Unsolved pm2 dosn`t start mm.sh after reboot
@sdetweil because I can’t get pm2 to work on my mac mini catalina
@trividar oh, pm2… then use the new script for that
see here
https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-bootsometimes it doesn’t restart on boot like I think it should (on catalina, worked great on sierra an high sierra). haven’t found the problem yet
@sdetweil oooh perfect… I will try it… do i see this right, I should execute it outside from MM?
cd bash -c "$(curl -sL https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
@trividar execute anywhere, it figures it out
@trividar thanks for asking about catalina… I have found the ‘problem’ with pm2 restart…
do
sudo nano /Users/$USER/Library/LaunchAgents/pm2.$USER.plist
right at the top there is a string ‘UserName’ shown below
the space after the < is because this forum sees the < as a special formatting tag…< key>UserName< /key> < string>?????< /string>
anyhow, delete those two lines
save the file (ctrl-o,enter), and exit, (ctrl-x)then restart (via shell),
sudo shutdown -r now
@trividar I’ve added all that to the fixup script… (and the updated install script)
so, if u haven’t done this manually, run then script, then restart your mac
