    MMM-DumpsterDay
    83 Posts 11 Posters 71.7k Views 12 Watching
      DeanoNoire
      Description:
      This module works as a reminder to take the dumpster from the driveway to the gate on every odd Tuesday and Monday before. Although the use sounds very specific, it can be easily changed to any reminder on recurring days.
      Screenshot:
      alt text
      Download:
      [card:DeanoNoire/MMM-DumpsterDay]
      Version 1.0
      Initial version
      Version 1.1
      Now there are 3 possible cans, user can disable each one in config or change the image via css.
      Pulsing is now switchable.
      Changed the startDate input format.
      Thank you for your time and constructive criticism! :)
      StoffbeuteluweS 1 Reply Last reply
      Reply Quote 2
        BD0G
        I think I may install this module as it sounds handy. Here we can only put out our Landscape cans every 2 weeks as they will not pick them up every week. I get confused sometimes as to which week it is “Landscape Week” or “Non-Landscape Week”. Would it be possible to alter the code to display a different style pulsing Icon for Landscape cans. Actually 2 Trash cans would be nice. One White for the regular trash can and one Green -signifying the color of the landscape can. If this is possible why not add an option to have all three colors represented.
        White = Standard trash Can
        Green=Landscape
        Blue=Recycle
        Oh, you misspelled Dumpster in the title of the post and spelled Dupster instead.
          DeanoNoire
          @BD0G That’s actually pretty good idea!
          In my town Recycle cans are put every 28 days, so I will definitelly use that feature too.
          I will work that in.
          Have a good one :)
            BD0G
            Cant Wait! With these changes I can then simply walk by my Magic Mirror on trash day and if I see one White Icon then its Trash “only” day. Or if I see a white Trash Icon and a Green Icon I will know I can put both Trash and Landscape out on the street. Saves me from having to consult a schedule that the trash provider sends us.
            Maybe another option in code to change to constant or pulsing icons???
            D 1 Reply Last reply
              DeanoNoire @BD0G
              @BD0G So I’ve made some changes:
              Pulsing is now switchable and I also changed the startDate input format.
              alt text
              Check it out ;)
              EDIT: I also added a blue version of the recylcing can as you mentioned (In Czech Republic it’s yellow)
              B 1 Reply Last reply
                mrdenmark
                could you post a working config for this? i’m having no luck writing it into mine
                  BD0G @DeanoNoire
                  @DeanoNoire
                  You are awesome! .
                  We will need a working config file with all the parameters listed so that it is apparent what settings control what features.
                  You can comment out the features using // backslashes as you know and add what they do to the right of the line or above it using // backslashes
                  Example :
                  //Line below this one controls the day that one sets to count from
                  //Line below this one controls pulsing or constant
                  etc…
                  Also is there the need to clone a module into the modules directory below MagicMirror/modules?
                  Specific instructions would be helpful to add to the git hub repository as there are alot of places where people can get hung up.
                  Questions that I have are where does one place the trashcan.css file? Where does one place the trashcan.js file?
                  Does one clone a directory into the MagicMirror/modules directory?
                  What does one add to the config.js file within MagicMirror/config?
                  Also you mis-spelled Dumpster again within the Noted files on the git hub repository.
                  Thanks for the quick work!
                  Let me know if you need assistance with writing the instructions and I can lend a hand if needed.
                  • StoffbeuteluweS
                    Stoffbeuteluwe Project Sponsor @DeanoNoire
                    @DeanoNoire a blue can would be Perfect Thanks :folded_hands_medium-light_skin_tone:
                      BD0G @Stoffbeuteluwe
                      @Stoffbeuteluwe Its included within the trashcan.css file , but waiting on configuration options and how to setup.
                      • StoffbeuteluweS
                        Stoffbeuteluwe Project Sponsor @BD0G
                        @BD0G ok Thanks
                          DeanoNoire @BD0G
                          @BD0G Hi there,
                          I added the install instructions and example of config with descriptions to the readme file.
