    help,i broke the mirror
    3 Posts 2 Posters 875 Views 2 Watching
      mrdenmark
      i’ve spent days getting my display how i want it,i deided to add a couple more modules-mmm-formula1 and mmm-googletasks and when i restarted i got the black electron screen,i went back to my last working config-still the same.
      ssh into pi, try npm start and this is the output-
      magicmirror@2.9.0 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.9.0
      Loading config …
      Loading module helpers …
      No helper found for module: worldclock.
      No helper found for module: MMM-DumpsterDay.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘node_helper’
      App threw an error during load
      at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      at Module.require (internal/modules/cjs/loader.js:658:17)
      at require (internal/modules/cjs/helpers.js:20:18)
      at Object. (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:8:18)
      at Object. (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:81:3)
      at Module._compile (internal/modules/cjs/loader.js:711:30)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
      at Module.load (internal/modules/cjs/loader.js:620:32)
      Whoops! There was an uncaught exception…
      { Error: Cannot find module ‘node_helper’
      at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }
      Launching application.
      i’ve searched for similar problems but not found the answer and i’m conserned about doing more damage1
      please help! aaarrrggghhh
        Blauenfeldt
        Someone got it working on this post:
        https://forum.magicmirror.builders/topic/11554/magicmirror-won-t-start-after-installing-module/6
        hope this helps
          mrdenmark @Blauenfeldt
          @Blauenfeldt
          wooohoo,
          awesome,
          that worked,
          thankyou,
          relief…
