    Monitor goes to sleep within minutes
    13 Posts 2 Posters 6.3k Views 2 Watching
    • N Offline
      Newbie007
      I have installed MM a week back it was all fine however since couple of days my monitor goes to sleep mode within minutes of powering on RPi.
      Post installing I was playing around with couple of modules but one suspect might be PIR-Sensor though I have it disconnected currently.
      My setup to disable sleep mode:
      sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
      Added below part
      @xset s noblank
      @xset s off
      @xset -dpms
      I couldn’t find [SeatDefaults] so as a trial I made changes in Seat Configuration and [Seat : *]
      /etc/lightdm/lightdm.conf
      Config
      alt text
        sdetweil @Newbie007
        @Newbie007 said in Monitor goes to sleep within minutes:
        xset s noblank
        xset s off
        xset -dpms
        you can issue those commands manually
        or you have to reboot to disable screensaver
        • N Offline
          Newbie007 @sdetweil
          @sdetweil i’ve already issues those commands during mm setup. Once monitor goes to sleep im unable to even wake it up
          • N Offline
            Newbie007
            I am not even sure how to wake up the screen, I don’t have keyboard just the mouse moving that doesn’t help
              sdetweil @Newbie007
              @Newbie007 ok, so mouse is shown… and moves… this is not screen saver…
              so, it appears MM is showing black screen
              you need a keyboard to be able to get to the debug info
              • N Offline
                Newbie007
                @sdetweil said in Monitor goes to sleep within minutes:
                I actually doubt that cause before going to sleep my monitor shows the default “HDMI” text which is usually shown before boot as well
                  sdetweil @Newbie007
                  @Newbie007 hm… well, if you reboot it, run my screensaver setup script…
                  see
                  https://forum.magicmirror.builders/topic/11052/new-script-for-screensaver-disable
                  post the log after from
                  ~/screensaver.log
                  • N Offline
                    Newbie007
                    This is what I got
                    lxsession screen saver already disabled
                      sdetweil @Newbie007
                      @Newbie007 PIR-Sensor… is that module still in config.js?
                      you can disable it by adding
                        disabled: true,
                      to that module config, after the module: statement
                      note that PIR has some dependencies, which can cause black screen…
                      • N Offline
                        Newbie007
                        PIR-Sensor
                        Damn! You are right.
                        I commented whole PIR-Sensor in config.js but I followed this method as well and forgot about it.
                        Currently I have unplugged my PIR, let me plug it again and report back to you.
                        But in mean time how can I disable this?
                          sdetweil @Newbie007
                          what? the module? I gave u instructions in the prior post
                            sdetweil @Newbie007
                            I don’t see a ‘method’ there… its a 4 page topic
                            • N Offline
                              Newbie007 @sdetweil
                              I thought I linked you to a comment in that thread which details how to use PIR sensor to turn on/off monitor along with LED lights which is apart from PIR-Sensor module.
                              I commented out the module but forgot about the standalone script. Now we are good.
                              Thanks for your help!
