new script for screensaver disable
the install script processing for screen saver disable isn’t working anymore, and we have a lot more platforms where users need help…
I have updated my install script to include a new approach…, supports mac too
but I want to test it out… so I have made a standlone script with just that part of the processing…
once tested I will include this in the submission to update the install scriptgive it a try and let me know
it will create a little logfile (screensaver.log) in the users home folder
bash -c "$(curl -sL https://www.dropbox.com/s/ah7wtk30101xx4t/test_screensaver.sh?dl=0)"thanks
You are so freakin awesome. Here is the output from my new/current dev machine. Ubuntu 18.04.3 LTS and MM 2.8.0. As your script so accurately put it, Ubuntu DOES have a built in screensaver which can be configured/disabled manually. I thought you might want the information from this test. My thanks to you, Sam, again and again. :thumbsup:
pop@E8300:~$ bash -c "$(curl -sL https://www.dropbox.com/s/ah7wtk30101xx4t/test_screensaver.sh?dl=0)" some other screensaver gsd-screensaver please configure it manually pop@E8300:~$screensaver.log confirms terminal output
@Mykle1 i think the gsettings command will allow scripted configuration… I sent u a command to test…
my 18.04 does not have gsd-screensaver running
Hello,
I ran this script a a fresh install of “Raspbian Buster with desktop, July 2019” on a Raspberry Pi 3 B. I got this output:pi@magicmirror:~ $ bash -c "$(curl -sL https://www.dropbox.com/s/ah7wtk30101xx4t/test_screensaver.sh?dl=0)" some other screensaver bash please configure it manuallyI guess the latest Raspian shall be support. Fell free to ask me for some additional information or traces from my setup.
Regards DirkEdit:
Currently trying out this manual method: https://www.raspberrypi.org/forums/viewtopic.php?t=249837&p=1525721 -
@mieserwicht i hope you can try the test script again… see if I corrected the problem…
@sdetweil said in new script for screensaver disable:
I’m just reporting that your script works for me. Ubuntu 18.04.3 and MM 2.8.0.
I’d also like to thank you again for all the help you’ve given me and all the scripts you’ve made available to everyone, not to mention all the tech support you give to everyone.
Voter for Sam! :-)
@Mykle1 thanks. But not looking for a pat on the back.
I cannot create modules like you do. I love what you produce, I just don’t have that eye.
But I love the technical support challenge. Learning all these modules. Looking at the code, thinking of fixes.
Yes, this is part of the reason I wanted to express my gratitude. I see the time and effort that you put in to help others. It is commendable. :thumbsup:
Ahh, thank you for your kind words. I do appreciate that. I’ve had so much fun learning code and creating things. There are a few people here that were kind enough and patient enough to help me. You are not least among them.
Case in point.
I tried again. The script ran without any console output.
As result the config:@xset s noblank @xset s off @xset -dpmswas now doubled (first I added by hand, second from your script) in the file /etc/xdg/lxsession/LXDE-pi/autostart
@mieserwicht fabulous… thanks… i did NOT check if already set…
try it again, should not double it now and should say already disabled in the log file
Get an error message now:pi@magicmirror:~ $ bash -c "$(curl -sL https://www.dropbox.com/s/ah7wtk30101xx4t/test_screensaver.sh?dl=0)" grep: ungültiges Argument „pms“ für „--directories“ Gültige Argumente sind: - „read“ - „recurse“ - „skip“ Usage: grep [OPTION]... PATTERNS [FILE]... „grep --help“ liefert weitere Informationen.Edit: And it still adds the configs to the autostart file, even if they already exist
@mieserwicht yeh, had to escape the - on -dpms… try again
adding again, yes, it got an empty result due to the error
