    MMM-CalendarExt2: Module not showing
    6 Posts 3 Posters 2.6k Views 3 Watching
    • F Offline
      flemmingss
      I have used MMM-CalendarExt before and now I try to change to MMM-CalendarExt2, but I don’t manage to get it showing.
      This is my module config:
      	modules:
      			module: "alert",
      			module: "updatenotification",
      			module: 'MMM-CalendarExt2',
      			position: 'middle_center',
      			  calendars : [
      					url: "webcal://www.google.com/calendar/ical/flemmingss%40gmail.com/private-XXX/basic.ics",
      					url: "https://calendar.google.com/calendar/ical/XXX%40group.calendar.google.com/private-XXX/basic.ics",
      					url: "webcal://www.facebook.com/ical/u.php?uid=XXX&key=XXX",
      			  views: [
      					mode: "month",
      			  scenes: [
      And this is what I see:
      alt text
      Anyone spot a mistake? The url’s are the same as in the old module, and the config is exact as the readme describes as basic config
      • F Offline
        flemmingss
        problem detected :D
        turns out MMM-CalendarExt2 did not support webcal:// like MMM-CalendarExt. Så I replaced all webcall;// with https:// and now it works.
          A Former User @flemmingss
          @flemmingss
          views: [
              mode: "month",
              calendars: [],
          scenes: [
              views: [],
            Svensson_Jesper
            I have the same problem as above post.
            		position: 'top_left',
            		    calendars : [
            			    name: "US holiday",
            			    icon: "noto-beach-with-umbrella",
            			    className: "holiday",
            			    url: "http://www.calendarlabs.com/templates/ical/US-Holidays.ics",
            		    views: [
            			mode: "month",
            			calendars: [],
            		    scenes: [
            			views: [],
            WIth this code I get the same picture as above.
            I have no problem with the standard calendar.
              A Former User @Svensson_Jesper
              @Svensson_Jesper
              1. Remove module position. This module doesn’t need position of module itself. Instead, set the position of each view in view configuration.
              2. Your ical is not valid. It seems out-of-date. There is no valid events to load on this period.
                Use other url like http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics instead of yours.
              Then, it will show like this;
              (I assigned bottom_bar as the position of the view)
              • F Offline
                flemmingss @Guest
                @Sean said in MMM-CalendarExt2: Module not showing:
                Jus t a black screen
                views: [
                mode: “month”,
                calendars: [],
                scenes: [
                views: [],
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	ipWhitelist: [],                                       // Set [] to allow all IP addresses
                	language: "nb",
                	timeFormat: 24,
                	units: "metric",
                	modules:
                			module: "alert",
                				views: [
                					  mode: "month",
                				  scenes: [
                					  views: [],
                • F Offline
                  flemmingss
                  problem detected :D
