    pm2 dosn`t start mm.sh after reboot
    29 Posts 3 Posters 14.3k Views 3 Watching
      sdetweil @trividar
      @trividar read the instructions at the link I gave,
      in a terminal window , use finder to find ‘terminal’
      • T
        trividar @sdetweil
        @sdetweil OK I found the link…
        bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
        just a question, I have set up the magicmirror with all my settings etc. can I just execute this without loosing my stuff??
          sdetweil @trividar
          @trividar no… if u have it running, why do you need to install again?
          if you don’t have it running, then u need to install…
          you can copy the config.js to the new system, but you will have to install the modules and make sure to handle the dependencies they require
          • T
            trividar @sdetweil
            @sdetweil because I can’t get pm2 to work on my mac mini catalina
              sdetweil @trividar
              @trividar oh, pm2… then use the new script for that
              see here
              https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
              sometimes it doesn’t restart on boot like I think it should (on catalina, worked great on sierra an high sierra). haven’t found the problem yet
              • T
                trividar @sdetweil
                @sdetweil oooh perfect… I will try it… do i see this right, I should execute it outside from MM?
                cd
                bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
                  sdetweil @trividar
                  @trividar execute anywhere, it figures it out
                    sdetweil @trividar
                    @trividar thanks for asking about catalina… I have found the ‘problem’ with pm2 restart…
                    do
                    sudo nano /Users/$USER/Library/LaunchAgents/pm2.$USER.plist
                    right at the top there is a string ‘UserName’ shown below
                    the space after the < is because this forum sees the < as a special formatting tag…
                          < key>UserName< /key>
                          < string>?????< /string>
                    anyhow, delete those two lines
                    save the file (ctrl-o,enter), and exit, (ctrl-x)
                    then restart (via shell),
                    sudo shutdown -r now
                      @trividar I’ve added all that to the fixup script… (and the updated install script)
                      so, if u haven’t done this manually, run then script, then restart your mac
