    CSS Colur description
    9 Posts 3 Posters 3.1k Views 2 Watching
    • V Offline
      Vauxdvihl
      Hi friends,
      i have a simple question.
      I am using @Sean calendarext2 module and i want to change some colors
      Currently i am using as a reference this page here:
      https://wiki.selfhtml.org/wiki/Grafik/Farbpaletten
      But i want to have a grey and a brown.
      I do not find these ones in the above standing link
      Can please somebody help me
      Thanks a lot
      • brobergB Offline
        broberg Project Sponsor @Vauxdvihl
        @Vauxdvihl
        go to : https://rgbcolorcode.com/
        There you can pick the color you want and then you use the codes to the right
        instead of using the color names
        color: red
        You can use Hexadecimal
        color: #FF0000
        Or RGB
        color: rgb(255,0,0)
        or RGBA (if you want the text to be translucent)
        color: rgba(255,0,0,0.8)
        (you can use many more, but these will do you just fine)
        • V Offline
          Vauxdvihl
          Thanks for the answer
          But the calendar ext 2 supports only 3 digits
          .CX2 .AbfallRest {
            background-color:#330;
            color:#FFF;
          Any other Idea?
          • brobergB Offline
            @Vauxdvihl …
            It’s not special in any way, it’s just css and it can take whatever the css standard does.
            So yes, it will take all the different options I wrote in my answer.
            The three digit HEX (#FFF) is just a shorter (and less exact) version of the six digit HEX, like this
            #FFF is the same as #FFFFFF
            #330 is the same as #333300
            But you can’t get exact colors, you can only get a rough version of the colors, the 3 digit HEX is limited in that regard.
            • brobergB Offline
              here is a list over the different values you can use in any option with colors in css : https://www.w3schools.com/cssref/css_colors_legal.asp
              • V Offline
                Vauxdvihl
                @broberg
                Thanks a lot for your help
                but one question
                i want to have a “brown” like 8B 45 13
                What is here the 3 digit hex ;-)
                S brobergB 2 Replies Last reply Reply Quote 0
                  sdetweil @Vauxdvihl
                  @Vauxdvihl find a hex to decimal converter
                  8b is 139
                  • brobergB Offline
                    @Vauxdvihl just use that hex code, I don’t see why you would bother trying to use a three digit hex when you can’t get that color with just the three digit hex.
                    Slap a # on it and be done. (#8B4513)
                    And the closest three digit code is easily done by removing the second character in the pair.
                    So
                    8B would be 8
                    45 would be 4
                    13 would be 1
                    But this will result in #884411 instead of #8B4513.
                    • V Offline
                      Vauxdvihl
                      @broberg
                      Thanks a lot
                      it is now clear
