    pm2 dosn`t start mm.sh after reboot
    29 Posts 3 Posters 14.3k Views 3 Watching
      Skorpionbird
      @sdetweil said in pm2 dosn`t start mm.sh after reboot:
      sudo env PATH=$PATH:/usr/local/bin pm2 startup systemd -u pi --hp /home/pi
      thx with this it works fine
      • T
        trividar @sdetweil
        @sdetweil Have you a solution for mac osx catalina? THX
          sdetweil @trividar
          @trividar sure, just use the updated install script, which will be in the next release
          see
          https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
          • T
            trividar @sdetweil
            @sdetweil how can I execute this script?
              sdetweil @trividar
              @trividar read the instructions at the link I gave,
              in a terminal window , use finder to find ‘terminal’
              • T
                trividar @sdetweil
                @sdetweil OK I found the link…
                bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                just a question, I have set up the magicmirror with all my settings etc. can I just execute this without loosing my stuff??
                  sdetweil @trividar
                  @trividar no… if u have it running, why do you need to install again?
                  if you don’t have it running, then u need to install…
                  you can copy the config.js to the new system, but you will have to install the modules and make sure to handle the dependencies they require
                  • T
                    trividar @sdetweil
                    @sdetweil because I can’t get pm2 to work on my mac mini catalina
                      sdetweil @trividar
                      @trividar oh, pm2… then use the new script for that
                      see here
                      https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
                      sometimes it doesn’t restart on boot like I think it should (on catalina, worked great on sierra an high sierra). haven’t found the problem yet
                      • T
                        trividar @sdetweil
                        @sdetweil oooh perfect… I will try it… do i see this right, I should execute it outside from MM?
                        cd
                        bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
                          sdetweil @trividar
                          @trividar execute anywhere, it figures it out
                            sdetweil @trividar
                            @trividar thanks for asking about catalina… I have found the ‘problem’ with pm2 restart…
                            do
                            sudo nano /Users/$USER/Library/LaunchAgents/pm2.$USER.plist
                            right at the top there is a string ‘UserName’ shown below
                            the space after the < is because this forum sees the < as a special formatting tag…
                                  < key>UserName< /key>
                                  < string>?????< /string>
                            anyhow, delete those two lines
                            save the file (ctrl-o,enter), and exit, (ctrl-x)
                            then restart (via shell),
                            sudo shutdown -r now
                              @trividar I’ve added all that to the fixup script… (and the updated install script)
                              so, if u haven’t done this manually, run then script, then restart your mac