                          I’ll copy it here also:
                          	module:"trashcan",
                          	position:"lower_third",
                          		refreshInterval: 18000000, // Default: 18000000 = 5 hours
                          		pulse: true, 			   // Default: true - Makes the module pulsating
                          		enableBasic: true, 				// Enable basic trashcan
                          		basicStartDate: "24.10.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                          		basicDateDiff_1: 14,			// Trashday reoccurance - Default: 14 (every 14 days)
                          		basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
                          		enablePlastic: true,			// Same values as basic but for Plastic
                          		plasticStartDate: "16.01.2019",
                          		plasticDateDiff_1: 28,
                          		plasticNotifyDayBefore: true,
                          		enableLandscape: false,			// Same values as basic but for Landscape
                          		landscapeStartDate: "29.10.2019",
                          		landscapeDateDiff_1: 28,
                          		landscapeNotifyDayBefore: true,
                          I hope it’s clear now :)
                          Also note the module should not appear today, as it’s not a dumpster day :) Try changing the Start date in the config to make it appear it’s dumpster day today to test it. I may also implement a AlwaysOn config key for testing purposes. Maybe during the week :)
                          If anything is unclear or can be improved, please let me know :)
                            BD0G
                            Many of the other modules that are published use the following syntax to copy the files needed to the MagicMirror/modules directory.
                            git clone https://github.com/DeanoNoire/MMM-DumpsterDay.git
                            So perhaps it would be advantageous to add the following as the first step.
                            1. Navigate to the MagicMirror/modules sub-directory
                            2. Run the following command “git clone https://github.com/DeanoNoire/MMM-DumpsterDay.git” (this will copy the needed files into the sub-directory)
                              BD0G
                              Also the code for the config.js appears to be missing
                              at the end.
                                BD0G
                                I switched to the sub directory MagicMirror/modules and did a git clone git clone https://github.com/DeanoNoire/MMM-DumpsterDay.git
                                That created a directory named MMM-DumpsterDay with the files below that directory.
                                Then I added the code you posted to my MagicMirror/config/config.js file exactly as you posted. I found that there was a missing }, at the end of the code.
                                I modified the config.js to reflect today as trashday and launched Magic Mirror . Nothing was displayed onscreen.
                                Shoundlnt the config.js code for module be MMM-DumpsterDay
                                  BD0G
                                    BD0G
                                    Here is my current config.js after renaming the module portion to MMM-DumpsterDay
                                    	module:"MMM-DumpsterDay",
                                    	position:"bottom_bar",
                                    		basicStartDate: "11.10.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                                    		basicDateDiff_1: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
                                    		enablePlastic: false,			// Same values as basic but for Plastic
                                    		enableLandscape: true,			// Same values as basic but for Landscape
                                    		landscapeStartDate: "11.10.2019",
                                    		landscapeDateDiff_1: 14,
                                    			module: "alert",
                                    			module: "updatenotification",
                                    			position: "top_bar"
                                    			module: "clock",
                                    			position: "top_left"
                                      DeanoNoire @BD0G
                                      @BD0G this seems right :)
                                      Thanks for the tips! I will change the installation process :) I’m still new, this is my first real programming project, so this colaboration process is new to me.
                                        BD0G
                                        Well I am kinda forced to collaborate if I want to use this awesome module . Right? :) LOL
                                        My config.js does not work so I want to get it going so we can all use this module!
                                        D 2 Replies Last reply
                                          DeanoNoire @BD0G
                                          @BD0G i will give it a try with your config and check what’s wrong and let you know.
                                            DeanoNoire @BD0G
                                            @BD0G Hey there, I changed the file names of the modules and the paths, so it can be used the way you described - via clone.
                                            Can pull the current version and give it a try? Also change the date accordingly :) I believe we’re getting there! :D
                                            Have a good one.
                                            • 1 / 5
