    Unable to update to latest version of Node.js and npm
    11 Posts 4 Posters 11.0k Views 4 Watching
    • E Offline
      ernenr1 @sdetweil
      @sdetweil Thank you very much! This actually worked!
        bminer1
        I am not having much luck with this. Been searching and trying everything…
        i@raspberrypi:~ $ node -v
        v10.15.2
        pi@raspberrypi:~ $ npm -v
        bash: npm: command not found
        • E Offline
          EdO
          I’ve used this to update npm:
          npm install npm@latest -g
            sdetweil @bminer1
            @bminer1 yes, they split the npm install off from the node install… so you have to do two now
            sudo apt-get install npm
            then sudo npm i -g npm ( as it updated the usr/lib folder)
              sdetweil @EdO
              @EdO he doesn’t have npm yet… see my post above
                bminer1
                This website was exactly what i needed to get the latest version and it worked.
                https://www.instructables.com/id/Install-Nodejs-and-Npm-on-Raspberry-Pi/
                  sdetweil @bminer1
                  @bminer1 in the future if you use the installer, it will handle this
                    bminer1
                    I went through all of the avenues and this was the only way it stuck.
                    I am creating a second MM Pi so ill try it again on this Pi.
                      sdetweil @bminer1
                      @bminer1 use the new installer script
                      see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
