    MMM-DumpsterDay
    83 Posts 11 Posters 56.9k Views 12 Watching
      BD0G
      I think I may install this module as it sounds handy. Here we can only put out our Landscape cans every 2 weeks as they will not pick them up every week. I get confused sometimes as to which week it is “Landscape Week” or “Non-Landscape Week”. Would it be possible to alter the code to display a different style pulsing Icon for Landscape cans. Actually 2 Trash cans would be nice. One White for the regular trash can and one Green -signifying the color of the landscape can. If this is possible why not add an option to have all three colors represented.
      White = Standard trash Can
      Green=Landscape
      Blue=Recycle
      Oh, you misspelled Dumpster in the title of the post and spelled Dupster instead.
        DeanoNoire
        @BD0G That’s actually pretty good idea!
        In my town Recycle cans are put every 28 days, so I will definitelly use that feature too.
        I will work that in.
        Have a good one :)
          BD0G
          Cant Wait! With these changes I can then simply walk by my Magic Mirror on trash day and if I see one White Icon then its Trash “only” day. Or if I see a white Trash Icon and a Green Icon I will know I can put both Trash and Landscape out on the street. Saves me from having to consult a schedule that the trash provider sends us.
          Maybe another option in code to change to constant or pulsing icons???
            DeanoNoire @BD0G
            @BD0G So I’ve made some changes:
            Now there are 3 possible cans, user can disable each one in config or change the image via css.
            Pulsing is now switchable and I also changed the startDate input format.
            alt text
            Check it out ;)
            EDIT: I also added a blue version of the recylcing can as you mentioned (In Czech Republic it’s yellow)
              mrdenmark
              could you post a working config for this? i’m having no luck writing it into mine
                BD0G @DeanoNoire
                @DeanoNoire
                You are awesome! .
                We will need a working config file with all the parameters listed so that it is apparent what settings control what features.
                You can comment out the features using // backslashes as you know and add what they do to the right of the line or above it using // backslashes
                Example :
                //Line below this one controls the day that one sets to count from
                //Line below this one controls pulsing or constant
                etc…
                Also is there the need to clone a module into the modules directory below MagicMirror/modules?
                Specific instructions would be helpful to add to the git hub repository as there are alot of places where people can get hung up.
                Questions that I have are where does one place the trashcan.css file? Where does one place the trashcan.js file?
                Does one clone a directory into the MagicMirror/modules directory?
                What does one add to the config.js file within MagicMirror/config?
                Also you mis-spelled Dumpster again within the Noted files on the git hub repository.
                Thanks for the quick work!
                Let me know if you need assistance with writing the instructions and I can lend a hand if needed.
                • StoffbeuteluweS Offline
                  Stoffbeuteluwe Project Sponsor @DeanoNoire
                  @DeanoNoire a blue can would be Perfect Thanks :folded_hands_medium-light_skin_tone:
                    BD0G @Stoffbeuteluwe
                    @Stoffbeuteluwe Its included within the trashcan.css file , but waiting on configuration options and how to setup.
                      Stoffbeuteluwe Project Sponsor @BD0G
                      @BD0G ok Thanks
                        DeanoNoire @BD0G
                        @BD0G Hi there,
                        I added the install instructions and example of config with descriptions to the readme file.
                        I’ll copy it here also:
                        	module:"trashcan",
                        	position:"lower_third",
                        		refreshInterval: 18000000, // Default: 18000000 = 5 hours
                        		pulse: true, 			   // Default: true - Makes the module pulsating
                        		enableBasic: true, 				// Enable basic trashcan
                        		basicStartDate: "24.10.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                        		basicDateDiff_1: 14,			// Trashday reoccurance - Default: 14 (every 14 days)
                        		basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
                        		enablePlastic: true,			// Same values as basic but for Plastic
                        		plasticStartDate: "16.01.2019",
                        		plasticDateDiff_1: 28,
                        		plasticNotifyDayBefore: true,
                        		enableLandscape: false,			// Same values as basic but for Landscape
                        		landscapeStartDate: "29.10.2019",
                        		landscapeDateDiff_1: 28,
                        		landscapeNotifyDayBefore: true,
                        I hope it’s clear now :)
                        Also note the module should not appear today, as it’s not a dumpster day :) Try changing the Start date in the config to make it appear it’s dumpster day today to test it. I may also implement a AlwaysOn config key for testing purposes. Maybe during the week :)
                        If anything is unclear or can be improved, please let me know :)
                        • 1 / 9
