoNoire
                                I deleted the sub-directory that was created under MagicMirror/modules named mmm-dumpsterday . All lowercase.
                                I then used the command git clone https://github.com/DeanoNoire/MMM-DumpsterDay.git.
                                This created the correct the directory named MMM-DumpsterDay . Capital letters in proper places.
                                Then I modified my config.js under the MagicMirror/config directory to reflect today as being trash day . Turned off Recycle by using the false specifier. Turned on Landscape by using the specifier true. Set the Landscape date to todays date as well.
                                Restarted the MagicMirror and I do see a pulsing white trash can ,BUT no can for Landscape. ???
                                The trash can is displayed within the bottom_bar area of the screen and the trash can is quiet large onscreen. I am assuming that I can modify the MagicMirror/modules/MMM-DumpsterDay/MMM-DumpsterDay.css file to change the size to better fit the screen?
                                Here is my current config.js file to troubleshoot the absence of the Landscape can. on screen
                                		basicStartDate: "11.11.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                                		landscapeStartDate: "11.11.2019",
                                			module: "alert",
                                  BD0G
                                  Also, I dont know how much additional code would be needed to display the words
                                  Tomorrow is Trash Day
                                  for the day preceding what one sets for Trash Day and then the words Today is Trash Day
                                  for the day in which is actually trash day. This would be in small text (alterable within the .css file) below the trash can icons. That way one would know at a glance.
                                    mrdenmark
                                    @DeanoNoire
                                    i have this module working and it looks good,thanks
                                    i would like to use the basic,recycle_blue and recycle_yellow bins,how do i modify the config to work with those?
                                      BD0G @mrdenmark
                                      @mrdenmark
                                      Try this setup in your MagicMirror/config/config.js
                                      		plasticStartDate: "11.11.2019",
                                      		landscapeDateDiff_1: 7,
                                      Then just modify the MagicMirror/modules/MMM-DumpsterDay/MMM-DumpsterDay.css file to have the Landscape setting display a blue can.
                                      .landscapeDiv{
                                      	height:70px;
                                      	width:20%;
                                      	background-image: url(imgs/recycle_blue.png);
                                      	background-repeat: no-repeat;
                                      	background-position: center center;
                                      	background-size: contain;
                                      	overflow: auto;
                                      	display:inline-block;
                                      If you want the Blue can next to the White can instead of the Yellow Can then just modify the MagicMirror/modules/MMM-DumpsterDay/MMM-DumpsterDay.css file like this
                                      .plasticDiv{
                                      	height:70px;
                                      	width:20%;
                                      	overflow: auto;
                                      .landscapeDiv{
                                      	height:70px;
                                      	width:20%;
                                      	background-image: url(imgs/recycle_yellow.png);
                                      	overflow: auto;
                                        mrdenmark @BD0G
                                        @BD0G
                                        thanks for that,one last thing,is it possible change the colour of the basic bin?in my case i’d like red.
                                          BD0G
                                          Give me a few minutes and I will try and fill the one that is white with a red color.
                                            BD0G
                                            Save the file I uploaded (right click -Save Image As) to this directory MagicMirror/modules/MMM-DumpsterDay/imgs
                                            Then change your MagicMirror/modules/MMM-DumpsterDay/MMM-DumpsterDay.css file so that it has this entry
                                            .basicDiv{
                                            	height:70px;
                                            	width:20%;
                                            	background-image: url(imgs/basic_red.png);
                                            	overflow: auto;
                                            • 1 / 5
